MY SUB ZERO MODEL 590 IS NOT COOLING ON THE REFRIGERATOR SIDE, THE FREEZER SIDE IS WORKING WELL. I LOOKED BEHIND THE INSIDE BACK PANEL, THERE IS ICE ON SOME OF THE METAL WIRES THERE. FAN IS WORKING. WHAT COULD BE WRONG?
The problem is very simple when you take the panel from the refrigerator on the freezer side you will see Ice, you will have to melt the ice to see the a sensor that controls the d-froster, if you change the sensor that should sovel your problem.
brown liquid coming out of the bottom of my subzero side by side refrigerator/freezer. what is the...
(More)
brown liquid coming out of the bottom of my subzero side by side refrigerator/freezer. what is the problem?
Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to...
(More)
Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to run all the time. The temps are OK. What elst should I look at
when you open the refrigerator the inside light sometimes comes on and sometimes it dosnt. i...
(More)
when you open the refrigerator the inside light sometimes comes on and sometimes it dosnt. i replaced all 4 lights i thought i fixed the problem but its still happening, any thoughts? also when i flick the little switch inside the bulbs light up whats going on?
I can't get at the light bulbs to change them in my Subzero side by side. Its any older model and...
(More)
I can't get at the light bulbs to change them in my Subzero side by side. Its any older model and apiece of glass covers the bulbs but I can't figure out how to remove it. Can anyone help me?
