Question about Invicta II Collection Limited Edition Diamond TwoTone #4742/1 Watch for Men
Watch is too big. How to take out links in band?
    Brigadier General:
  • 5,158 Answers
Please review this instructional page to resize the band
http://www.geocities.com/watch_crazy/bands/bands.htm
robert
Posted on Sep 25, 2009
How do I take out a couple links in the band of a 7056 White Peugeot watch. The pins are not spring loaded like most other watches. The band is plastic and there is only one pin per link. I don't know if...
Hi I just bought this watch for my wife's birthday and we had the same problem, it was too big. I googled and binged for a solution to shortening the band or to remove a link but no one had an answer. I go crazy with things like these and just decided to look at the watch band. First took out the pin for the latch so I can get a better look because that pin can be pressed down. On the inside of the band are arrows. Those arrows indicate which direction the pins can be pushed out. Just push the pin out with a tool, they will require a little pressure but they will give because one end of the pin is bigger than the other. Remove link and enjoy. Hope this helps someone else out there. Just a note this is only for the Peugot 7056 it has a white plastic band and I wouldn't recommend anyone try this with any other model as I don't know how those bands are designed.
Dec 30, 2010 | Peugeot Watches
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Watch band to big
mcdevito75 here, Remoeing links requires a link remover tool, BEST BET, look for a small watch repair shop in your area to remove these liknks, hold onto these removed links in case you need them in the future.
Jul 12, 2010 | Callaway CY2060 Sport Series Watch
How do i take out some links to the band?
There are little pop screws between each of the links  and there are certain equipment used to pop them out.  Can hurt.  I suggest that if you don't want to get hurt or damage the band take it to the place you got the watch or a local jeweler.
May 26, 2009 | Kenneth Cole KS4009 (Size: ) Wrist Watch...
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Link removal of stainless steel watch band
Actually, this seems to be the big end of the split pen. Take a pin and push into the opposite hole ontil the big end pops out, then use pliers to pull it out. It should be easy to put it back. There should be an arrow on the inside of the band to show where to push.
Sep 04, 2008 | Citizen Eco-Drive Modern Watch
Armitron mens watch band link removal
Try http://www.webjeweller.com/jewellery/removelinks.shtml
Dec 25, 2007 | Watches
Invicta II Collection Limited Edition Diamond TwoTone #4742/1 Watch for Men Logo
102 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you an Invicta Watch Expert? Answer questions, earn points and help others
