Question about Poulan Garden
Model 3400, runs on idle but not at full speed,
Model 3400, runs on idle but not at full speed, cleaned everything, adjusted mixture screws per manual. can fool it if choke is pulled out slightly but runs like not getting gas at high speed?
It seems like high speed channel in carb is plugged but I can not find anything. When it comes off idle when pulling the throttle it just dies.
    President:
  • 2,220 Answers
I think like you it is running lean. Normally I would provide a link to the IPL (exploded parts list) for your saw but Poulan just locked the site for non-dealers. Please register your displeasure here http://www.poulanpro.com/node4020.aspx. IMO as an owner, you should have free access to these.
Sounds like time for carburator kit, HTH
Lou
Posted on Sep 26, 2009
Bought new carb for ryobi blower need to set up carby so it will start
Set both the high and low mixture settings two full turns back from the closed setting(full clockwise).. Set idle speed for all ahead full.
Start sucker and after a warmup throttle it down and then start adjusting the low mixture screw for fastest idle. Then lower idle some more but not to point where it starts to run rough. Then rev the sucker to high speed and adjust the high mixture for max speed. You may have to make a slight adjustment on the high speed to get a smooth transition from low speed to high.
Feb 09, 2017 | Ryobi Garden
It idles fast if I turn the idle down it stalls running rich on top end at fast idle sometimes it will drop to a very low idle and shut off
adjust the idle mixture screws first and then adjust the idle speed screw to compensate
adjusting the idle mixture screws will alter the idle speed but when properly adjusted then adjust the idle speed screw,
Aug 24, 2015 | Motorcycles
What is the proper carberator adjustment
Start with 1 full turn out from the closed position on both the idle and high speed mixture screws. After the engine has warmed up, hold the throttle wide open and adjust the high speed mixture screw until the engine runs at the highest RPM then turn the screw counter-clockwise about 1/8 turn.
Next, turn the low speed mixture screw in whichever position gives the best idle.
After making these adjustments, check the throttle response. If the engine hesitates when applying the throttle, turn the low speed mixture screw counter-clockwise about 1/8 turn.
Jan 30, 2015 | Garden
Runs slow
In California the new blowers have sealed mixture adjustments and you need the have your carb. mixture adjusted be a qualified shop. If your carb. HAS mixture adj., turn the high speed mixture so it runs best at high speed, then turn another 1/8 turn counter clockwise to be a little rich. Then at idle adj. the other screw till it idles best.
Apr 21, 2014 | kawasaki Krb300a Backpack Leaf Blower
Choke problem
That's an indication that the idle mixture is too lean, as the choke richens up the mixture, allowing it to run.
Your carb should be similar to this:
http://www5.picturepush.com/photo/a/3728808/img/3728808.jpg
The AIR SCREW adjusts the mixture (rich/lean), and the IDLE SCREW adjusts the idle SPEED.
Try screwing in the AIR SCREW 1/2 a turn and see if that helps.
If not, try another 1/2 turn.
Still no idle?
Turn the screw back where it was (1 full turn) and then screw it OUT 1/2 turn, then if not, another 1/2 turn.
Once you have the mixture correct, the idle speed can be set with the IDLE SCREW.
Jan 11, 2014 | 2003 ATK 125 4-stroke
What is the factory setting for lowand high screws on 25cc craftsman blower
If the two screws are side by side, one is the high speed mixture screw and the other is the low speed mixture screw. To set the high and low adjustment screws, tighten the screws in until they stop, don't force the screw after it stops. Back each screw out 1 1/2 turns. The engine will start and run here if everything else is ok. Fine tune each adjustment screw by closing the screw off (CW) until the engine runs rough. Back the screw out (CCW) until the engine smooths out. Run the engine at full speed and adjust the high screw. Let off the trigger and adjust the low screw. Once the mixture screws are adjusted, you can turn the idle screw to adjust the idle speed. It can take some time getting it all adjusted.
Nov 20, 2013 | Garden
I have a 1995 homelite plt-3400 gas trimmer. It starts ok. It runs fine at full throttle, but will not idle. I have replaced the primer bulb because it had a crack and it has a new spark plug. I have also...
You may be able to adjust the carburetor as I describe below but if it doesn't work then I would recommend you clean the carburetor and install a carburetor kit. When you have it back together then you will need to able to adjust the two mixture adjustment screws. When you have it started you goal is to adjust the idle screw so it not only idles but when you pull on the speed control it does not falter you try to accelerate it. The other screw affects the mixture at higher speed. When you can accelerate it from idle to full speed and back again repeatedly without faltering etc. then it is fairly good. If you turn both of these screws counter clockwise a little more it should reduce the risk that you may be too lean. It still needs to run well. I hope this helps and if you have any other questions feel free to contact me.
Aug 14, 2011 | Garden
I have a john deere 70 1974 with a 7 horse power tecumseh how many times to i turn the either jets on the carb
The bottom screw on the carburetor is the main fuel mixture screw, turn this "in" slowly until is "seats" and then back it out two turns. The idle mixture screw is located on the side (do not confuse with the idle speed screw), turn this in slowly until it seats and then back it out one turn. This will get you in the ballpark but it will have to be fine tuned from their. The proper adjustment is between a "lean" running condition (engine will try to cut off) and a "rich" running condition (engine will load up). The main fuel mixture is adjusted at full throttle position and the idle mixture screw is adjusted at idle speed. Once this is done, you can adjust the idle speed screw in the low throttle position. Hope this helps.
Feb 23, 2011 | John Deere Garden
I have a Briggs and STatton 24 OHV intek motor on a craftsman lawn tractor. I got it on sale and when I got home it ran rough. The fuel line had collapsed or was plugged with some white powder. I took off...
It sounds like the fuel mixture is running very Lean..There are usually two adjusting screw screws on the carburettor that control the mixture. A Larger one is for the Main Jet and a smaller one for the Idle Jet. There is also an adjusting screw on the throttle butterfly to control the idle speed.
To adjust setup, start with at least a half tank of fuel, and have engine at operating tempurature (That is warm but not overly Hot). As a starting point, loosen (anticlockwise) Main Jet screw about half a turn, to richen mixture,so that engine will run without choke. Run engine at full speed and adjust main jet for highest smooth speed without engine missing due to mixture being too lean or rich.
Allow engine to idle and the adjust Idle Jet Screw for smoothest idle. Idle Speed screw may have to be adjusted if idle speed is too high/low.
Sequence above may have to be repeated to get best running. If engine hesitates sometime when sudden load is applied but then picks up, try adjusting Main Jet by 1/8 to 1/4 turn richer until it handles the load without faltering.
Aug 22, 2010 | Briggs & Stratton Briggs Stratton Intek V...
In my honda xlr 125 i changed the main jet to #92 and slow jet to #35 is this ok? If so how can i tune the carb. I am from Sri Lanka. Its a tropical country.
The only way to know if the jetting is correct is to see how well it runs - and check the spark plug color.
You can start by warming up the engine and adjusting the idle mixture. Do this by turning the idle mixture adjustment screw (there are only two adjustment screws on the carburetor: one is the idle speed adjustment, the other is the idle mixture adjustment). Turn the idle mixture adjustment screw in or out until the fastest idle speed is attained. Then adjust the idle speed with the idle speed adjustment screw.
Now ride at full power and see how well it performs. If the engine cuts out or surges at full throttle, that means the main jet is too small. If the engine produces black smoke from the exhaust and doesn't seem to produce enough power, then the main jet is probably too big. Confirm the main jet correctness by looking at the color of the spark plug: white or light tan = too lean (main jet too small). Dark brown or black = too rich. Dark tan to brown color = perfect.
Nov 29, 2009 | 2000 Honda XLR 125 R
Garden Logo
193 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
