Question about LG KU990 Viewty
Install new operating system
Tough books panisonic has NO Floppy drivel, or CD rom drive, how do I install an OS?
  • sandybottom Dec 17, 2007
    USB port does not reconise ANY thing I plug in....Yet before old hard drive died it worked fine...
    will try that, Thanks
  • 32 Answers
You can install through the USB port, either with a regular USB flash drive with the proper software on it (if you are installing something like Linux), or by plugging in an external hard drive (Firewire would also work for this, if your computer supports it) to read the installation CD-ROM.
Posted on Dec 17, 2007
  • aaaa Dec 17, 2007
    Sorry, meant to say "external CD-ROM drive", although a hard drive would also work, same way as a flash drive.
  • aaaa Dec 17, 2007
    If you want to install Windows an external CD-ROM drive is probably the way to go. You will have to ensure that booting from a USB drive is enabled in your BIOS, and then hit F8 and select "USB drive" from the boot options when your computer starts up.
I have got a O2 mini. how to do setup new OS? i wanna resetup.
Please!
Posted on Apr 17, 2008
CD drive refuses to open or run even when I press the button
Select a cd rom device,then add another boot up disc,then see if it opens.Will it take a cd rom better than a floppy? If so use the boot up disc,rather than an older and possibley more damaging floppy.
Feb 16, 2010 | E-Machines eOne 433 PC Desktop
Tip
How to do Fast and unattended Setup of OS in multiple machines
<span> <p><span>Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement.</SPAN><br> <p><span> </SPAN><br> <p><span>Verify for unattended Installation:</SPAN><br> <p><span><span> </SPAN>To perform an unattended installation from a CD-ROM, the following conditions must be met:</SPAN><br> <p><span>The computer must support booting from a CD Rom<span> </SPAN>The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.</SPAN><br> <p><span>The answer file must contain a valid [Data] section. This is explained later in this article.</SPAN><br> <p><span> </SPAN><br> <p><span>Before installation it has some conditions:</SPAN><br> <p><span><span> </SPAN>1&gt; the installation is limited to a single partition.</SPAN><br> <p><span><span> </SPAN>2&gt; you cannot specify third-party drivers during Setup </SPAN><br> <p><span> </SPAN><br> <p><span>Prepare For an Unattended Installation:</SPAN><br> <p><span><span> </SPAN>To prepare your computer for an unattended installation from a CD-ROM, I've followed these steps</SPAN><br> <p><span>First I've created a Folder in local drive & shared it. Then I create setup manager.</SPAN><br> <p><span>I install Setup Manager by following these steps:</SPAN><br> <p><span>I Open My Computer, and then open the Support\Tools folder on the Windows XP CD-ROM.</SPAN><br> <p><span>Double-click the DEPLOY.CAB file to open it </SPAN><br> <p><span>On the Edit menu, click Select All.</SPAN><br> <p><span>On the Edit menu, click Copy to Folder.</SPAN><br> <p><span>Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.</SPAN><br> <p><span>Click Copy.</SPAN><br> <p><span>Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows Setup Manager Wizard starts.</SPAN><br> <p><span></SPAN> <br> <p><span></SPAN></SPAN> <br> <img src="alokerdas_9.jpg"> <br> <p><span>Then I Use Setup Manager to Create an Answer File.</SPAN><br> <p><span>I open the setup manager & go to create a new answer file.</SPAN><br> <p><span>Then I go to the unattended installation & windows version option.</SPAN><br> <p><span>I have selected the fully automated option & create an answer file.</SPAN><br> <br> <br> <img src="alokerdas_10.jpg"> <br> <p><span>If you want Windows Setup to delete all partitions on the hard disk and to create a new partition, you must include the Repartition command in the Winnt.sif file. Under [Unattended], insert a new line, and then type "Repartition=Yes"</SPAN><br> <p><span>If you omit this line, you are prompted for the installation partition.</SPAN><br> <p><span> </SPAN><br> <p><span>Add a [Data] section with the following entries to the unattended answer file:</SPAN><br> <p><span>Unattended Install=Yes - Value must be set to "yes"</SPAN><br> <p><span>MSDos Initiated=No - Value must be set to "no" or Setup stops during the graphical portion of Setup<span> </SPAN></SPAN><br> <p><span>Auto Partition=1 - If the value is set to 1, the installation partition is automatically selected. If the value is set to 0 (zero) you are prompted for the installation partition during the text portion of Setup.</SPAN><br> <p><span>Save the unattended answer file as Winnt.sif on a floppy disk.</SPAN><br> <p><span>Insert the Windows CD-ROM into the CD-ROM drive, and then insert the floppy disk into the floppy disk drive.</SPAN><br> <p><span>Change the boot order in the CMOS so that the CD-ROM is first in the list.</SPAN><br> <p><span>Restart your computer. When Setup is started from the CD-ROM, the Winnt.sif file located on the floppy disk will be used to complete the unattended installation.</SPAN><br> <p><span> </SPAN><br> <p><span>This is an easy process to save time & effort.</SPAN>
on Feb 15, 2011 | Computers & Internet
Tip
How to do Fast and unattended setup of OS
Here I have an Idea for primary setup of a large lab quickly. Suppose you have to setup a lab where have more than twenty or thirty system but must setup it quickly. At that time if you don't have enough CD Rom drive or not enough OS installer CD then the task will take a long time. To save time at the same moment I like to prepare an unattendent operating system installation. Before this task I must check for presence of some requirement. Verify for unattended Installation: To perform an unattended installation from a CD-ROM, the following conditions must be met:The computer must support booting from a CD Rom The unattended answer file must be renamed to Winnt.sif and copied to a floppy disk so Setup can access it. So must need a floppy disk drive.The answer file must contain a valid [Data] section. This is explained later in this article. Before installation it has some conditions:
1> the installation is limited to a single partition.
2> you cannot specify third-party drivers during Setup Prepare For an Unattended Installation:
To prepare your computer for an unattended installation from a CD-ROM, I've followed these stepsFirst I've created a Folder in local drive & shared it. Then I create setup manager.I install Setup Manager by following these steps:I Open My Computer, and then open the SupportTools folder on the Windows XP CD-ROM.Double-click the DEPLOY.CAB file to open it On the Edit menu, click Select All.On the Edit menu, click Copy to Folder.Click Make New Folder. Type the name that you want for the Setup Manager folder, and then press ENTER. For example, type setup manager, and then press ENTER.Click Copy. Open the new folder that you created, and then double-click the setupmgr.exe file. The Windows
Setup Manager Wizard starts: alokerdas_2.jpg
<SPAN style="FONT-FAMILY: 'Courier New
The computer is asking for me to restore mbr on the compaq computer corporation setup utility
Might be Operating System has been corrupted so pls repair the operating system through OS CD or re-install the OS .if still issue not resolve then replace the hard drive with goods one.
Nov 20, 2009 | Compaq Evo D500 PC Desktop
When i turn on my laptop it says invalid system disk.replace the disk and then press any key
You probably are using Windows XP. With this error, you must re install your Windows XP operating system with your XP CD.
Oct 21, 2009 | Computers & Internet
Motherboard
Hi Henryk14,
There are a few issues that can halt Windows from installing.
1. If your Microsoft Windows CD is a copy & not a valid CD this can happen. (Possible bad copy).
2. You CD-ROM drive is either dirty, (Inside) or it's not reading the disk. (Check the data cable on the cd-rom drive. Make sure it is fully connected). (Swap out the data cable is needed).
3. E-Machine's can & most do have more than one partition on the primary hard disk drive.
Most likely there are two hidden partitions on the drive. If the manufacture placed one of the partitions at the top of the drive, (As many do to stop owners from upgrading their operating system with their own CD). The installation of XP can be halted. You will not see an error message from windows during installation in this case.
(The hidden partition is too small to allow windows to install, 4MB in size is about norm).
One option is to contact the manufacture & buy their upgraded OS CD for your model.
Another would be to erase the drive with a floppy disk. A standard Win98 boot disk will do the job but that is ill advised.
The best way to clean & format the entire drive would be to find the manufacture of the hard disk drive & go to their web site. Download their Dos software to create a bootable floppy disk for Dos. Boot the system with the floppy disk & format the drive. This will remove all the hidden partitions & make the drive whole again.
Most hard disk drive manufactures also provide software to create a bootable CD. This will also clean the drive & set it up for window. (You should back up all your data to CD or a second drive).
Other software can be used to totally clean a hard disk drive. "Darik's Boot And Nuke".
Found here: http://www.dban.org/ (Ideal for tough systems & dreaded blue screens).
Good luck Henryk14!
Mike
Oct 24, 2008 | E-Machines eMachines Desktop PC
How to install operating system on laptop with now cd-rom drive or floppy
Did you change the '1st boot' drive to the optical drive?
If you haven't, you need to enter the BIOS setup and change from C: to whatever your optical drive is named and then change it back once the operating system is installed on the C: drive.
Oct 11, 2008 | Compaq Armada E500 Notebook
Installation
You need to use floppy disks (called boot disks) to boot DOS with cd-rom drivers, because the win98 cd isn't bootable by default.
I suggest you to go to http://www.bootdisk.com/bootdisk.htm and grab the respective windows 98 boot disk.
You will need a functional computer to write the disk image into the floppy.
After that put the boot order in BIOS as floppy first.
Once you see DOS prompt A:\> just access your cd-rom drive like d: or e: and then type install
WaZZie
Jan 04, 2008 | Microsoft Windows 98 for PC
Panasonic Toughbook CF-27
i need help i have a panasonic cf-27 toughbook with a usb cd drive and usb floppy drive ive tried both seperate and with a multi usb connector to boot both but it doesnt find them can anyone help me?
Oct 26, 2007 | Panasonic Toughbook CF-27 Notebook
PRINTER INSTALLATION PROBLEMS
Please check If your CD drive is detected on BIOS, if yes then Put a Windows XP bootale CD (checkout for the Service Pack) and choose boot from CD in the BIOS and go for "repair option" after the Agreement "I Agree-press F8" session. complete the installation then try installing the printer.
Oct 09, 2007 | Computers & Internet
LG KU990 Viewty Logo
164 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
