Question about HP Deskjet F4180 All-in-One InkJet Printer
Yellow not printing?
Just inserted new ink cartridges, black & colour. Documents are printing but the yellow seems to not be there. Items that should be green are blue etc. What can I do?
I have a MFC-79CW running out of yellow colour, now it seems unable to copy paper by pressing 'BLACK' buttom. Do I have to replace new colour boxes just to use B/W ? Thank You
Yes, you have. Inkjet printers use color ink in cleaning cycles, so your color cartridge will be eventually empty even if you only print in B/W.
If you need to print/copy a lot of B/W documents, I would recommend a laser printer, or an inkjet printer with individual color cartridges (printers from Epson, Officejet from HP, etc). You'll save some money by using those.
Mar 02, 2011 | Brother Office Equipment & Supplies
Yellow not printing properly.
Go to the maintenance section of your printer on your desktop and clean the cartridges
Start - printers or Start - control panel - printers
Also check the level of your ink while you're there
May 08, 2010 | HP Deskjet D2360 InkJet Printer
Hpdeskjet932c quit printing yellow & blue
Just try with replacing the color cartridges may be it is dry.
Sep 24, 2009 | Zebra 110Xi III Plus Thermal Printer
When printing colour, black appears green
A worn out printhead can allow inks to contaminate each other, after cleaning you need to check your cartridges, if yellow is a brown color, you are getting contamination and need to replace the printhead. Black is hard to tell but when cyan gets too dark it's contaminated as well.
Aug 12, 2009 | Canon BubbleJet i560 InkJet Printer
I have a used C60. I have replaced both ink cartridges with Epson cartridges. When printing in color, the colors are not accurate. For example, red comes out yellow. Also, there are lines running through...
Hi there. The reason for your problem is that the colour cartridge contains cyan, magenta and yellow ink, plus a black cartridge of course. All the other myriad colours are produced by mixing these four basic colours. So, if you print red, it requires ink from both the magenta and yellow cartridges. Thus if your red produces a yellow print, it means your magenta is not printing. This can be due to a number of reasons, mainly an empty or faulty magenta cartridge or blocked magenta print nozzles.
If you wish me to help you with sorting out the lack of magenta, please post a new comment to this effect.
Mar 04, 2009 | Epson Stylus C60 InkJet Printer
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Pixma iP1500:new ink cartridges fitted but no Magenta
Take a look at the mounting point. They break very easily on this model. If not broke, try cleaning with a swab and inserting the cart again.
Jul 03, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
I cannot print but i have only the black cartridge but i dont have the yellow cyan ang midget
Most modern printers use some colour when printing Black and therefore will not print if ANY ink cartridge is showing as empty.
Unless your printer has a setting for using Black ink only (this is not the same as printing a black and white document), then you will need to purchase and install the colour cartridges before printing can take place. The good thing about this is that very little colour ink is used when printing black and white documents - so they should last a long time.
Good luck.
May 09, 2008 | Brother Multi-Function Center MFC-240C...
How do I reset the ink levels?
We have an issue of missing or replace yellow cartridge. Please feel free to contact the HP support for replacement of the printer, if the printer is in warranty status. HP would replace the printer.
Dec 29, 2007 | HP Photosmart C5180 All-In-One InkJet...
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
HP Deskjet F4180 All-in-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
