Question about Coleman Air Tools & Compressors
My compressor starts and stops and wont keep running
  • 21 Answers
1. pressure switch is bad.
1a. pressure switch fill with water\humidity inside.
2. motor is seized as soon as it overheats it stop.
Posted on Sep 26, 2009
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
I have SSR up series 15-30hp air copressor.The compressor will start and build pressure until the pressure gets to a certain reading on the gauge and the unloader valve begin to unload the air out. But the...
The compressor will run stop start or load unload. There is a switch for this. Make sure the right mode is selected.stop start for light use. Load unload for heavy. This mode keeps the starting and stopping to keep from burning up the motor. That is rated by stops per hour. They shouldnt be more than 10 times per hour
Dec 30, 2014 | Air Tools & Compressors
Indesit fridge/freezer starting & stoping
The compressor is supposed to start & stop, it wont run all the time.
Nov 22, 2013 | Amana ABB1927DE Bottom Freezer...
My freezer keeps clicking off after I plug it in and it wont get cold
hi daniel.clicking off is usually the motor (compressor).u can try the comp/relay first.good luck Ali
Aug 21, 2012 | Refrigerators
New copeland compressor wont start
Hello,By all means install a hard start kit on the cap.Your wiring is correct.A scroll compressor usally doesn't need a start kit but I have seen 5 ton units that take one.Check the compressor tag and make sure the compressor is not a 3 phase motor!
Apr 21, 2010 | Heating & Cooling
MY COMPRESSOR JUST KEEPS RUNNING AND WONT REACH MAXIMUM PRESSURE AND SHUT OFF. I CAN SHOOT NAILS BUT IT WONT SHUT OFF DOWN.
The compressor itself sound like it is bad. You might see what it cost to repair it. It might be cheaper to get another one...keep in mind if you do a lot of work with it that a 2 stage compressor will cool better and you won't have this type of problem again.
Oct 19, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
My ac compressor works while i am recharging it and keeps running as long as the car is running when i turn the car off and on again it wont run
Look on the cold line just before it goes through the firewall you should see a pressure switch. This switch may be bad. It has contacts that open and close to keep the compressor cycling and prevents the compressor from freezing the lines.
Apr 29, 2009 | Heating & Cooling
My compressor will not run.
The start capacitor could be bad. Also the compressor could be worn out. If compressor starts and runs then stops and become hot makes me think the compressor is defective. How old is your refrigerator? Even so compressors go bad. Thanks, Seabreeze
Mar 28, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore side by side compressor keeps getting hot
Your fan is stalling which in turn is over heating the compressor causing it to shut itself down. Replace the fan and make sure the coils under the fridge are clean. That should take care of the problem. Good luck
Dec 29, 2008 | Kenmore 50522 / 50524 Side by Side...
Air Tools & Compressors Logo
104 people viewed this question
Top Coleman Air Tools & Compressors Experts
John Trevino
elunsford
JOHN LAPIER
Are you a Coleman Air Tool and Compressor Expert? Answer questions, earn points and help others
