Question about Dell 1600n All-In-One Laser Printer
Keep getting a document jam error and can't find the problem.Dell 1600n
2 Suggested Answers
SOURCE: Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Posted on Jun 19, 2008
Dell 1600n laser printer has error message of document jam
the automatic document feeder has a few sensors on it, most likely one of these has become displaced, ofter they are just clipped in so if you are handy with a screwdriver lift the lid and remove some screws from the bottom of the document feeder and gently dissasemble, not expert at this model but take it slowly or get someone handy to do it, once youve got to the circuit board in the automatic document feeder the problem will be one of the arms that breaks the beam in the optical sensor (black U shape) should just clip back in and problem solved.
Sep 25, 2009 | Dell 1600n All-In-One Laser Printer
Frequent paper jams on a Dell 1600n AIO, sometimes doesn't grab the paper from the tray (not really a jam, just need to open and close tray), sometimes gets caught halfway through the path -- need to open...
This could be caused from the papers you use at times(weight). Call on a Dell representative to check it out for you if you bought it from a Dell shop.
Thanks
Aug 19, 2009 | Dell 1600n All-In-One Laser Printer
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
Grey arm is in place. cannot find any paper anywher that is a jam
this can happen if any of the contact points on the cartridge are even remotely scratched or if the cartridge is "low" even if it doesnt say its low
Please Rate Me
May 28, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600N warming up message
Hi Unplug the printer power cable from the wall and disconnect it from the printer as well. Turn the printer power switch on for 15 seconds. This will reset the printer. Turn the printer power switch off and plug the cable back in on both ends. Then turn power on. The Document Jam error should be eliminated.
Please keep in mind you must check for any small pieces of paper or look for a real paper jam prior to completing the steps above.
I hope that helps.
Sep 16, 2008 | Dell 1600n All-In-One Laser Printer
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
Rear output slot
What do you mean? Do you actually want the paper to deliver out the back? Do you need the part that goes to the back so the paper delivers properly? Explain...
Call Dell Services. They will be able to help you purchase any part you need.
Mar 11, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
154 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
