Question about Dell 3010cn Laser Printer
I get an arror code "Paper Jam Fusor 077-104" "Open Paper Cover Remove Paper" I have tried to see if there is any paper jam and cannot find anything. I have shut off power, disconnected cord but cannot get past the error message.
  • 5 more comments
  • dabenner Sep 26, 2009
    Everything checks out okay from what you suggested. What shall I look at next?
    Sorry sir, I should have answered that question. I do not have the duplexer option.
    I cannot get out of the error messageing mode. When I press menu it still flashes the same thing on screen.
    What do you mean press on the "o" button and then enter the pass code numbers. There is not a keypad on the printer.
    I have done as you instructed and have not been able to get past the error code screen.
    Okay I turned on printer, but you talk about pressing and holding "power button" What is that? The 30010cn only has menu, cancel, enter, up, down, left, right buttons, besides the on off switch on side.
  • dabenner Sep 27, 2009
    Okay I cannot understand what you are talking about when you talk about the RA/PH tray. The printer does not have a removable Registration cover, it swings open in the back. The paper feeds from the front and does not have a removable feeder that I can determine. Please explain yourself better and send a diagram or in some way help me to understand what you want me to do.
    President:
  • 1,653 Answers
As often happens with DELL printers check all the paper paths and make sure there is no sign of any paper or pieces of paper. Also vacuum the paper path areas and use a soft brush to clean all the paper path sensors.
Also check the Web Config Tool to make sure evertthing is OK.
Reboot the printer.
If that does not cure the problem then reseat the fuser unit and try again.
If that fails then reset the NVRAM and reboot the printer.
Posted on Sep 27, 2009
  • 615 Answers
Does the feed roller make a complete revolution? There are plastic guides on each side of the feed roller. When the tray lifts, does it get stopped by these guides and is not allowed to lift any further. If No, the roller does not. It looks like the guides might be stopping the tray from lifting all the way. That's the problem...... and a common mistake. The plastic guides were not re-positioned correctly when the Paper Handler/Registration Assembly was replaced. You probably see these guides pointed downward? They shouldn't. Remove the PH/RA again and tilt the plastic guides until the square cutout on each guide fits into the bottom edge of the PH/RA as you replace it...let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 26, 2009
  • 4,281 Answers
First turn off the printer.
Then pull ink cartridge from printer.
Then clean dust from its position on printer.
Check on ink cartridge clean ink powder and dust from it.
Then refix ink cartridge.
Then check in back side of printer that there isn't any small paper pieces.
let me know if you need more assistanse.
Thanks.
  • Ok first turn on printer then press power button for 10 seconds.
    Then go to printer menu screen then go to settings and reset all settings .
    Then that message gone.
    Let me know if you need more assistanse.
    Thanks.
    President:
  • 632 Answers
Is the duplexer used?
Posted on Sep 25, 2009
  • 10 more comments
  • Jan McZeal
    Jan McZeal Sep 25, 2009
    1. If duplexer is not being used, open registration cover.
  • Jan McZeal
    2. Verify that the registration actuator is not damaged.
  • Jan McZeal
    3. Verify there are no foreign objects in the registration cover interlock area.
  • Jan McZeal
    Jan McZeal Sep 26, 2009
    is the duplexer used?
  • Jan McZeal
    If duplexer is used, verify that the acoustic cover is removed.
    1. Press the latch at the top left corner of the duplexer option, and then swing the assembly open.
  • Jan McZeal
    2. Verify the acoustic cover has been removed.
  • Jan McZeal
    3. Remove duplexer.
  • Jan McZeal
    Reinstall everything and make sure all fits together tightly and perfectly..
  • Jan McZeal
    Procedure #1 Clear NVRAM (under maintenance)
    You can restore the original factory default menu settings by initializing NVRAM. (Does not reset Network or Security settings)
    1. Press Menu
    2. Press "down" until Configure appears, and then press "right"
    3. Press "down" until Maintenance appears, and then press "right"
    4. Press "down" until Init NVRAM appears, and then press "right"
    The Init NVRAM Are you sure? message appears on the operator panel. Press the "enter" button in the center.
    5. Wait until you are prompted to restart the printer, then turn off the printer, and then on again.
  • Jan McZeal
    Procedure #2 Clear NVRAM (under Network)
    1. Press Menu
    3. Press "down" until Network appears, and then press "right"
    If
    you want to restore the printer completely to factory defaults, perform
    both procedures. I
  • Jan McZeal
    Press menu while powering up the printer.
  • Jan McZeal
    Hold down "0" button for 5 seconds the press Start button while holding down "0" button. The machine will prompt you to enter password. Enter 6789 the press confirm.
Had paper jammed - removed jammed paper - but nerror light still on
Before you can clear a "PAPER JAM" or "PRINTER JAM" error, you must locate where in the unit the paper is jammed.
First, unplug the machine for safety and disconnect the telephone line. Next, follow these instructions based on where the paper jam is located.
Paper is jammed inside the paper tray:
  1. Pull the paper tray out of the machine.
  1. Pull out the jammed paper to remove it.
  1. Reload the paper in the paper tray.
  2. Reinstall the paper tray.
Paper is jammed inside the machine:
  1. Remove the jam clear cover on the back of the unit. Pull the jammed paper out of the machine.
  1. Re-insert the jam clear cover.
  2. If you can not pull out the jammed paper, lift the scanner cover from the right-hand side of the machine until it locks securely into the open position.
  3. Remove the jammed paper.
  4. Check the print head's position. In the example photo the print head is positioned at the left hand side of the platen area.
  5. Gently move the print head to the center.
    Note Be careful to not force the print head to move.
    If the print head is positioned at the far right hand side, you cannot move it. Please contact Brother Customer Service from "Contact Us".
  6. Examine under the print head. If anything is found, remove it.
    Note Use a flashlight if necessary to check thoroughly.
  7. Lift the scanner cover to release the lock. Gently push the scanner cover support down and close the scanner cover.
  8. Reconnect the power cord and telephone line.
Note To prevent paper jams, do not put multiple kinds of paper in the paper tray at the same time.
If the message continues to appear on the LCD, the machine will require repair. Please contact Brother Customer Service from "Contact Us".
Thanks for using fixya......
Oct 26, 2010 | Brother Office Equipment & Supplies
Recurrung jam message
if there's no paper jammed then a sensor might be dirty, the printer has several sensor along the path of the paper to detect its flow.
Mar 30, 2010 | Xerox DocuPrint C525A Laser Printer
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
Removed paper after paper jam and have opened all the doors to check everything, however it still reads 'switchback jam open front cover up scanner unit'
  • Step 1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  • Step 2 Turn off the printer.
  • Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • Step 6266_a1.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_b1.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • Step 7266_a2.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/ehows/steps/books/266_a2.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  • Feb 19, 2010 | Konica Minolta Magicolor 4695MF All-In-One...
    My printer always said ''open back cover and then remove the paper jam'' what's that means? also can't print anything.
    open the back cover to remove any paper jam on your printer, follow on it. Maybe there's a paper inside hanging in the ruler, take a look.
    Jul 22, 2009 | Office Equipment & Supplies
    Paper jam
    try this
    1. Turn off the printer.
    2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
    3. Also open the back cover of the printer if this model has one.
    4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
    5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
    6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
    7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
    8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
    9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
    10. see alternative if the problem is still not solved.
    alternative :
    Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
    Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
    give this a try
    alternative :
    Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
    Paper jam message but there is no paper jammed. opening and closing cover doesn't work.
    hi,are you sure no paper jam ok check very very small paper in your machine or clean the sensor.
    Apr 28, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
    MY PAPER IS JAM IN MY HP DESKJET D4160 PRINTER
    Open the paper jam cover at the back of the printer and remove the jammed papers, be sure you return properly the cover afterwards. Re-start your machine.
    Mar 02, 2009 | HP DeskJet 3745 Printer
    Dell 3010cn Laser Printer Logo
    199 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Electro Med Services...
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
