The colors are mixing togather - Televison & Video
  • 3,459 Answers
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Sep 27, 2009
Do you need to mix oil and gas togather and if so how much.
Obviously it depends upon the leaf-blower. It makes sense for a leaf-blower to be two-stroke, which means an oil and petrol mixture. However, dependent upon the engine, you'll have to make sure you are using the correct mix. Frequently these mixtures are 1:50 and 1:20 or 1:25. Do make sure about the correct ratio for your own machine.
Mar 24, 2015 | Garden
Mixed ink systeme
Match all your clients' custom colors with the HP Indigo Ink Mixing System. This stand-alone device allows operators to mix a wide range of special colors from a set of base inks. The HP Indigo Ink Mixing System combines state-of-the-art color measurement technology with HP ElectroInk to make color matching a precise and predictable procedure. Fully automated software guides the user through steps of measurement and analysis to determine the best color match to the original sample and to mix new ink-easily and efficiently. If you prefer, special HP IndiChrome Off-Press inks can be mixed and shipped to you from HP at any time.
Apr 23, 2014 | HP DesignJet 3500cp InkJet Printer
Should i use dex cool or 50/50 mix in alero
You should use what ever color is in there. But they do make , what they call a global mix (usually green) that can be mixed with all other colors of anti freeze. 50/50 mix gives you protection down to -20 degrees. If you live in a colder area, use straight antifreeze.
Apr 17, 2014 | 2004 Oldsmobile Alero
How should I mix acrylic paints correctly?
You must work fast while you are mixing acrylic paint colors because the dry very fast. my suggestion is to mix your acrylics to the colors you want while using more than you need. The remaining color should be stored in a sealed container to use later.
Feb 03, 2013 | Crafts & Hobbies
Why do my colored cartridges run out when I never fax colored papers? I have a MFC3360c
Unless you specifically tell the machine to only use the black cartridge, then it will mix your colors to make black ink. If then your black cartridge runs out it will also mix your colors.
Apr 16, 2011 | Brother Office Equipment & Supplies
Formatting Nokia 3110c
do format by finger with press togather * button, 3 button send button and power on togather.do not release for a moment. if not work do it again its must press togather .
May 21, 2010 | Nokia 3110 Cellular Phone
Colors mix
there is a problem in signal cable bend it if change in color is seen then replace the cable problem will be solved
Feb 26, 2010 | CTX S965A (Black) (Black, Silver) 19" LCD...
MAGELLAN SPORTRAK COLOR DISPLAY REPLACEMENT
Whats up rjallan?
There is 6 screws holding it togather, the bottom two are under the rubber under where the batteries go. You also have to pull the plugs out. By the way I have a screen for you. I have 3 demo nits so i cant program them to use. But the screens are good.Email me your address and I will send you the screen in the mail. My email address is erik_jacobson2007@yahoo.com.
Let me know
Erik
Sep 14, 2008 | Magellan SporTrak Color GPS Receiver
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
