Question about IBM Infoprint 1332 Laser Printer
All envelopes come out crisp and wrinkled after they have been fed and printed. What is causing the wrinkling and how can I stop it from happening?
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
Envelope printing error - envelope prints wrinkled from MP tray
sorry buddy but mfps wrinkle envelopes he have tried many things on many models they all wrinkle the best thing you can do is try to reduce the wrinkle we tuck the flap inside and that helps a little other than that sorry
Envelopes wrinkles after running through printer
Minolta does recommend stuffing the lip inside the envelope before running. But I think it only helps with jamming. Plus high humidity can cause wrinkling.
Mar 14, 2013 | Konica Minolta Office Equipment & Supplies
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
HP Color LaserJet CM2320nf MFP Envelope wrinkles
On alot of printers when you print envelopes theres a back door on the printer to prevent the curling or wrinkles. Just open the back door when doing envelopes.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | HP Office Equipment & Supplies
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
Brother MFC-9840CDW wrinkles envelopes. Brother says this is "normal", and that the only way to 'fix' it is to open the back of the printer EVERY TIME YOU PRINT AN ENVELOPE and make some kind of...
Problem Solved!
I have a Brother MFC-8480 DN all in one printer, copier, fax and scanner.
I discovered that envelopes wrinkle because users, like me, didn't know that Brothers built in a no-wrinkle, pass through exit for envelopes, labels and thick paper.
Envelopes were never to be printed by inserting them in the front and letting them wrap around a HOT roller and get cooked and wrinkled. The way it works:
An envelope is inserted in the front and goes straight out the back of the printer through an exit door, completely avoiding the hot roll-through mechanism.
Take a look. On the back of the machine is a large pass through exit door. Just snap it open. You will see one blue lever on each side of the opening. Snap them both straight down to the . . .ta da. . ."envelope icons".
Put three envelopes in the front and they will print straight out the back, perfect and wrinkle free. After printing your envelopes, snap the blue levers back up and shut the door. Takes about five seconds to open the door and snap down the blue levers down/up.
Happy envelope printing.
-Eric
Jul 11, 2009 | Brother MFC-9840CDW Laser Printer
Envelope Feeder for Dell 5210N wrinkles envelopes
Hey,
This may be a bit late, but I just posted a solution to the Dell 5210 envelope problem here
http://www.laserprintercenter.com/laser-printer-news/2010/10/envelope-printing-and-laser-printers/
Basically, it has to do with the envelope enhance feature...
Oct 13, 2008 | Dell 5210n Laser Printer
Printing Address on Envelops
E-mailing you the info I am finding
Apr 04, 2008 | Xerox Phaser 7300DN Laser Printer
IBM Infoprint 1332 Laser Printer Logo
48 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
