Question about Uniden TCX905 Cordless Accessory Handset and Charger Phone
I have a tcx905s handset that will not register to my tru9496 base. Uniden claimed that 905s units will work with this base. However, they said that refurbished units will not work. Is this true?
Not sure about the refurbish issue...but have you tried to de-register the handset by holding down the end key and the # key, then placing on the main base unit to register with your system.
Posted on Sep 03, 2010
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
Oct 04, 2013 | Uniden Lands Phones
How do i add another handset "uniden 6.0" phone to an existing phone and base unit of the same brand.I need the step-by-step instructions please. thank you!
First make to get a compatible handset.
For the Uniden D1660-2, the compatible handsets are DCX160 and DWX337. Make sure that you have not exceeded the number of handsets that the phone can support. The D1660-2 can support 12 handsets unless you use any DWX337 handsets. Then the limit is 6. (If you have more handsets, you will need to deregister some of them first.) Then allow the handset to charge. If the handset is reading "not registered", then place it into the base unit. You should see "Handset Registering" for about 30 seconds; then it will read Registration Complete. The manual for the Uniden D1660-2 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1660-2om.pdf . This is the most common Registration for Uniden phones; there are a few exceptions (depending on the base or the replacement handset). Check the appropriate manual (see below to find the manuals).
For the DECT4096, press Menu on the base and then navigate to Handset Register. When you see Handset Registering on the base display, press and hold # on the handset to be registered until you see Handset Registering. (It takes about 2 seconds.) After the display changes to Handset Registered, check for dial tone.
On a few Uniden phones, there is a Page/Handst Register button on the base. On those you navigate through the Handset menu to Handset Register (Menu > Handset menu > Handset Registration). Then press and hold the Page button until you hear a beep. Then wait for the registration to be completed.
Most Uniden manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl . Select your type of Uniden phone and scroll through the list to your model or use the search box to directly search for your phone and the manual.
I hope this helps.
Jul 26, 2011 | Uniden D16602 Twin Cordless Phone
I have extra handsets from a TRU9480 phone and
have it checked by ur near by customer service and ask them to connect
Aug 30, 2009 | Uniden TRU9496 Corded / Cordless Phone
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
We had Uniden model TRU8866. Handset #2 was damaged and lost. We purchased a new phone through Uniden. It says Set #4 on it. We would like it to say #2 The new phone is a Power max5.8ghz.
In order to re-register handsets with TRU8866 base unit, you have to reset the base unit, de-register the handsets, and then re-register the handsets. To reset the base station, disconnect the power from the base and then press and hold the CID, Intercom, and Exit keys while you connect the power. Wait for the beep, and let go of the keys. Now re-register the handsets - the first one will become #1, and so on.
May 16, 2009 | Uniden Lands Phones
Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Aug 07, 2008 | Uniden TCX905 Cordless Accessory Handset...
Adding a new handset
You need to register the new handset with the base.
In Global settings De-register the new handset then place it on the main base unit connected. It should then register.
Jun 30, 2008 | Uniden TRU8885 Cordless Phone
Tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Mar 10, 2008 | Uniden TCX905 Cordless Accessory Handset...
Uniden handset TCX905 with base unit TRU8866-if compatible?
I just successfully registered 4 TCX905s with my TRU8865 base - it's documented in the TCX905 manual.
Be sure the handset you want to register is fully charged.
Remove the handset you want to register from its charger.
Now unplug the AC for the main base, hold down the 'find handset' key on the base and plug the AC in again, when it beeps, you can let go of that button.
Hold down the '#' on the handset you want to register, it will show 'Registering Handset...' and when it beeps, it's done - registered, you're good to go :)
Oct 11, 2007 | Uniden TCX905 Cordless Expansion Handset
Uniden TCX905 Cordless Accessory Handset and Charger Phone Logo
240 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
