Lost the screen resolution 1600X900. How do I get it back? Its a Dell S2009W. Worked fine until I had computer problems. Now all my photo people are fat.
Windows 7 - Start, Control panel, Adjust screen resolution, Detect, apply OK.
I have a Dell ST2010 and have to do this every powerup as it forgets...
If anyone knows how to fix that I'd be grateful...
Posted on Mar 20, 2010
  • 2,841 Answers
You can set the resolution on the computer. Right click an empty space on the desktop and then click Properties. In the properties dialog box click Settings. Now use the slider to change the resolution. Click apply.
Posted on Sep 25, 2009
My Samsung Syncmaster 2033SN LCD Display flashes after every 5 seconds
Get in touch with Samsung support: http://www.samsung.com/us/support/contact
May 19, 2015 | Samsung Computers & Internet
Can't get 1600x900 Resolution
Your graphics card may not be able to display this screen resolution.
Open Control Panel - Display - Settings tab and move the slider on the Screen resolution - to get as close to 1800 X 900 then click apply.
Mar 21, 2012 | Dell Dimension 5100 (D51L1) PC Desktop
Change the resolution on my Samsung B2030 LCD Monitor
1600X900 is a higher resolution than that of 1280X1024. Therefore 1600X900 is a better resolution. If you would like to run at the lower resolution simply right click your desktop screen and click properties. Then on the settings tab use the slider bar to adjust the resolution. Lower to the left and higher to the right. If the desired resolution is unavailable then you could try downloading and installing the latest drivers for your graphics card installed in your computer.
Your card will either be AMD/ATI Radeon or Nvidia. You will need the model number of the graphics card, the latest drivers may increase resolution support for your card.
Also look on the bottom right hand side of your screen for an Nvidia Control Panel logo in green. Right click it and select the option to "change screen resolution" This may provide you with additional resolution options.
Take care!
damnor01
Nov 02, 2011 | Samsung B2030 LCD Monitor
Elongated print and pictures
It's most likely your desktop resolution that does not match the ratio of your screen.
The E193FP is a regular 19", which means you should be using resolutions such as the following:
1024x768 1280x1024
These have a ratio of 4:3 (if you divide the first number by the second you should get 1.33333).
If you are using a widescreen resolution, such as 1600x900 then you will experience distortion.
Apr 06, 2010 | Dell E193FP 19" LCD Monitor
Screen monitor images on the righ side is not showig.
Hi afcarrillo,
This could be a simple resolution problem. By that I mean that the resolution is set too low, therefore putting things off screen. Here's how you change the resolution:
Windows XP
Right click the Desktop and select Properties. Click the tab all the way on the right that says settings, and drag the slider to your native resolution of 1600x900
Windows Vista
Click Start, Control Panel, Appearance and Personalization, Personalization, Display Settings and drag the slider to 1600x900
Windows 7
Simply right click the desktop, select Screen resolution and pick 1600x900
If you do not have a resolution problem, then it's most likely the monitor itself. Most often times you can fix it one of two ways:
1. Some monitors have a button that says "Auto" which will auto adjust your monitor. If you have one, try it.
2. If that didn't work or you don't have one, go through the monitor's OSD (on screen display) and work through the settings so that you can manually adjust it and set it to your taste.
Hope this helps :)
Nov 29, 2009 | Acer Computers & Internet
16:9 resolution problem
You don't specify your machine type, or the operating system, but let's assume a desktop computer and Windows XP...
Was the monitor recognized properly by the video driver?
Go to Display Properties, settings, advanced, monitor and see if Plug and Play monitor is installed. All modern graphics cards talk to the monitor to discover it's capabilities and should adjust the available resolutions so that the monitor's native resolution is available for choosing.
If some other monitor is listed there, change it to Plug and Play monitor. If still having troubles, you can do two things:
- update the video driver for your graphics card
- find the monitor's .inf file (it should be on a CD that comes with the monitor, or can be downloaded from DELL site), and install this instead of the Plug and Play monitor or whatever you have in your monitor setup (as above, go to monitor - properties - update driver).
Nov 08, 2009 | Dell Computers & Internet
I have a dell with windows vista. the monitor is 20 or 21 inches wide screen. I recently had a friend try to install windows xp but at the last attempt he tried to reformat my computer & install it xp...
You can adjust the screen resolution to increase the size of the image to fill the screen.
Go to the Control Panel - Display - Settings and adjust the screen resolution to 1280 X 1200 pixels. If this still doesn't fill the screen then increase it further say 1600 X 1200 pixels even higher if necessary.
Aug 19, 2009 | Dell Computers & Internet
I bought a 1600x900 monitor and now pictures are distorted
Your screen's ratio is oriented to playing wide screen formatted movies. Set your screen resolution to a ratio that's more or less 2 to 1 and you'll have a more realistic depiction of people on photos.
Aug 16, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Computers & Internet Logo
1,689 people viewed this question
David Payne
David Payne
