Question about Teac Floppy Drive 235HF Internal Floppy Drive
Ican't get a self installed floppy disk drive to work with Vista.
I've tried to install 3 seperate 3-1/2" floppy disk drives but can't get them to work.
After I installed the first one, I got the message stating "New Hardware Found"."Floppy Disk Drive" followed by "New hardware is installed and ready to use".
When I click on the "Computer" tab on my start menu, it shows the Hard disk partitioned drives (C: and D:), and the DVD RW Drive (E:) and it also shows that it recognized the new Floppy Disk Drive (A:).
When I insert a disk, it tells me "You need to format disk in drive A: before you can use it." even though it's brand new pre-formatted-IBM compatible disk labeled Maxell MF 2HD.Then it asks "Do you want to format it?" then it offers 2 choices, "Format disk" or "Cancel", When I click on "Format Disk", a new small window pops up saying "Windows cannot format this type of disk. Insert a different disk and try again." Which I have done over and over with all different types of disks (HD, DSDD, 2HD,etc., but get same result.
I've made sure that the disks are not read only and I've tried two different wire sets from the disk drive to the mother board and as I said earlier 3 seperate floppy disk drives. I've made sure the wiring ribbon has the red/pink lead running from pin 1 on the floppy drive to pin 1 on the mother board plug
I've gone into the "Device Manager" section of my computer and uninstalled the floppy disk drive and the "floppy disk controller" each time before I tried a new drive or configuration.
I purchased 2 refurbished drives from a reputable local store and the first was from my old Presario, so I don't think that all 3 could be defective.
My computer is a 3 months new HP/Compaq Presario Model SR5710Y. P/N NC696AA-ABA.With Windows Vista Home Premium.
Please Help.
  • 109 Answers
Reverse the data ribbon direction in floppy side (data cables pink color side should be plugged opposite to power cables color side)
Posted on Sep 26, 2009
Running windowsXP pro sp3 ids TEAC floppy in CP sys but no A drive in explorer
I too am having a problem with the Sabrent floppy drive.
I'm running a windows 7, 64bit system, everything installed ok,
but I kept getting a "install disk" message every time I tried to
access the drive. (I did have a disk installed.)
Any thoughts?
Thanks
Feb 21, 2012 | Sabrent External Floppy Drive
Just bought a teac fd-05pub usb portable diskette drive. i have a dell computer with windows vista. when i pluged it in the device was installed, however the power light comes on for a few seconds then...
The below is on the basis that the drive is visible in "Computer"...
This can be tow thing, one the drive is not receiving enough power from your USB port, try unplugging any addtional USB devices connected to the PC, if this doesn't work try a powered USB hub. Second the floppy disk is faulty or the drive itself is faulty.
Hope this helps, let me know how it goes.
Thanks
Jul 11, 2011 | Teac FD-05PUB External Floppy Drive
I am now unable to access a floppy disk that I had been able to access for years. I now get an error message that tells me the disk has no ID address mark. How do I fix this?
Try changing the stting switch on the disk. I think it is for formatting or something like that. Try moving it to the opposite direction and then put it in your computer again ;) Good Luck
Nov 12, 2009 | Teac Floppy Drive 235HF Internal Floppy...
I want to reinstall my Y computer but the restore CD does not seem to work. So i tried a new XP cd, but that too could not work as it does not see the SATA hard disk installed. The Bios on the Tecra M9...
Hi, your Windows XP install CD doesn't have SATA drivers for the hard drive included, so it's not able to address your hard drive. You can't disable SATA in the BIOS to make it work since your hard drive is still SATA. You'll need to get a 3.5" floppy disk and drive if your laptop doesn't have one. They make external 3.5" USB floppy drives that will work.
1. download the SATA drivers for your laptop (iastor.sys and inf)
2. copy the drivers to your floppy disk (about 6-7 files)
3. plug the floppy drive into your laptop
4. boot to the Windows XP CD
5. as soon as the installation starts, it asks you to "Press F6 to specify RAID or controller drivers" - Press F6 now
6. When setup asks for it, point it to the floppy drive
7. Installation will continue and find your SATA hard drive
Ta-da! Rock on with your bad self.
May 18, 2009 | Toshiba Tecra M9-S5517X PC Notebook
Windows xp setup does not detect hard drive
You need to use the RAID/ATA floppy disk that was provided with your motherboard. It was supplied either on the cd or on seperate floppies.
When you have the disk in the floppy drive you press F6 when it asks at the very beginning of loading files in the windows setup.
When the setup asks load the RAID/ATA drivers and when you go to install your hard disk will be detected. You will have to get a floppy drive and plug it up if you don't already have one. There is a way to build a windows setup cd which includes the ata/raid drivers but it's often easier to just get a floppy drive.
May 08, 2009 | Microsoft Office Professional 2007 Full...
Why not win xp load in compaq presario cq40
The notebook is preinstalled with a SATA hard drive which needs seperate drivers to be installed inorder to get the hard drive detected. The drivers for the SATA can be installed only by using a floppy drive. As the notebook does not have a floppy drive installed, we can either try disabling the SATA native support in BIOS or install the drivers with the help of a USB floppy drive.
Here is the link for SATA driver:
http://downloadmirror.intel.com/16759/eng/f6flpy32_85.zip
Check the following document to install SATA dirver without using the floppy drive:
http://www.scribd.com/doc/4864999/sata
Jan 22, 2009 | Microsoft Windows Vista Home Premium with...
Have a HP DV9500 laptop and I am trying to remove Windows Vista and install windows xp. When I get to the blue screen to start the install it says it can not locate my hard drive and the only option...
Hi.
I will explain you the issue.
If the USB floppy drive is not available, you have the alternative steps to install the SATA driver.
Please refer the following link to install SATA driver without the USB floppy drive:
or
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/sata.pdf
If you have the Floppy drive you can install the SATA driver.
Just follow the below procedure:
Download the SATA driver:
ftp://ftp.hp.com/pub/softpaq/sp37001-37500/sp37005.exe
1. Download the driver to a directory on your hard drive.
2. Execute the downloaded file and follow the on-screen instructions. A diskette containing the driver is created, and the driver files are also made available at c:\swsetup\sp37005. If you choose to cancel diskette creation, you will need to copy the driver files to the chosen media.
Installation Instructions:
NOTE: A USB diskette (floppy) drive is required to use this driver. If an external USB diskette drive is used, ensure that it is plugged into the system before starting Step 1.
1. Insert the operating system CD, and Power On the notebook to boot
from the CD.
2. At the very beginning of the operating system installation, the following prompt is displayed at the bottom of the screen:
"Press F6 if you need to install a SCSI or RAID driver...."
When the prompt is displayed, press F6.
3. Later in the operating system installation, you are notified that a mass storage device could not be detected. When this notification occurs, press S (S=Specify Additional Device).
4. When prompted, insert the diskette that was created from the SoftPaq file, and then press Enter.
5. Select "Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)" and press Enter.
NOTE: At this point, the following prompt MAY be displayed, depending on the version of your operating system CD. If the prompt is displayed, press Enter to use the default Windows driver and continue, if it is not displayed, continue with Step 6. The prompt reads as follows:
Windows already has a driver that you can use for
"Intel 82801HEM/HBM SATA AHCI Controller (Mobile ICH8M-E/M)".
Unless the device manufacturer prefers that you use the driver on the floppy disk, you should use the driver in Windows.
S=use the driver on floppy ENTER=use the default Windows driver
6. Continue with the operating system installation, as prompted.
NOTE: If a problem is encountered when using the external USB floppy drive, refer to Microsoft Knowledge Base Article 916196: "A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process."
Sep 09, 2008 | Computers & Internet
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
TEAC floppy drive won't work with Vista Home Premium
Have you tried WWW.Driverguide.com - Generally I have found all the drivers I need there. Else try the manufacturer's web site at www.teac.com
Aug 15, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Teac Floppy Drive 235HF Internal Floppy Drive Logo
307 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
