Question about Maytag Neptune MAH5500B Front Load Washer
Washer holdes water in tub. if i don't wash for a few day'when i do the close smell.
    Genius:
  • Maytag Master
  • 1,460 Answers
Check you pump is pumping properly. Clean filter in need be..
Posted on Oct 03, 2009
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
Do you need to keep the door open when not being used. i know some models require that.
There's no special requirement that you need to keep the door open. But, If you keep it closed after your done washing, some water is usually left behind and if you don't wash for a few days it could make the first few loads have a certain musty odor. I always leave the door open for a few days to dry out the insides then close the door and I haven't noticed the musty smell. Good luck.
Apr 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
There is water left under the tub after the wash is over. When I move the tub I can hear the water sloshing. How can I get rid of the water. It makes my towels smell like mildew.
If it is draining down and spinning the clothes dry then all of the water is draining out. There is only about a 1/2 in space under the tub. There is a balance ring around the top of the tube that holds water. That may be the sound you are hearing? Try washing a load without anything in it on hot and use a box of baking soda. See if that will help with the smell. My washer leaves a mildew smell sometimes. I started running an extra rinse cycle on it. And that helped. I think it was my water.
May 28, 2010 | General Electric WCSR2090D Top Load Washer
Water left in tub at end of load smells bad you don"t see water but can hear at a turn of the tub by hand.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
Neptune MAH 4000AWW works good but some whater is left
Apr 11, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Washer smells like stagnant water
Open the door and let it air dry between washes doesnt have to be wide open but not latched either also run a hot wash with no clothes and 1.5 cups of bleach (pour bleach in the tub after it fills not in the bleach disp)
Sep 28, 2007 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Odor when starting cycle
Check your water softener(If so equipped). This can cause foul odors in the water supply if not properly balanced or maintained. Good luck!
Sep 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
