Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP 7310 OFFICEJET, ERROR MESSAGE
EVERYTIME I CHANGE THE COLOR CARTRIDGE ON THE HP 7310 OFFICEJET ALL IN ONE AN ERROR COMES UP TELLING ME TO REMOVE AND CHECK THE COLOR CARTRIDGE. I HAVE DONE EVERYTING THAT HP RECOMMENDS AND THE PROBLEM STILL EXISTS. CAN ANYONE HELP ME?
7310 All In One - running windows 7 64k OS problem: error blinking msg: error remove and check color cartridge. This is a fairly new cartridge, I have removed color cartridge rubbed it on a damp cloth -...
you need to change it, maybe you damaged it while trying to get it working. the clearly shows a faulty cartridge remember it can be faulty even as new or from the box
Oct 27, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Remove and Check Color Cartridge keeps appearing. I have changed color cartridge and message still appears.
is a non-original or defect color cartridge. ask for change cartridge to original. If still continues, ask for a new printer the cartridge bruned your printer board.
Jul 15, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Error message HP Officejet 7310 "remove and check cartridge on right. Removed cartridge, checked it (nothing), installed it back - still same message. Installed new original HP cartridge - still same...
Can you find a friend with a similar HP printer, i.e., one that accepts the same model-number of ink-cartridge? If the cartridge gives the same error-message in the other printer, it's time to responsibly recycle your "dead" cartridge, and give the brand-new cartridge to your friend, for his/her usage.
Nov 25, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I'm told by the HP Officejet J4540 that the color cartiridge has a problem. It is new. I've done all I know to do. It tells me to refer to the device documentatio. Got any ideas? THANKS!! Everytime I try...
IS IT REFILLED IF NOT TRY TO ALIGN THE CARTRIDGE
REMOVE THE CABLE FROM THE BACK
PRESS # AND 6 AND BY KEEPING THEM PRESSED INSERT THE POWER CABLE
ALIGN THEN
Sep 18, 2009 | Office Equipment & Supplies
Changed ink cartridge now it won't work
Try removing the black and see if the error is still there. If it goes away the black is bad, if it stays you got a defective new color cartridge.
Jul 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My HP Officejet 7410 xi is showing an error message that states "Remove and check color cartridge". I have tried replacing the old cartridge with two separate new ones and I still get the error message.
Apparently, there is a known problem with this printer series (7310 / 7410). When you replace the cartridge, there is a metal wire that keeps the cartridge in place. This wire comes away from the wall as you slide the cartridge in and makes a hole in the ribbon cable.
Unfortunately, there is not much that you can do, other than to contact HP. Hopefully, your printer is still under warranty.
Jun 15, 2009 | HP OfficeJet 7410 All-In-One InkJet...
I changed my color cartridge #97 on my HP officejet 7310
Remove the color cartridge. Make sure the contacts in the print carriage are clean. Chek to ensure the contacts on the cartridge are clean. Reinsert cartridge.
Mar 20, 2009 | HP OfficeJet 7310 All-In-One InkJet...
the internal circuit of the printer which connects the colour cartridge is gone faulty so this error.that internal circuit needs replaCEMENT.thanks
Dec 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
383 people viewed this question
Seeker5211
Seeker5211
