Question about Kenmore 22422 Top Load Washer
Water spillin out bottom
How do I get inside to see where leak is
    Sergeant:
    Champion:
  • 289 Answers
Posted on Dec 26, 2009
  • 5,911 Answers
You will need to remove the exterior casing of the washer to access the interior and determine where the leak may be coming from. Follow these steps:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
If the leak is coming from the front of the washer, most commonly this is caused by a leaking drain pump. The pump is located in the front directly below the wash tub. The pump is not serviceable and must be replaced if it is damaged.
Some other items to consider:
1. Check your fill hoses to ensure they are tight and not leaking. What can often appear as a washer problem, may be a loose hose.
2. With the washer case removed, check the area UNDER the wash tub. If the leak is coming from the center above the transmission, the tub seal may be leaking.
3. Inspect the wash tub for any cracks. If the tub is cracked and its not serious, you may be able to get by with some marine epoxy to reseal it. If the crack is significant, a new tub will be required.
4. Check the air dome on the lower right hand side of the wash tub. This is a small plastic air hose that runs from the wash tub all the way to the pressure switch. If this hose comes loose, the washer will start to leak as it fills. Simply reattach if it comes loose.
NOTE: It is important to remove the washer case in matters like this so that you can get a full view of everything to determine the source of the leak.
If you need an illustration of your washer and components, searspartsdirect.com, appliancepartspros.com, or pcappliancerepair.com usually has some excellent exploded view diagrams that you can refer to.
If you determine the pump is damaged and needs replaced, the following link explains how:
http://www.fixya.com/support/r397092-replacing_water_pump
Prices can vary between these sites so shop around for the best deal. NOTE: Use the part number from the Sears site and use it to "Search by Part Number" on the other sites. It makes it easier to find as some sites may not have your model number listed, but will still carry the part.
To reinstall the washer casing, follow these steps to ensure you get the case correctly placed and secure on the frame:
1. With the lid of the washer open, grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make sure the back of the washer fits into the washer casing on each side by leaning over the front of the washer and grasping the back panel and pull towards you. Reinsert the brass clips by placing the clips into the slot on the back of the washer first, and then forcefully push then down into the opening on top of the washer.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
Read through everything thoroughly before beginning any repairs. If you have any questions, or require additional assistance, please let me know. I hope this information is helpful.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions will apply.
Posted on Sep 25, 2009
Water leaking near the fire wall
Sounds a corroded heater core, leaking inside firewall. It is possible if the leak is not to bad try some stop leak. from the below link. Thank you Atheek, please leave feedback. Advance Auto Parts Car Engine Batteries Brakes Replacement Performance...
Jul 12, 2016 | 2008 Ford Territory 4.0
Where is the heater control valve on a 2008 dodge charger? If its bad could it leak on the drivers side inside?
You don't have one. And no it wouldn't leak on the inside. Two possibilities for the leak. Heater core is leaking or the drain is plugged up.
Feb 06, 2016 | Dodge Cars & Trucks
I HAVE A 2002 BMW 525I I AM ALWAYS RUNNING LOW ON ANTIFREEZE , AND CAN NOT FIND OUT WHERE IT IS LEAKING FROM. HELP
Hi
i do not know if you have allready done this, but check the carpet under the dash press hard on it and see if it is wet, sometimes the small radiator in the heater ( called the matrix ) leaks due to corrosion, and you cannot see a leak from the outside as it is leaking inside the vehicle, also sometimes you will smell a sweet smell inside the vehicle if there is allot of antifreeze inside but not all the time.
Hope this helps.
Jul 31, 2014 | BMW 525 Cars & Trucks
Why is washing machine leaking orangish liquid inside washing machine after a load of wash?
Am I understanding you correctly? Is orange liquid leaking on the floor at the base of your washer or is it leaking in the inside of the washer?
If it's leaking on the inside that sounds like rust from maybe the supply hose mesh gaskets. Should be stainless mesh but stranger things have happened.
Jun 07, 2014 | Kenmore 24032\24036 Top Load Washer
Strong raw fuell smell inside the car intermitantly
Usually, what you smell inside the car is coming thru the vent from the engine compartment.
So it could be a leak around the engine or the vapor canister. Its possible the canister gets overloaded from time to time when the computer vents the gas tank to the canister. A very small leak can be a very strong smell inside the car.
Apr 29, 2013 | 2005 Dodge Neon
Water was leaking inside on passengers side, now
HVAC drain tube was blocked and condensation could not drain to the outside of the vehicle
as a result the water pooled inside the HVAC case leaking on the inside and killing your blower motor and probably blower motor resistor
clear the drain, replace the blower and resistor and you'll be back in business
Jun 08, 2010 | 2001 Oldsmobile Aurora
Radiator coolant fumes inside cabin
There is a chance you may have an engine bay coolant leak and the fumes are being drawn in through the heater ductwork so verify that first.
But....
Coolant fumes inside usually come from a leaking heater core. The heater core is like a small radiator inside your vehicle that gives off heat.
Problems like this arise from coolant that has not been flushed and creates an electrolysis that eats away at the material causing a leak.
This is not a job for a do it yourself guy(or girl). A pro could easily spend 5 to 7 hours changing this one.
Make sure whoever does this repair flushes the system.
Nov 04, 2009 | 2000 Ford Expedition
My GE refrigerator is leaking cold air at the wires coming out from the back of the refrigerator. The frame around this hole is cold. Is there a leak inside the refrigerator? What can I do to fix this...
refrigerant could leak inside the unit, it could smell bad if the compressor had a burnout
refrigerant carries oil troughout the system and back to the compressor
if the compressor had a burnout, the oil would turn acidic creating an odor if there is a leak
personally I would check what's inside, open a box of baking soda and see if this eliminates the odor
if your fridge quits cooling, you've got a leak
Sep 17, 2009 | Refrigerators
Code thrown for top end problem
Lets get it WRIGHTis the oil on the out side or on the inside of the plug,, if inside then thats why No3 cylinder isent working and sounds like you have a ring or valve seal gone,
If you have the oil leak on the out side and not on the inside then your leak could be from the rocker cover gasket leaking If plug oiled up inside then fit new one and try it again. How many KM has it done
May 19, 2009 | 1997 Toyota RAV4
Kenmore 22422 Top Load Washer Logo
136 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
