Question about Freezers
Frigidaire side by side works fine for a couple of days then it starts to get warm, milk gets warm n ice starts melting. i unplug for a day n i when i plug it back in tll work for a couple of days again.... then repeat.. any ideas?
  • 4,070 Answers
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
If you need help finding your model number see here> http://www.appliancepartspros.com/modelnumber_locator.aspx
To locate your timer, motherboard, control or adaptive defrost control , enter your model number and search for the part or post back on Fixya.
http://www.searspartsdirect.com/partsdirect/index.action?psid=26129238&sid=PSx20071217x00001a
Posted on Sep 25, 2009
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
Freezer seems to be stuck in defrost mode
Sounds like the pat test fried the pcb. They use too high a voltage to test the appliance wiring and it doesn't do printed boards much good!
May 11, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
20.3 cu. ft. Upright Freezer GLFU2067F: We have an upright frigidaire 20 cu feet that is a...
Sounds like frost bulidup from door being left open warm air gets in making frost and ice. Need to turn off for 24hrs or so to let all the ice melt compleatey then turn back on keep door closed run for 24hrs check Temp. shoud be about 0 to -5 Deg. if good start using.
May 17, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
My freezer has ice building up on the bottom
Defrost freezer, and make sure the door close well each time
Mar 07, 2010 | Frigidaire Freezers
Ice accumulation at bottom of freezer
Hi, Remove the rear inside panel of the freezer and locate the drain hole under the evaporator coils.
Use a hair dryer and melt the ice. Make sure and get the ice out of the drain hole as well.
After the ice is removed, be sure and flush the drain hole with hot water. A baisting surenge works great for the flush.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 01, 2009 | Freezers
Whirlpool conquest fridge; freezer isn't working
https://www.repairclinic.com/RepairHelp/Refrigerator-Repair-Help
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Oct 03, 2017 | Whirlpool Freezers
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezers Logo
166 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
