Remove the plastic cover on top of the engine, you will see 4 small like square boxes set in the center of the motor, thats your coil which set on top of the spark plugs. remove that coil and you will see the plugs. this car does not have any plug wires, that what probably see a bit confusing...hope that help
If it has coil packs they are under them in the head.
Car cranks, has spark but will not ?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
How to Perform a Basic Engine Tune Up-Spark Plug and Wire
Change
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up_01.html
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How does the spark plug wire go on the distributor cap in
1991 Mitsubishi Mighty?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
No spark on 2008 Chevy Avalanche?
http://schematicsdiagram.blogspot.in/2012/04/no-spark-on-2008-chevy-avalanche.html
1985 Pontiac sunbird?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wire-go-on.html
Ford Plug Wires Not Coming out?
http://whoisbyme.blogspot.in/2012/06/ford-plug-wires-not-coming-out.html
Ford explorer has no spark?
http://schematicsdiagram.blogspot.com/2011/12/ford-explorer-has-no-spark.html
Chevy impala spark plug firing order diagrams?
http://technoanswers.blogspot.in/2012/02/chevy-impala-spark-plug-firing-order.html
How to gap spark plug on Chevy Impala?
http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for chevy impala?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
Chevy s-10 blazer 4.3l Spark Plug Firing Order?
http://howtobyme.blogspot.com/2011/12/chevy-s-10-blazer-43l-spark-plug-firing.html
1982 dodge rampage Spark plugs Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/1982-dodge-rampage-spark-plug-firing.html
2006 Suzuki Forenza Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
1983 Ford Ranger Spark plug firing order?
http://schematicsdiagram.blogspot.com/2011/12/1983-ford-ranger-spark-plug-firing.html
Firing Order for 1991 Lexus ES 250?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1991-lexus-es-250.html
Firing order for 1992 Chevrolet 5.0 engine?
http://schematicsdiagram.blogspot.com/2011/12/firing-order-for-1992-chevrolet-50.html
How to identify number one spark plug on the distributor
cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How to remove rear spark plugs on 1991 Buick Regal?
http://howtobyme.blogspot.in/2012/02/how-to-remove-rear-spark-plugs-on-1991.html
These details will help.
Thanks.
For
spark plug problem, click the help links provided below: ---
Car
has no spark?
Plugs?
Car
cranks, has spark but will not start?
How to gap spark plug ?
Spark plug Replacing for?
spark plug on the distributor cap?
wire go on the distributor cap?
Diagram?
This will help.
Thanks.
My 2006 chevy colbolt has eithier a broken or clogged catailac converter. Is there a recall on this?
