Music CD does not play correctly
All my music CD's play well on my CD player except for one disc (original). This disc plays well on my computer and in my vehicle. When played on my player, the music comes out fine from 1 speaker, but the lyrics coming out of the other speaker has a metallic sound although I can understand the words. My player is almost 12 years old. Can you help?
  • 130 Answers
SOURCE: intermitent audio
I had that happen before, one problem was my car had bad shocks or i hit a pothole in the road. The second time i had the volume up so loud the bass wass thumping the floor and it skips the CD. My question is, how lowd is the thign turned up? :P Some CD players load the data into a memory and then it plays from the memory till it needs more info. It maybe that the unit is not stable or the CD is not balanced right so it cant read the info at a consistant speed. The music maybe playing faster then it can read because of the vibrations. Is the disk clean? i know this may sound dumb but it is easy to over look. If the surface of the data side is so scratched up it may have problems reading the data quickly enough. Sometimes the coating can fall of the disk if you hold it in the light you can sometimes see spots threw the disk where the foil has been chipped off. The CD player could have a focus problem also, it could be damaged in shipping or have been dropped and it cant focus properly on the data. Do you have any other disks to try? a new one? one you never play?
Posted on Apr 04, 2006
Vivekt1000
  • 35 Answers
SOURCE: CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Posted on Aug 14, 2007
tvsandstuff
  • 24 Answers
SOURCE: `Sony CD player won't play burned discs
Many of the older Car CD Players will not play CD-R's or they may with static sounds behind the music. What you need to do is try using a different brand of cd-r disc. If this doesn't work then it means that you may need to replace the CD player because the model that you have may not be decoded in order to play CD-R, CD-RW, play MP3's or anything of that such.
Get back to me if this doesn't work I'll help you square it away.
Posted on Nov 20, 2007
zzedly
  • 300 Answers
SOURCE: music won't play through speakers
Please provide more detail of your system's setup and connections. Thanks!
Posted on Mar 05, 2008
StuartB
  • 807 Answers
SOURCE: New laserunit won't work
You seem confident enought to take it apart, have you tried cleaning the runners that the laser runs backward and forward on.
Some times they collect dirt/dust and the laser can't move smoothly so it jerks and skips.
Posted on Mar 14, 2008
I want to play a music CD on my LG player
the LG DVD player is compatible with music disks of both types MP3 Music disks and normal CDs just press play on your DVD remote
Mar 14, 2017 | LG Televison & Video
I burned a disc of music but doesn't play on my Panasonic CD Stereo System.
Some players are like that! You need to experiment with different makes and speed settings when recording!
Nov 11, 2014 | Audio Players & Recorders
Hello i have a Philips cdr 870. With every blank CD inserted, the display shows NO AUDIO. Pre recorded CDs play OK. Unable to record. I have recently aquired this machine and this is the first time I have...
You are probably inserting blank computer discs, eg 650 or 700mb rather than blank music CD-R or CD RW`s which this machine is designed to work with. The correct discs are labelled "music audio" or 80 minutes. You can only use these types of discs. Why? When these recorders first came out, it was a way of battling piracey in copying discs. I believe there is a "hack" to enable this player to use blank computer discs.
SMA
Jan 13, 2010 | Philips CDR870 CD Recorder
Casette to disc
to convert music from cassett to disk u need to connect the cassett player headphone jack / line out jack to ur PC/laptop mike / line in jack....then play the music and record it in a software(Nero Sound editor etc)
then once that's done save it as mp3 file on to ut PC and trf it to ur cd/disk....u can just copy it as mp3 or create a music cd using Nero...from the mp3 file
the difference is if u just copy the mp3 on to the cd then only a mp3 player/mp3 music system deck can play it... if it's created as a music cd then any cd player can play it....just like any music cd that u buy in the mkt...
a 700 mb disk can hold almost 7 to 10 hrs of music in mp3 format....
but a music disk can hold only 80 mins of music
Jan 03, 2010 | Dell (3996D) Sound Card
I want to use cd-rw discs. what do i need to do?
rewritables discs are basically the same as regular discs except that they allow to be erased and rewritten over sevral times you shouldnt have to do anything different
Aug 29, 2009 | Compaq Presario 5000 PC Desktop
Disney Princess CD Player will not play music
try cleaning the laser with a q-tip if the laser is dirty from finger prints or dust it won't be able to read the disc therefore won't play. Clean laser and if that doesn't work then the child may have damaged the player in a fashion that would be better to get him/her a new one.
Jan 08, 2009 | Disney Princess Portable CD Player
The DVD/CD writer on my Acer laptop is not correctly writing discs. It is writing music files to the disc but it does not play on CD players - it is like the music is on it is as data files as when the...
When you want to create an audio cd, you select audio or mp3 in case you CD player also play mp3. Do not copy or write music file to your cd as data files.
Dec 22, 2008 | Computers & Internet
My dual xdvd700 wont play cd-r discs with music videos on them.
dual xdvd700 is a very picky device in order for you to play videos on a cd-r disc...you need need a burning software that have video burning capacity...don't just burn video as data copy/backup b/c dvd player won't recognize it. hope this help...
So it's base on how you burn your disc...NO data backup/copy ...use Video Burning instead
Dec 09, 2008 | Car Audio & Video
76 people viewed this question
 Grubhead
Grubhead
