Question about Nikon D60 Digital Camera with 18-55mm lens
Error Message When I take a photo with Nikon D60 it's as though the shutter gets stuck and it gives an error message on the screen (Error! Press shutter release button again.) The top half of the photos are completely black. Also, there have been a couple of times during this problem that the shutter clicks and when looking through the viewfinder everything appears tinted. Weird, I know! Any ideas or suggestions?
  • 854 Answers
Try to take off the battery and reset the camera. You can also try to remove the lens and check the mirror opening..see if there is some thing stuck there. You can try to click the shutter while the lens is removed. If this procedure didn't work I suggest calling Nikon for further repairs.
Posted on Sep 25, 2009
Mi camera digital Nikon D 60 got a messaje: ERROR PRESS SHUTTER RELEASE BUTTON AGAIN Cant anyvary help me to fix it
It is nothing to lose to try this:
1. Remove the battery (the charged and good working battery),
2. Switch the power to ON position,
3. Press the shutter button for 5 seconds.
4. Switch the power to OFF position,
5. Insert the battery,
6. Switch the power to ON position,
7. Try to take a picture.
Please post the result here.
Mar 03, 2014 | Cameras
My D60 only when I use the flash I get an error message job nr
Job NR is usually associated with the camera's processing time during very slow shutters. If you wait long enough it will show you the image you've taken but because the shutter is very slow, the image will be blurry and unrecognizable. On manual mode or Shutter speed priority change your shutter speed to at least .125 of a second. That should fix the problem.
Apr 16, 2013 | Nikon D60 Digital Camera
My camera is showing this message: Error. Press shutter release button again. When I press it, nothing happens. Any ideas?
Hello, your camera have a bad sequence motor.You need to replace the SQ base plate unit. Contact Nikon service to solve.
Regards
Mar 02, 2011 | Nikon D60 Digital Camera
My Nikon D60 "Error. press shutter release button
Hi
The error is with the shutter release button and the unit has to be taken apart....Get it repaired by Nikon it is a common problem with these units.
Thanks for using FixYa
Have a Nice Day
Jan 25, 2011 | Nikon D60 Digital Camera
I have turned camera on and set up to take a photo and the shutter release button will not press in to take the photo. I used the camera yesterday and it worked fine!
Turn the camera on and look into the view finder while you try to press the shutter button. Check the information in the view finder to see whether you are getting an error message. If you see an error message in the view finder, remove the lens cap and proceed to take a photograph but, instead of pressing the shutter button this time, press the button near the top of the camera on the back which says "AF/AE. If the camera takes the photo it means you have somehow initiated the auto focus/auto exposure lock which the camera will not override when attempting to take a photo using the shutter button. When you use the AF/AE button, you override this system. To remedy this issue, when you get the error message try pressing the shutter button again. Also, remove the lens to see if the shutter inside has frozen in the "locked" position. If you find this to be the case you will need to contact Nikon Customer Support. The link for Nikon Support is below. The numbers are half-way down the page.
http://support.nikonusa.com/app/answers/detail/a_id/238
Oct 31, 2010 | Nikon D40x Digital Camera
Nikon D60 "Press shutter release button again". Camera "stuck" and not working.
Remove the battery and let the camera sit for a few minutes. Reinsert the battery and turn the camera on. If the error persists, then consult with a Nikon-authorized service representative.
Jan 15, 2010 | Nikon D60 Digital Camera
D60 won't turn on
Nikon told me to remove battery, remove SD card, remove lens and then hold the shutter button down for 30 seconds. If the Also sometimes the contact between the lens and body is not quite perfect and removing and replacing the lens hleps. If not it has a 1 year warranty, return to them with the exact error message (even if the problem is just intermittant) and they can usually find and fix the problem if the above things do not do the trick. Tonya
Aug 07, 2009 | Nikon D60 Digital Camera
Error message on display
you might have a stuck shutter. have it checked by nikon..
Jan 28, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon D60 Digital Camera with 18-55mm lens Logo
599 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
