Question about Echo Garden
Gas tank leaking on a echo chainsaw 452. Is there some seal needed
  • dontbother10
    dontbother10 May 11, 2010
    Are you certain it isnt a cracked or split fuel hose? That would be my guess unless you dorpped the saw from a tree or ran over it. A Parts Catalog (exploded parts list) can be found here:http://www.echo-usa.com/pdf/documentatio... Pages 4 & 24 show the fuel detail (this may not be you saw). I wish other manufacturers parts lists were this detailed. HTH Lou Please let us know what the exact problem is and if this was helpful.
    President:
  • 2,220 Answers
If it is split hoses post a clarification and we can provide some guidance there too.
Posted on Sep 25, 2009
I want to wire my superstar dm452 power echo mic to my realistic trc 465 am ssb and need to know what color goes to what pin?
its a 5 pin which all radshack radios are and they are all,99% anyway, wired the same . So take an old radshak mic apart at the plug and see how it is wired then experiment from there.
Apr 07, 2015 | Workman Publishing Workman DM-452-5 model...
ECHO 452VL NOT OILING CHAIN
Sounds like you have a blocked oil pump. With the flow regulator fully open and no cage filter on the end of the oil intake hose its probably pulled through dirt and blocked the pump.
Jul 27, 2013 | Echo 452vl 452 guide plates
Will not run
You need to make sure it is mechanicaly ok ( not scuffed the piston ) remove the muffler and check the condition of the piston skirt through the open exhaust port, any sign of damage and the machine will need to come apart.
May 08, 2013 | Echo Garden
I have a Echo 452 CS, exchanged piston and rings, engine starts and runs perfect only when I start cutting wood the engine dies immediatly. Air filter is clean, spark is OK. What could be the problem?
Fuel starvation, either due to a blockage in the fuel filter in the tank, or a split fuel hose, or dirt in the carb, it may also be due to the carb settings set too lean, when you re fitted the new piston are you sure the base gasket was correctly seated? and any pulse holes were not covered ( gasket correct orientation ).
Oct 05, 2012 | Echo 452 Chainsaw Piston Cylinder
Need a replacement fuel line for echo 452 vl chainsaw where can i fine on
You can find that fuel line at many places. Just go to any repair shop for small engines and they should be able to sell you the right one. Might take in the old fuel line just to be certain you have the right size.
Apr 04, 2011 | Garden
How do you fix the plastic gas line? It doesn't stay in the gas tank. When I prime the bulb the gas squirts out and when the echo blower is in use, gas ends up leaking on my leg.
The holes in these gas tank are made to fit available fuel lines tightly enough to prevent the problems you are having. If yours is leaking either someone put on too small a fuel line or made the hole larger so it would be easier to put the fuel line in the tank. The only fix is to get the next size larger fuel line or replace the tank. You can try to seal the line with RTV or silicone but he gas will degrade it and it will leak again plus you'll have a harder time the next time the line has to be replaced.
Jan 05, 2011 | Echo Back Pack Blower Rack Fits Stihl...
I have a 16" 452
You need to take the handle apart and check the trigger mechanism.It sounds like the rod or cable has come off and is stuck wide open.
Nov 20, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Leakin gas tank on Mod #PM 425 AV-18
Try sealing with PermaChem (I think that what it's called). It's a thick, sticky, fuel resistant compound that some in a small 4 oz tube. It never really hardens. It's made for threads. If this won't work than try Seal-All It will harden & should seal a cracked fuel tank, temporary fix for a fuel hose leak, etc. It can be found at Walmart, Home Depot, etc.
Jun 06, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
My two part gas tank leaks what do i use to seal it with
If the tanks are plastic, the best fix is to replace them. Most epoxies, silicon, and other glue bases don't bond well with plastic and the vibration of the running saw doesn't help the repair either. Hope this helps!
May 12, 2010 | Garden
Seal crack
Just buy the new seal and run the gas line through it and reinstall it into the tank.
Oct 10, 2009 | ECHO, Inc. PB-251C Handheld Blower
Open Questions:
Garden Logo
185 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
