Help with belt replacement
How do replace a belt on my Amana Washer, model ALW880QAW? It stopped spinning and agitating and when Itook the front off I saw a broken belt. I have the belt, But I don't know how to replace it.....HELP!!!
  • Scurve Jan 19, 2008
    My Amana washer stopped spinning. Removed the front cover and found a broken belt. Further examination appears difficult to assess replacement steps. Please help, your advice would be greatly appreciated.
  • Anonymous Mar 22, 2008
    i can not change mty belt because i am a spastic pleaase help me !
You have to remove the motor from the tub, there are 4 scews holding it on. then take off the pump using a star type bit
Posted on Jul 18, 2008
How do replace a belt on my Amana Washer, model ALW880QAW? It stopped spinning and agitating and when Itook the front off I saw a broken belt. I have the belt, But I don't know how to replace...
look around the motor you will see the mounting bolts they just might need to be losend or removed in order to remove and install the new belt some have a sleeve in the middle of the bolt that needs to be removed, try to do one bolt at a time, some times that helps.
Aug 21, 2011 | Washing Machines
Amana washing machine (ALW880QAW). Does not work in spin cycle. Washer works ok in wash cycle, and in draining water, just the new belt is too loose when it switches to spin. It just burns up the belt....
probably the lid switch is faulty,remove screws behind control panel,then pull control panel toward you and lift up and lay back,now remove 2 screws in the lower front panel by the floor and remove the cover,then 2 more screws to remove upper front panel above the lower one,then 2 more screws in front hold the top on then raise top up like a car hood and the lid switch will be under the top cover
Mar 23, 2011 | Amana ALW880WH Top Load Washer
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
Amana ALW880QAW doesn't spin and agitation is slow
winephan,
I could be the pump slowly ceazing causing the belt to slip which would give a burning smell.
Motors in those units, are well build...have a service guy in but DON"t say anything about the motor.. because they will say it because you mentioned it
I sounds like you pump
Jul 22, 2010 | Amana ALW880WH Top Load Washer
My washer (ALW880QAW) agitates but does not spin. I took off the front cover and the found a black circular piece lying there (What it goes to I do not know). The belt looks okay. The motor goes in spin...
That is the drive coupler and it has worn out. You can order a replacement set that comes with two plastic retaining pieces that slide onto both your transmission and engine and also a rubber piece that goes in between these two plastic pieces. You can search many places to find out how to replace this part. I just ordered a set and shopped around a bit and mine was $20 after shipping.
Nov 29, 2009 | Amana ALW880WH Top Load Washer
Replace Broken Belt
Here is the link that will explain how to do it:
http://www.applianceaid.com/amana-wash.html#belt
check this link u ll get if u dint really sorry for in convinience
Jun 17, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Amana clothes washer alw880qaw
Hi, Check the belt first. Remove the lower front panel and see if the belt is ok. Please let me know if I can assist you further.
Thankx
Vic
May 25, 2009 | Amana ALW880WH Top Load Washer
Washing Machines Logo
365 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
