Question about HP Pavilion a305w (DM181AR) PC Desktop
Friend said the capicitor went bad and they are
Friend said the capicitor went bad on the motherboard and they are hard to replace. We see where it is leaking. Is this true?
  • HP Master
  • 4,336 Answers
Could be true, but often it is cheeper and better to replace cpu. Otherwise you still have an older computer, that got repaired.
Posted on Sep 25, 2009
My DX483101e, the old hard drive (win 7 pre) went black, would not start, installed a new 1T Western dig hard drive, added win 8 (bad idea), eventually it went black, would not start. A friend got them...
Check in BIOS that your HDD id showing.
if it is showing then do the DPS self Test of the HDD. Surely it will solve your issue.
Otherwise it will be the issue of motherboard.
Oct 07, 2013 | Gateway DX483101e PC Desktop
My hard drive went bad and my asus p4b266-c motherboard is not recognizing the replacement drive. How do I update the motherboard so I can finish installing windows xp pro?
hello, after plugging the new hard disk, you will go to setup from the bios settings and choose ide settings, when you get to the master primary press enter so that the computer can detect the hard disk automatically, once this is done, save the settings and restart your pc
Dec 23, 2010 | ASUS P4B266-C (P4B266-C WA) Motherboard
I have a sony STR-de135 receiver whlie looking for one problem created another.While the receiver was unpluged I touched and output transistor MN2488 and it sparked now the left channel sounds distorted so...
The capicitors in the unit are charged. Replacing the output transistor(s) is not a task for a novist. Capicitors, resistors, driver transistors and sometime preamp chips can also be bad as well. If all the bad components are not replaced the parts you replace could blow out again.
Jun 19, 2010 | Sony STR-DE135 Receiver
EMachines T2824. Does nothing but light on mainboard coming on...
This is a motherboard problem. You'll need to replace it. Although, it may be cheaper just to buy a new PC (eMachines are never very expensive, or well-made for that matter)
Sep 22, 2009 | Computers & Internet
HP Media Center M8000. Network card bad, must replace motherboard
hello Friend,
here is the solution.
Buy New good Network Card Like D-Link or other cost about (10$-15$) install it on pci slot.then install drivers.so now u r system with new working Network Card.
if helps Rate the solution
Jul 02, 2009 | HP (D7580-60003) Motherboard
HP DV6500 will not boot
Motherboard is definitely bad then, you went thru all the steps that I would have done. Sounds to me like the voltage that is going thru the motherboard isn't being regulated properly cause some chips on the motherboard is bad and when there is to much voltage going thru then the laptop shutting off is a safety mechanism in place to avoid chips burning out on the board. Motherboard would have to be replaced.
Jun 10, 2009 | HP Pavilion DV6500Z Notebook
Gigabyte board GA-8IK1100 - all I need is a capacitor value
Hi, got the same board here infront of me. The capacitor is 1000mf,, 6.3volt
success
Mar 25, 2009 | Gigabyte GA-8IK1100 Motherboard
T2893 e machines wont turn on
Since you are looking inside, try this. Trace the wires that come from the power switch back to the Motherboard. The wires from the switch will connect to two pins on the motherboard. Carefully jump those two pins with a screwdriver and the machine should turn on. I would suggest doing this with all drives and cards unplugged first.
Jan 15, 2009 | E-Machines (T2824) PC Desktop
Dell opteplix gx270 problem
It is either dust build up on the CPU heatsink under the fan or that model is known for blown capacitors...
Open case and check motherboard for blown capicitors and / or dust build up on CPU heatsink
And if there are any bad capacitors then you will need to replace the motherboard.
Sep 10, 2008 | Dell (4T274-DE) Motherboard
Motherboard replacement question
You should be fine. Once the MoBo (if it is an exact replacement) is in and your box is completely assembled you should be good to go. I don't know why you are expecting a BSOD though?
I hope this helps,
TampaNative
Jan 29, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
HP Pavilion a305w (DM181AR) PC Desktop Logo
43 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
