Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
Printer will not print anything. - HP Officejet 6500 Wireless All-in-One InkJet Printer
How to fix printing problem
Check your default printer. The printer may not be set as default setting.
Dec 11, 2015 | Lexmark X3430 All-In-One Color Inkjet...
Why dose my cannon mg2150 printer print online but will not not print offline ?
Select the proper printer as your default ,, you may be printing to file instead of the printer,,
Aug 22, 2014 | Cannon Office Equipment & Supplies
Can't print anything
You may have blocked print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
Jun 25, 2012 | Canon PIXMA MP160 All-In-One InkJet...
!My printer works fine but doesn't print in color. I have checked all the ususal culprits and can't finnd anything wrong, HELP
Check that your Print Preferences is not set to print in greyscale or print only in black.Also you could reset the printer by turning the printer off, unplug printer from outlet, wait awhile,.then plug printer back in and turn printer on.
Nov 15, 2011 | Office Equipment & Supplies
My printer is printing without anything in the printer
go to the printer properties clear the queue and then stop the spooler services and then restart the services .... and your problem will be gone .....
Apr 14, 2010 | Lexmark X2600 InkJet Printer
Printer says i'm ''Offline'' and I cannot print anything.
right click on the printer and click on set as default and try to print this would resolve your issue persist, delete the printer and click on add a device
Aug 19, 2009 | HP Office Equipment & Supplies
Printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
Aug 13, 2009 | Epson Stylus C88 InkJet Photo Printer
Prints summary everytime you print anything
You can disable this option at the printer properties. I don't remember what tab it's located. Just open printer properties, check on each tab and remove the check mark to disable this function where it's indicated.
May 20, 2009 | Canon S520 InkJet Photo Printer
HP DESKJET 335 PRINTER WILL NOT PRINT OR DO ANYTHING
Look under you printers and see if the printer is online. If it is. Look if you do not have any print jobs in queue and delete them. Try again.
Mar 17, 2008 | Office Equipment & Supplies
Printer is not working
Will the printer print anything at all?
If it prints out anything, liek say open word try to print something out in there, if that works it may be a bug in Gmail.
Also what are you trying to print in Gmail, I can test it on my side aswell, I have a Gmail account.
Thanks,
Cam
Oct 19, 2007 | HP PSC 1210 All-In-One InkJet Printer
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
