Question about Avid Code Hydraulic Disc Brake
Avid juicy sevens remain tight against disc
Pushed pads apart w/ screwdriver. put wheel on. perfect. then squeeze levers, back to rubbing. red dial adjuster does nothing. help!
    Problem Solver:
  • 6 Answers
Juicy's are prone to sticky pistons.REMOVE pads,clean calliper ,pull lever lightly and add a drop of hydraulic fluid to the edges of the pistons to lube.Recess pistons,wipe off excess fluid and fit pads.If this doesn't work they might need bled.
Posted on Sep 26, 2009
I have avid juicy disk brakes. I took the rear wheel off and the pads but now I can't put the wheel back on because the pads are too close together so that the disk won't fit. Can you help please
You need to put a screwdriver between the pads and lever them apart. Trouble is, this will push the fluid back up to the reservoir near the brake lever. make sure there is room for the level to rise and make sure you don't get brake fluid on any painted surface as it will bring the paint off if left.
Aug 04, 2011 | Cycling
Avid Juicy 7 disc brakes:The front wheel was removed and the brake lever squeezed while the wheel was off. The front wheel goes on, but does not spin freely. It turns easily, but not freely like it...
It sounds like you have a piston that is not fully returned and is sticking.
Get a big flat bladed screw driver, take the wheel out and very carefully insert the screw driver into where the disc would sit and use the screw driver to try and push each brake pad back in without damaging your brake pads.
If this works go to a local bike shop and ask them for a avid brake insert for transporting your bike so this does not happen in future! :)
Jan 13, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Jammed Avid Juicy 5 brake piston
Sounds like you need to strip down the caliper and clean it out im afraid. How about trying a LBS?
(usually its caused by a dry seal and the piston has to be forced out by putting an air line onto the caliper bleed nipple and blasting air into it to force it out - *be careful if trying this!!**)
Jan 07, 2010 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Brake pads dont retract
you will need to retract them with a small c clamp, thus slowly pressing the calipers back into cylinder.plz rate-bozcro
Sep 16, 2009 | Avid Juicy 7 Hydraulic Disc Brake 2008...
Avid Juicy five system leaking fluid
Your brake failed and you need to take it to a good bicycle repair shop in your area. Hydraulic brakes on bicycles are not easy to self service as you need specialized tools and the proper replacement parts.
Aug 23, 2009 | Avid Code Hydraulic Disc Brake
Brake pads tightening up
use a flat screw driver and push the pads back in on the calliper. Be gentile though.
Jul 30, 2009 | Avid Code Hydraulic Disc Brake
Brake pads are shut fairly tight. Can't get disc
Your brakes adjust automatically (so when the pads wear down your levers don't get looser). What you did was pull the brake lever and it adjusted making the pads shut.
Anyway all you need to do is take a wide flat-head screw driver and wiggle it back and forth between the 2 pads.
Jul 10, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Bought a set of avid juicy seven ultimate brakes,i squeezed the brake lever and now the pads are shut tight how do i slacken them off again!
take the wheel out insert a very large flat bladed screw driver up into where the rotor would sit and lever the pads back in very gently with the screw driver.
if this does not shift them they will need re-built by a Sram bike shop.
Mar 23, 2009 | Avid Juicy Ultimate Hydraulic Disc Brake ,...
Avid Juicy 7 hydrolic disc brakes piston lock up
Do not bleed the brakes! If you don't have the plastic rectangular spacers that came with the brake when they were new, go to your local bike shop or get an "old" teflon kitchen spatula that's thin enough to fit but make sure its a bit thicker than your rotors and try to pry the pads apart then wiggle it until a good portion is in between the pads. Then squeeze the brake lever with the spatula is in between. This should reset the pads leaving enough clearance for your rotor to fit. NOTE: Avoid depressing the lever when the wheel is off. This will cause the pistons to travel further than usual causing both pads to come together. Hope this helps.
Dec 02, 2008 | Cycling
Avid Code Hydraulic Disc Brake Logo
341 people viewed this question
Top Avid Cycling Experts
Michial Gueffroy
John Egan
John Egan
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Are you an Avid Cycling Expert? Answer questions, earn points and help others
