Question about Ford Tractor 8n Front Emblem
Is there a simple way to replace a fan belt on a Ford 8N?
This 8N has front drive hydralics, and there seems to be a shaft and a lot of stuff in the way. Am I missing something, or does the whole lower front end hydralic system need to come apart before the new belt can go on?.....Dave...........
  • 474 Answers
There should be a coupler on the driven shaft. take out bolts and gently pry apart. this should allow enough room to work the new belt around the crank pulley
Posted on Sep 26, 2009
8n ford point adj . Point shaft following cam. Points will not open and close.
Have you checked the gear drive on the bottom of the distributor? I have seen the rolled pins sheer off on distributors where the gear drive attaches to the distributor shaft.
Apr 19, 2016 | Ford Cars & Trucks
How to replace 2006 ford escape left front axle shaft
How to Replace a CV Axle on a Ford Escape / Mazda ...
? 9:41
https://www.youtube.com/watch?v=_JxagNLBlQ4
Aug 29, 2013 - Uploaded by klowny1969
Axle nut should be torqued to spec..in the ford escape its around 205-220 lbs ft How To Change An Axle On A Front Wheel Drive Car ! SUBSCRIBE ! ... How to Replace a Front Axle Half Shaft - Duration: 14:37. ... Alternator replacement 2005 2006 Ford Escape 3.0L DOHC All Wheel Drive - Duration: 13:15.
Front axle replacement Ford Escape 2003 Right front CV ...
? 8:46
https://www.youtube.com/watch?v=JQK8SPj6Qsk
Mar 29, 2014 - Uploaded by Fixing cars and stuff
Front axle replacement Ford Escape 2003 Right front CV axle install remove replace This Channel provides ...
Feb 03, 2016 | Ford Cars & Trucks
Shermon shifterin ford 8n
http://www.yesterdaystractors.com/atrp/specs/ford.htm
The above link is an excellent site for help. Can you see if the shaft is turning when you try to shift the Sherman Hi/Lo transmission.?
The Sherman units are installed inside the housing between the engine and Ford transmission and I believe you would have to "split" the tractor to access actual Sherman unit. It sounds like either the Hi/lo lever is slipping on the shaft or has broken internally....good luck. Try doing a search for ( Sherman transmission Ford 8n tractor help) there are a lot of Old timer experts out there and this was a very popular addition to the 8n's
Apr 10, 2014 | Ford 8N Tractor
Cooling system not circulating, replaced engine, replaced thermostat and cooling hoses. Think there is a blockage, but not quite sure. 1998 Ford Taurus stationwagon SE
If you think there is a lot of rust or stuff that looks like rust in the radiator fluid then it is most likely not a thermostat problem. If the car has a lot of miles check if the water pump drive line to the fan feels loose. If so there may be a bad bearing. If it is an electric fan, well a belt still drives the water pump, so you may loosen the belt and test the same way. Make sure the radiator cap holds pressure well or the system will overheat. Also make sure there are no colapsed hoses.
Oct 17, 2009 | 1999 Ford Taurus
The steering column shaft in my 1954 Ford 8N tractor broke and I need info on howe to fix it.
Not sure, but if it's a 1954 model, it's not an 8N. 8N was only built thru 1952.
But sounds like you will need a new steering shaft.
www.Ford8N.com
Sep 19, 2009 | Ford 8N Tractor
Ford 4000 starter only works when I hit it with a hammer. What does that indicate?
the bendix unit on the starter shaft is sticking. You need to pull the starter and clean the shaft up and lightly grease it so the gear can move out when you engage the starter. worst case scenario you may have a badly worn shaft and need to replace it with a new starter. hope this helps you...
Sep 15, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
In 3rd gear the front wheels shake on 8N ford Tractor
The quick easy answer is put your feet on the steering shafts just ahead of your feet when sitting on the tractor when driving at speeds causing the shimmy.This is what most people do.
The longer answer is a new or rebuilt steering box or possibly adjustment.
Some (most) boxes have play that cannot be adjusted tight even with a rebuild.
Jul 14, 2009 | Ertl 1/16 Ford 8N Tractor With Wagon
Ford 8n gets hot, may need to be timed,Step by step needed.
This is everything that i know that will make an 8N run hot...a stopped up radiator(inside)..a radiator that is filled with debris in the cooling fins..a bad thermostat(located in the upper radiator hose..if it has one).....a stopped up block..bent fan blades...fan shroud missing..a bad water pump..the fan belt slipping on the water pump ..a blown head gasket..low coolant..i hope this will help and one of them should fix it ..if not...please write me back
Jul 01, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Ford Tractor 8n Front Emblem Logo
270 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
donald boissonneault
fordexpert
Are you a Ford Garden Expert? Answer questions, earn points and help others
