Question about LG LMV1630ST Microwave Oven
Door panel falling apart - LG LMV1630ST Microwave Oven
  • 4 Answers
Check repairclinic.com for parts on this unit. The door will run you about $121 item #1310935. If you just need the door frame assy. that's about $31 item#1300226. Good Luck.
Posted on Dec 16, 2009
New microwave got condensation between glass panels. Got new door happened again. I think it's a design defect. How can I disassemble to clean as needed?
To be honest-- it's not worth the effort. Some doors do come apart and some are glued together. If the replacement door is only listed as a complete door it doesn't come apart. If it does come apart, it requires prying the plastic frame off the inner side of the door to get to the screws. The frames usually crack if you are not careful. Contact Frigidaire customer relations and explain the problem and see what they have to offer either as a repair or explanation.
Apr 14, 2015 | Frigidaire Microwave Ovens
Magic Chef microwave oven
On alot of models the door comes as a complete assembly and can't be taken apart. Magic Chef is made by Maytag and I am pretty sure theirs do not come apart. If it does come apart then it is likely held togther by plastic tabs that have to be pried apart. The problem is they break easy and then you will be replacing parts. Guess you will have to decide if it is worth taking that chance because doors are expensive. I don't see your model # in the description but you can try looking a diagram by typing in your complete model # located on the sticker inside the microwave. Try sears.com and click on parts and various other repair sites. Hope this helps. Let me know if you have any other questions.
Oct 07, 2007 | Microwave Ovens
How do I fix my microwave door latch? It will not allow the door to close.
Need to have model for exact fix but door may just have a spring fall off inside door inner panel snaps off you will see the rest
Mar 24, 2015 | Microwave Ovens
LG door panel separating
DO NOT use this microwave in the current condition it is in- please! Although microwaves do not emit ionizing radiation, it does emit non-ionizing radiation and electromagnetic fields- and there is a lot of research studies being done possibly linking microwave exposure to cancer.
If your microwave is in that bad a shape, bring it to an authorized microwave repair shop or junk it and buy a new one.
For replacement parts, repair videos, and manuals: http://www.lg.com/us/support/parts-accessories
Jan 03, 2014 | LG Microwave Ovens
G.E. Spacemaker trips the breaker on the circuit it is pluged into if you open the door when it is running.
Check the door switches and the wires connected to them. I've seen at least one door switch that had bad contacts literally fall apart due to overheating. It's possible you have one that is broken and twists over to touch a grounded metal part when you open the door (also inspect the bracket that holds the switch for the same issue). The same switch doesn't trip the breaker when the oven is not running because there is no power going through it at that case.
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The door is falling apart...need a new door? worth buying door or new microwave?
Best is to see if a door can be sourced from an old set , as you can get one swapped from a scrapped oven.
I don't think buying a new one is worth as a recent model will cost lower with better efficiency of power and performance.
Hence you must decide accordingly.
Oct 23, 2010 | KitchenAid KHMS147 Microwave Oven
Handle replacement
The door handle can easily be replaced on most microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This should be a very simple repair that you can easily perform yourself.
If you have any questions, please post back and let me know. You can refer to this illustration, if you like, to assist you as well:
http://pcappliancerepair.com/model-display.php
I hope this helps you.
Mar 17, 2010 | Whirlpool GH4155XP Microwave Oven
The glass on the microwave door on the outside has slipped down and there is no screws to take apart the door and fix the glass. Does this fall under the warranty? My 5 years is up on 12/01/09.
I would contact customer service (for Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here about the warranty and to find your nearest authorized servicer.
If not, it's pretty easy to fix this yourself.
There are probably broken tabs on the inner or outer door panel.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Sep 26, 2009 | Maytag MMV1153A Microwave Oven
Microwave serial # xr2004675 superba heating
If the door seals tight & properly and the fine screen / mesh in between the door glass panels is not damaged, there should be no leakage.
But the risk remains that moisture and food particles will get into cracks and crevices and lead to arcing or rust, both of which can eventually damage the mesh.
What is the small curved piece that's falling out? Can you post a photo of it?
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 29, 2008 | Microwave Ovens
Plastic shielding and door handle broke off
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
If you don't find your model there, call the number shown on that page.
Oct 12, 2007 | Goldstar MV-1501 Microwave Oven
LG LMV1630ST Microwave Oven Logo
282 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
