Question about HP Pavilion dv9005us Notebook
My dv9005us becomes too hot. The GPU goes to 110 C in less than an hour and then shuts the laptop off. I can even put my hands on the desktop.
  • 496 Answers
Check out all the vents and take a can of compressed air to them make sure that they are free and clear of any blockadge see if that helps if not you may need to get inside it and see if the fans on the cpu are still working they're probably pretty dirty and causing problems
Posted on Sep 25, 2009
My AMD laptop become too much hot and goes off.
you need to renew your thermal paste on CPU and GPU and maybe the chipset bga to. and clean all the dust from the heatsink and the fans.
Applying Thermal Paste To Laptop CPU
Jan 29, 2016 | AMD Computers & Internet
Hello, I have a problem with my PC. I'll be
connor,no input you write it can be a easy thing as the monitor-cabel is not tight enough fasten.check that first .if the problem don't go away you have open the computer and remove the videocard clean the cards slot with caned air short poffs never shacke the can.now reseat the card and hope at that did the trick.let me now if ok
Jul 20, 2013 | Computers & Internet
PS3 shuts down completely and abruptly without warning and reason
Your GPU gets hot, because when u start the console it gets hot, nd when u start a game it becomes hotter, when the system detects that ur GPU is hot it shuts down Automatically, the cause of this problem is common, you need to replace the GPU's thermal compound nd try to find the The Arctic Silver one, it's the best.. GOOD LUCK
Feb 03, 2013 | Sony Playstation 3 (PS3) Console
Dv9005us mother board.
Laptop do not have the capability of a desktop computers that allow you to install various motherboards inside the PC case.
You can improve the performance by installing more RAM and replacing the hard disk with a solid state hard disk.
Dec 14, 2012 | HP Pavilion dv9005us Notebook
I have hp dv5 1002au, my laptop displays hrizontal lines and everything freezes, then i can only perform a force shut down and would start normally next time. the problem use to happen rarely but now it...
Your laptop is presenting a GPU overheat witch is consistent with the horizontal lines coming from the video card output, thus it shuts down to prevent damage. Let me tell you how I know this I recently a year ago fixed a unit with this same problem on youtube.com/rulds2008.
You can got to my laptop repair video there. What I did was not easy, I had to take apart the laptop as a whole. I cleaned out the fan units witch is connected to the same heat sync the cpu/gpu is connected. I put some thermal paste on the gpu chip.
I put it back together and the unit lasted another year or 2. The issue is within the manufacturing of this Hp laptop witch caused this problem to begin with. The manufacture used some thermal sticker that was put on the gpu that wore off thus the gpu got hot.
A overheated gpu causes damage, if your unit was damaged then a motherboard replacement will be in order. I clock a motherboard replacement at $230 bucks. You might want to check ebay.com tho if you decide to go that route. A temp fix is thermal paste on the gpu itself.
I work for your ratings, So if your inclined to watch my videos, and choose to try what I have done please let this be at your own risk, I been in the repair biz for a long while. Please do not forget to give a feedback rating.
Thanks and best regards,
Rulds2008 "ED"
Jul 19, 2011 | HP Pavilion dv5-1002us Laptop PC
My laptop is Wipro brand. I have been using it for last 2.5 years. Since a couple of months I am facing a problem of being hanged up. Anytime the screen gets sparked and colors of the screen starts...
This is definetely not a software issue. You are facing either:
A) Bad LCD screen or inverter board
These can be replaced quite easily as they are both held in by a number of small screws.
B) GPU Hardware fault
Normally caused by excessive heat. This melts the solder around or in the GPU chip and causes it to malfunction as you described. This can be fixed by painstakingly removing your motherboard and resoldering the GPU chip. It is not garaunteed and getting a new laptop is much easier.
C) (unlikely) Driver issues.
Download the latest drivers for your screen/GPU from the manufacturer.
May 09, 2011 | Computers & Internet
When i shake my laptop, its screes becomes black
Do not shake your laptop.
There are components, like hard disk, graphics card, that are sensitive to shakes.
Jan 29, 2010 | IBM ThinkPad T40 2373 Notebook
Irregular power supply to toshiba satellite M100 laptop
hi there,
i would like to know how old is your laptop.?
new laptop less than a year can operate on 1- 3 hours.
older laptop 2yrs above can only operate at 1 - 1 1/2 hours.
first for an initial help try removing the battery pack and put it back in properly,
let me know again here.
thanks
Dec 06, 2008 | Toshiba Satellite M100 Notebook
HP Pavilion dv9005us Notebook Logo
331 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
