Question about Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum
My bissell proheat will not spray water or cleaner and the filter does not turn;
    Problem Solver:
  • 10 Answers
Thanks to many others who have posted on similar problems -- water and/or solution sprays through the handheld tools, but not through the main machine.
As others have suggested, I removed the water reservoir, which exposes the 2 main water sprays mounted above the rollers. Using, pliers, I carefully slid the clips back. Gently but firmly removed the two red nozzles.
Elsewhere I have read suggestions to just do one nozzle at a time. However, I found out that if you remove both red nozzles, you can then blow through one side and it will come out the other. In my case, that dislodged a nice collection of crystal-like chunks (guessing it may be crystallized residue from the cleaning solution).
There was also a bit of blockage in one of the red nozzles, which I cleaned out. Make sure you can blow through both of them with little resistance.
Reassemble: Push red nozzles back into hoses. Using pliers, reposition sprung clip back over the red nozzle. Snap nozzles back into place. Refill tanks and power it up.
In my case, that resolved the problem of no sprays from the main machine. Sprays like new now. Hope yours does too!!
Posted on Sep 26, 2009
My Bissell Proheat carpet cleaner/hose for cleaning will not spray anything
My ProSeries Carpet Cleaner won't spray. What ... - Bissell
www.bissell.com > Support > Helpful Resources > FAQs
BissellLet's start by figuring out where your carpet cleaner can spray. If you have no spray at all, start below. If you have no spray at the floor but can spray from the hose, scroll down for the ... Turn the unit on after cleaning and see if water sprays to the floor now. IV. .... My ProHeat® Self-Propelled's Powerdrive isn't engaging.
Bissell Carpet Cleaner Won't Spray. Easy Repair - YouTube
? 1:48
https://www.youtube.com/watch?v=nccdrjpGp34
Dec 20, 2013 - Uploaded by Cecil Argue
You may have a bad pump, clogged hoses or a clogged heater. ... Just want to tell you that this was the perfect ...
Nov 30, 2015 | Bissell Vacuums
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
How do i unclog my bissell proheat that will not spray
Check the filters? There are two. One on the water tank cap (looks like a screen), the other is under the Flow Indicator: turn the Flow Indicator Cap counter-clockwise and remove it. Lift the rotor out and under it is the filter. Lift it out and clean. Reinstall in the reverse -order. If that didn't help you could call Bissell Consumer Care at - 1-822-237-7691 I Hope that helped.
Feb 28, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell PROheat 2X No longer sprays water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Oct 30, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My bissell proheat sprays water when first turned on, then after a minute stops spraying
heatman101
oiguut
Jul 18, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat won't stop spraying.
heatman101
yolo
May 02, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat cleaner hand cleaner spray but floor cleaner wont
heatman101
cnb,m
Dec 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell shampoo machine will not spray either water or soap
heatman101
yuet
Oct 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell ProHeat Turbo Deep Cleaner Upright Steam Vacuum Logo
376 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
