Question about Dell 924 All-in-One InkJet Printer
Carrier jam iv tried taking it apart and putin it back together but every time i try to turn it on it makes a horrable noise then says "crarrier jam press select" and when i do it just freezes, makes another horrable noise, then turns off and every time i turn it back on it does it again.
    Problem Solver:
  • 12 Answers
Try turning it upside down and shaking lightly. Could have small item inside. If it isn't this might need replacement. I have been through 3 of these. Hope this helps.Lesnbek
Posted on Sep 27, 2009
I took apart my dryer to investigate a noise. While it was apart I noticed arcing at the terminals. L1 had completely melted. I purchased a new terminal block and installed it. Everything went back...
Hi herbert hurt...
The noise you are hearing could be your drum rollers.
They could need cleaning and lubrication or replacement.
If they need lubrication they will make a squeeling noise, if they have flat spots on them they will make a thumping type of noise.
If that is you noise then take the dryer apart and lube,clean, or replace the drum rollers
Please take time to rate me
Aug 17, 2011 | Vacuums
I have a carriage jam
Turn the power on. Goto the procedure to replace ink cartridge, to get the carrier in the middle. Turn off power by unplugging the machine, if you hit thee power button the carrier will go back to the right. Take your hand and move the carrier to the right then to the left. You are feeling for binds in the print shaft or any obstruction. If the print shaft is binding clean and oil it. If the cartridge is hitting something locate and repair. There is a thin strip behind the carrier that has black strips all along from left to right. This strip is called an emitter strip. That strip allows the circuit board to know where the carrier is at. The strip gets dirty and can cause the carrier to get lost to the circuits. Clean it. There are more step that you can take but they get more technical. The above mentioned can be done with out taking the cover off. You may resolve the problem.
Nov 19, 2008 | HP Officejet 7210 All-In-One InkJet...
Paper jamming in rx585
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 13, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Kitchen aid dry motor noise
Try taking it apart again and try to turn the motor by hand. It should spin freely. If it does you've probably got a bad motor. If it is stiff or doesn't turn at all, then you might have missed something putting it back together. I wouldn't think you can overtighten the blower, it is probably something else, and with it apart it should be easy to see.
Jul 21, 2008 | KitchenAid Dryers
Machine makes banging noise
wow, taking apart and putting it back together is a big feat. I think you should check the needle and its height, could be to low and is hitting just enough to make noise and not break.
Jul 24, 2017 | Brother XL-2600I
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
Carrier XHD183D Through-the-Wall Heater/AC runs constantly
YOU COULD EITHER HAVE A THERMOSTAT PROBLEM OR FAN CONTROL PROBLEM.TURN THE POWER OFF AT THE FURNACE AND TAKE THE THERMOSTAT OFF THE WALL.MAKE SURE YOU MARK THE WIRES SO YOU KNOW HOW TO HOOK IT BACK UP AGAIN.RESTORE POWER TO THE FURNACE.TOUCH THE WIRES THAT WERE HOOKED TO THE R & G TERMINALS ON THE T-STAT TOGETHER AND HOLD THEM THERE.OBSERVE THE OPERATION. WHEN YOU TAKE THEM APART DOES THE BLOWER STOP?TRY IT A FEW TIMES. IF IT CONTINUES TO START AND STOP YOU GOT A BAD T-STAT.JEFF
Dec 13, 2007 | Carrier XHD183D Air Conditioner
Cartridge carrier stuck
just open the cover and out oil or any lubricant on the rod of catridge carrier and and manually move the head from left to right at for 5 to 10 times. but doind all these thing make sure your printer is completly off. bye
Jun 21, 2006 | HP DeskJet 5150 InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
88 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
