Question about Dell V305w All-In-One R840635AU InkJet Printer
How do you use it with a mac computer - Dell V305w All-In-One R840635AU InkJet Printer
Im trying to download undying to a mac computer
System Requirements: (This is Vintage Mac Software and may not work on current systems.) Requires: Mac OS 8.6, 9 or X. G3 400mHz or Faster. 96MB RAM. 600MB Hard Drive Space. 16MB VRAM with 3D Accelerated Video Card (Rage 128 or Better)
Nov 18, 2012 | Aspyr Clive Barkers Undying for Mac
Useing Hard drive on a Mac computer(Hard drive Isn't showing up on computer)
It could be that it's either not partitioned properly, or if you've used it before it might not have been ejected properly the last time it was disconnected.
Some drives that say they are Mac compatible must be partitioned for Mac before they become accessible. Based on the brief description that's the only advise I can offer at this time.
Nov 06, 2012 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a Mac osx g9 and IO don't know how to install bluetooth do I have to buy something or download it?
Go to
Finder » Applications » System Preferences
Under the Internet & Wireless section there is a Bluetooth option. Click on this.
Make sure both 'On' and 'Discoverable' are clicked.
Dec 25, 2010 | Apple Bluetooth Card (Rev. 3) for eMac,...
Internet connection fails through DLink router
Some ISPs (Internet Service Providers) require that you "register" the 'MAC' (not an Apple --> Media Acquisition Control) address of the network-adapter of your computer (or router) with the ISP,
before the ISP will allow your computer (or router) to be provisioned.
Your router has a different MAC-address than your computer.
So, your computer works with its "registered" MAC-address,
but your router cannot connect with its "unregistered" MAC-address.
Access the web-server inside the router, and click the 'Clone MAC-address' button, and restart the router.
Then, the router will send the MAC-address of your computer, rather than its own MAC-address, to your ISP.
Dec 31, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I downloaded a Sansa video converter and it keeps saying that my Sansa is not connected after i connect it. Can i have some assistance please?
do u have windows or mac system? if mac,
Although MAC OS is NOT a supported operating system, the Sansa player can still be recognized if the Sansa player is only plugged in MSC mode.
MAC computers do NOT support MTP
A Sansa player in MTP mode when plugged into a MAC computer will NOT be detected or recognized.
MAC computers supports Sansa players in MSC mode
Sansa players can only be recognized by a MAC if the USB mode on the Sansa player is set to Auto Detect or MSC.
See answer ID 207 for instructions on how to put your Sansa player in MSC mode.
See answer ID 1141 for instructions on transferring music to your Sansa player using iTunes on a MAC computer.
Aug 01, 2009 | SanDisk Sansa e260 MP3 Player
I have the same problem too
Try this procedure:
To Spoof a MAC Address
  1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records.
  2. Disconnect other computers from the router.
  3. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.)
  4. In an Internet browser type the address 192.168.0.1.
  5. Type admin for the username, password for the password, and click OK.
  6. Go to the Basic Settings > Router Mac Address.
  7. Select Use Computer MAC Address.
  8. Click Apply. This automatically gives the router the computer's MAC address.
  9. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Jun 06, 2009 | NetGear DG834G Router
Mac compatible computer cool school???
If you have a modern (Intel) Mac running Leopard, you can use BootCamp, which is on your computer, to install Windows XP or Vista on your computer in a separate partition and run the software there. Other options that are a little simpler include using Darwine, a program that can run *some* Windows applications on Mac. The easiest solution would be to return the product to the store, because these companies are unlikely to ever produce a Mac client for your product.
Dec 30, 2008 | Fisher Price Video Game Consoles & Games
Using mp3 player on mac computer
There is no solution - the software is not Mac compatible -period. It doesn't say MAC-compatible on the product specs, therefore it is not Mac compatible.
Aug 22, 2008 | Philips GOGEAR SA6045 MP3 Player
I mac printers
yes you can use any type of printer for your Mac computer
Mar 02, 2008 | Macsense MPC 10 Network Adapter
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Dell V305w All-In-One R840635AU InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
