Question about Dell 3010cn Laser Printer
I get error message "Paper Jam Fuser 07-104" "Open Paper Cover Remove Paper" I have done that and cannot see any misfed paper. What is the proplem?
It could be a couple issues. The picker rollers may need to be replaced. There are sensors after the draw and after the fuser.
Posted on Oct 03, 2009
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
Sir my printer problem is on printer menu write a clearing paper path what is this massage and give me solution.
Thank you contacting FixYa for your printer inquiry.
This error is associated with either a sheet of paper blocking the paper path or a partial piece of paper that blocks path or trips a sensor. The printer will usually throw up a error code 13.XX on the display and the XX is a number that will indicate where in the paper path this error most probably occurred. Just follow the steps for your error on the below chart.
This link will take you to the user guide which will be helpfull identifying components and providing guidelines for most of the helpful hints and things you will need to know about this printer.
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00218691/c00218691.pdf
Locate your error on the matrix below and follow the steps. Comment back if you need more help. Thank you again for contacting FixYa.
TF
HP Laserjet Error Codes 0 - 19 Message on printer Display Panel What it means. What to do. 13.XX PAPER JAM [LOCATION] Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken. For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation. 3.0 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation. 13.1 PAPER JAM OPEN INPUT TRAYS Paper-delay jam at paperfeed area. 1. Ensure that paper trays are loaded and adjusted properly so media can feed from the tray. It might be necessary to reduce the stack height of media in the tray. 2. Check the input area for obstructions such as media in the path. Also check to see if the registration assembly damaged or unseated. 3. Replace any defective sensors or flags. 4. Verify the media meets the specifications. 5. Check the pickup feed and separation rollers for unusual wear. Replace as needed. 6. Rotate the media in the input tray by 180° and/or turn it over On NX engines this is most likely the fuser flag or the ACPM. The ACPM has a photosensor hard-wired to the back of it. 13.10 PAPER JAM CHECK DUPLEXER Jam at duplexer. 1. Check the duplexer and the rear area of the printer for obstructions or damage. 2. Check the duplexer for proper operation. Replace the duplexer if a sensor is defective. On a 5si, 8000, or 8100 series laserjet a Duplex Jam can be caused by a tray 2 and 3 feed assembly failure. 13.14 For Laserjet 5si. This error is caused by a defective paper control PCA Replace paper control PCA. 13.2 PAPER JAM OPEN INPUT TRAYS Paper-stopped jam at paper-feed area. 1. Check the input area for obstructions such as paper in the path. Also check to see if the registration assembly is damaged or if the transfer roller is out of place. 2. Replace any defective sensors or flags. 3. Ensure the media does not exceed the maximum length. 4. If multiple sheets are feeding, it might be necessary to fan the media and reduce the stack height. Also, replace separation pad. 5. Verify that the fuser is properly installed. On NX engines this is an input jam. 13.20 PAPER JAM CHECK REAR DOOR Media stopped in the paper path during power on or when the top door was closed. 1. Remove all media in the paper path, and then open and close the top cover. 2. If the message persists after all media is removed: Check if media is jammed in the prefeed area. Replace any defective sensors or flags 13.21 DOOR OPEN JAM The top cover was open while printing. 1. Clear the jam and close the top door. 2. If the message persists, check the top door switch for proper operation. 13.5 PAPER JAM CHECK REAR DOOR Paper-delay jam at fuser. 1. Check the transfer roller and small media belt to ensure they are operating and can feed print media. 2. Check the paper path for obstructions at the transfer roller, toner cartridge, paper feed assembly, and fuser. 3. Replace any defective sensors or flags. 4. Turn the media stack over and/ or rotate it by 180° in the input tray. If still persists - replace fuser, then DC controller. 13.6 PAPER JAM CHECK REAR DOOR Paper-stopped jam at fuser. 1. Check the paper path for obstructions at the fuser and output/delivery area. 3. Replace any defective sensors or flags. 13.99 PAPER JAM [LOCATION] A non-specific paper jam occurred. 1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation
Jun 09, 2011 | HP LaserJet 4350 Printer
I have a xerox workcentre XL2130. It had a bad paper jam. I cleared it - now it has an error code E4. I've turned it off and on - hit the clear button - nothing is clearing it? Help! Thanks, Stacia
YOU STILL HAVE A PROBLEM IN THE PAPER PATH...
DOWNLOAD THE USER MANUAL
Clearing the Paper Path
- E-1, E-2, E-3, E-4, E-5
When a paper misfeed occurs the red misfeed indicator flashes
on the WorkCentre diagram, and an E status code will flash in
the Display Window. Paper misfeeds may occur in the areas
shown below. Follow the steps below to locate and clear the
misfeed.
Note: Ensure that the alternate paper tray is lowered
(XL2140df only).
Caution: Do not touch the shiny drum cartridge surface.
Scratches or smudges will result in poor copy quality.
Do not remove paper through the bypass. Unfused toner may
adhere in the area, resulting in smudged copies.
E-1
Steps 1-2 for XL2140df only
1. Lower the right Side Tray 2 Access Door.
2. Remove the misfed paper.
3. Close the Access Door.
If paper cannot be removed, open drawer (2) clear misfed paper.
4. Close the Side Cover.
E-2
1. Press the Release Latch to open the Side Cover.
Exit Area
Paper Feed Area
Fuser Area
Side Cover
35
- E-1, E-2, E-3, E-4, E-5 (continued)
Caution: Do not touch the shiny Drum Cartridge surface.
2. Carefully remove the misfed paper in the direction shown.
If paper cannot be reached, open the paper trays and remove
misfed paper.
E-3
Fuser Area
Warning: The fuser area is hot. Take care when removing
paper from the fuser area.
Note: Ensure that the Alternate Paper Tray is lowered
(XL2140df only).
1. Press the Release Lever to open the Side Cover.
2. Pull down on the fuser lever.
• This will release pressure on the paper.
Caution: Do not pull paper up through the fusing unit. Unfused toner
may adhere in the area, resulting in smudged copies.
3. Remove the sheet of paper in the direction shown.
E-4 and E-5 (2-sided Reverse Copy XL2140df only)
Exit Area
1. Pull down on the fuser lever.
2. Gently pull the paper out through the exit area.
36
3. If not accessible, turn the knob in the direction of the arrow
to move the paper to the exit area.
4. Gently pull the paper out through the exit area.
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Feb 12, 2011 | Xerox WorkCentre XL2130f Laser Printer
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
My Konica Minolta 2530DL printer has paper jam ,as i tried to remove paper a part of it tornoaway and got stucked in the fuser roller arear. How can i remove the fuser to get the piece of paper out
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 12, 2010 | Konica Minolta Magicolor 2530 DL Laser...
Paper jammed at this time error message show on control panel 13.05.00-Jam in top cover area open front covers and Transfer unit. Fuser is hot transfer unit can be easily damaged. Check left side of...
This error comes when media doesn't come to fuser delivery sencor with in the specified time it may be due to improper paper picking or fault in registration ***...
clean the paper feed rooler & registration *** path ur problem will resolve defin...........
Jul 14, 2010 | HP LaserJet M4345 MultiFunction Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
Panasonic printer dp4520 error code j40
This indicates there is a paper in the fuser area(very Hot section be cautious).1. open the front door.2, open the left side door. look inside for a green plastic handle & lift up he metal guide plate sometimes the paper gets wrapped around the upper heat roller or curled up and around the separator claws. if so be very careful not to scratch the rollers or break the sep claws. there is a green handle/knob located in the machine that can be turned, this turns the fuser rollers and makes it a little easier to remove a fuser paper jam. After you remove the paper jam close all the doors/panels you first opened. the copier should reset itself. I have seen the pj errors change to a new one indicating another pj still exists. if so look again and remove as indicate by the Lcd screen. Please leave positive feedback if this helps
Jun 07, 2008 | Office Equipment & Supplies
Error Msg: PAPER JAM in Brother MFC-8840D
one of the jam switchs is stuck down or paper concertina in fuser assy
Dec 28, 2007 | Brother MFC-8840D All-In-One Laser Printer
Dell 3010cn Laser Printer Logo
198 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
