Question about Kenmore Elite 45986 Front Load Washer
When I try to start my washer it beeps and flashes f then dl. I lost the owners manuel. What does this error message mean and how can I fix it?
  • 5,911 Answers
The error codes are not listed in the Owner's Manual, they are listed in the Technical Data Sheet. "Fdl" is a door latch error code. This is an indication that the door latch is broken or the Central Control Unit (CCU), which controls the latch is not working properly. The technical data sheet that comes with the washer explains all the error codes, diagnostics steps and troubleshooting procedures on how to determine which component has failed. The tech sheet is located inside the washer behind the lower toe panel directly below the door. If not directly behind the toe panel, it will be affixed to one of the interior cabinet walls. To remove the toe panel, you need to locate and remove the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off.
NOTE: For better access to the toe panel screws, you can prop the two front feet of the washer up. (A 2x4 works well for this).
Inspect the door of the washer to ensure the latch pin is intact and not broken. Then, inspect the latch mechanism on the front of the washer to ensure nothing is lodged inside. Last of all, remove the top and panel of the washer by locating the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. Locate the connector plugs that run between the CCU and the door latch. Unplug each connector (one at a time) and plug them back in to make sure they are seated properly and making good contact.
If you determine the latch is broken, the following link explains the steps necessary to replace it:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 25, 2009
What does F DL means i opened the door to add something then t came up F DL and wont start again, the cycle had just started I pressed cancel all it does is beep and flash F DL
Hello and welcome to FixYa
FDL is a door lock error and is caused due to an issue with the door lock when it is unable to lock/unlock. Please check the door lock mechanism/door switch assembly and replace the part that has gone bad so that the issue is resolved. Please get back to me if you have any other questions.
Kevin
Sep 14, 2011 | Whirlpool GHW9400 Duet Washer
When i try use the washer it starts to make a clicking sound then when i hit cancel starts to beep and it flashes f dl
F dl = Door lock error
A Door Lock Error occurs if the door cannot be locked. It will try to lock
it six times before displaying the error code.
Possible causes/procedure:
¦ Door lock mechanism is broken or removed from door.
¦ Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door
switch/lock unit and Central Control Unit (CCU).
Jun 11, 2011 | Kenmore HE3T Washer
Fatal Error 14h 2300 DL
printer.konicaminolta.com/service/ASP/mc2300/.../mc2300SM.pdf
this link is going to take you the manuel that what you have to do when you got an error.
Nov 16, 2009 | Konica Minolta magicolor 2300DL Laser...
DL f flashing and beeps
Fdl is a code that indicates a door lock error. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Aug 12, 2009 | Kenmore Elite 45986 Front Load Washer
Error message
Hit cancel the amount of minutes will stay the same and then hit the start button again.
May 13, 2009 | Kenmore Elite 45986 Front Load Washer
Error code on the washer machine
DL/F is a door unlock error the door lock may be broken.
Mar 18, 2009 | Whirlpool Washing Machines
My front loading washer wont start it flash E and DL i dont no what it means can you pls help me?
DL means door lock error. This happens when the door trys to lock 6 times but cant lock.
There a 2 things that create this problem. the door lock mechanism or the CCU ( central control unit )
Replace the door lock mech. first. if this does not fix the problem replace the ccu.
Nov 15, 2008 | Kenmore 46462 Front Load Washer
What do I do for dL and F error message?
same problem..for a couple months I could get it to work intermittently but finally gave in and the repair guy is here putting in a new control panel. expensive sorry to say.
Jul 17, 2008 | Kenmore Elite 45986 Front Load Washer
FRONT BELLOWS
I have a whirlpool duet washer i can't retrieve the model number because the door is locked but the dryer which is the match to the washer is model number GEW9200LW. My question is that when I hit the control button then start, a muttled beep will sound not allowing the door to open. I get an error message of DL then it flashes to F? Any help?
May 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
195 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
