Question about HP Office Equipment & Supplies
I had my printer (hp psc 1200 series) try and print a document however I didn't know that the printer was offline so I tried to cancel the document and now it says under status- deleting, paused, printing) and I was wondering how to get it to finally delete the document from the printer queue? Thanks
  • 23 Answers
You need to go ahead and simply refresh a service known as "Print Spooler"
here's how you do it..
for Windows XP:
>> click on start
>> click on run
>> type in " services.msc " and hit enter
You will see a list of service names alphabetically arranged on the right hand side..
From there look for the service name "print spooler"
>> right click on it
>> click on stop
wait for 10 secs
>> right click on it again
>> click on start..
>> restart the computer..
>> you will find your document deleted :)
plz rate if you find it helpful. thank you
Posted on Sep 25, 2009
Hp printer displays offline
I resolved the problem by restarting the Print Spooler service.
Click Start/Run
Type services.msc and press enter
In the Services dialog scroll down to Print Spooler
Click to select it and Click Restart Service.
The system will stop and restart the service.
Close the dialog and check your printer again.
If this fails, leave te printer on and reboot the computer.
Hope this Helps!
Feb 13, 2010 | HP PSC 1209 All-in-One InkJet Printer
Can't cancel a HP PSC 750 Printer print job.
Right click on MyComputer and click Manage. Then go to Services and Applications and then Services. Find the Print Spooler services in the list and right click to stop it. When it is stopped try to cancel the document again. Then start the print spooler service again.
Regards,
nicolasiac
Feb 12, 2010 | HP PSC 750 All-In-One InkJet Printer
I have HP 1200 psc I have a document that will not delete therefore I cannot print anything at all I have tried switching off everything - no luck - can you help?
From Printers and Faxes window
1. Right click the printer icon for your HP 1200 PSC then select "Set Printer Offline".
2. Right click again the printer icon then select "Cancel All" print jobs.
3. Once it's cleared, right click the printer icon again and then "Set Printer Online".
Or, restart the computer and the printer.
Oct 23, 2009 | HP PSC 1315 All-In-One InkJet Printer
Hp 1400 does not print from print command by computer
sir reinstall your printer software and drivers or follow my commands go in your start>printers and faxes>and right click on your printer>properties>ports and select your port and apply
Jun 03, 2009 | HP PSC 1410 All-In-One InkJet Printer
How do I get a alingment test
HP PSC 1200 and 1300 series:
  1. Turn on the HP PSC 1200 or 1300 series product.
  2. Disconnect the USB cable from the all-in-one.
  3. Press the sequence of front panel buttons below to start the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
    1. Press and hold Cancel .
    2. While holding Cancel , press On .
    3. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
    4. Press Cancel again.
    5. Press Copies .
    6. Press Paper Type .
    7. Press Color Start Copy . The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
  4. When the alignment page has printed, place the page face down on the scanner glass and press Scan . The alignment is complete when the On light stops blinking.
  5. Reconnect the USB cable.
Jan 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1100/1200 all-in-one does not scan with vista..
I had the same problem. Click Start, Windows Photo Gallery, from that screen, you can select import from scanner. The 1200 series printer should be a choice to select. You are then able to preview the image or document, then press scan. I found this out through the HP support website.
Aug 07, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Replaced cartridges
try these... if the lights stops press cancel and color button together to self test. if it is working. the printer is ok! proceed to check for the printing Queue cancel all pending document, check and select printer on the print control ,
yours ,
alecz
Apr 20, 2008 | HP PSC 1350 All-In-One Thermal Printer
Aligning printer after new ink cartridge inserted
SOLUTION: Start the cartridge alignment by performing a series of button presses from the front panel of the product.
  • HP PSC 1200 and 1300 series:
      5. Press Copies .
CAUSE: This can occur if the cartridge alignment is canceled or times out without a valid print cartridge alignment stored in memory.
Oct 29, 2007 | HP PSC 1350v All-In-One InkJet Printer
932 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
