Question about Photography
Nikon n4004 top cover
How do i remove the top cover plate from my n4004 camera. the right side seems to be caught on something and i don't want to break it by using too much force.
thanks
  • 667 Answers
There are two screws on the right side that are hard to find. One is inside the battery chamber and the other is under the small cover surrounding the shutter release button. The cover is held in place by 2 sided tape. Pry it up carefully starting near the strap lug
Posted on Dec 23, 2007
Nikon n4004 manual how to remove lense
You may download a copy of the manual here. The lens mounting/unmounting instructions are on page 7.
Apr 22, 2012 | Nikon Cameras
Hi i recently bought a used F3/T. Just ran a 36 exp roll and everything seemed to work fine. However i realized on loading a new roll, that the film counter did not reset. It remains at frame 37. How can i...
This won\'t be easy for you if you don\'t the proper tools, You have to remove the wind lever assy, and the speed dial, Then wind side top cover, Then pull wind base plate assy, And check counter reset lever, to make sure spring didn\'t come loose, Putting the baseplate back on can be fun because of linkage to the wind assy
Sep 29, 2010 | Nikon F3HP 35mm SLR Camera
Removing Nikon FM2N top plate
Unscrew the rewind knob and remove a circlip under it (You may need to grind the tips of a pair of round-nose pliers for this). Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Do not remove the center screw from the shutter speed dial. Remove three screws from the side of the dial and pull off the grip ring.
Jul 08, 2010 | Nikon Photography
I have just bought a second hand Nikon F 401 camera. How do I load film into it? Is it possible to get a free downloaded manual?
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Look for the N4004 manual. That was the name used in North America.
May 03, 2010 | Nikon Photography
Parts for Nikon FM Camera.
The bottom will fit, but the top cover for an FE2 is quite different than an FM.
Jan 28, 2010 | Nikon Photography
Nikon FA top plate removal
After unscrewing the rewind knob, remove the circlip under it. Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Mar 22, 2009 | Nikon FA 35mm SLR Camera
Want to remove top plate of nikon fe
It's not very easy- you have to remove the rewind knob and dials at the left end of the cover and the speed dial and winder arm at the right side. Then the 5 small screws around the cover.
It is a delicate task because under the cover there are some very sensitive electronics. If you are determined to go ahead with it then your best bet might be to get a service manual.
Nov 16, 2007 | Photography
Looking for a user manual
Sep 21, 2007 | Photography
Photography Logo
145 people viewed this question
Top Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Photography Expert? Answer questions, earn points and help others
