Question about HP Pavilion dv6000z Notebook
My built in wireless card status is tuck on orange
    President:
  • 2,004 Answers
Please run system restore back to factory default.
Posted on Sep 25, 2009
Cannot get the wireless connection to work on the printer. The USB cable is connected to the back of the PCU. I've installed and uninstalled twice and nothing. It did work when I first got it and...
Here are some guidelines to identify and fix your wireless communication issue:
  • What is the status of the Wi-Fi light on the printer? Green light means that it's connected to a wireless network while Orange light means it's not connected to a network.
  • Try to print the printer's wireless network settings to determine if it's connected to your own wireless network. On the printer operator panel, touch the Setup button > Network Setup > Print Setup Page. Your printer will then print the its wireless network information page. Ensure that the printer is connected to your network by checking the Network Card Status, Wireless SSID, Quality or Trouble Code.
  • If printer is not connected to your network, you may need to reset your printer's wireless network settings. On the printer operator panel, press Setup button > Network Setup > Reset Network Settings. The Wi-Fi light on the printer will momentarily turn off then back on to solid orange. You can then run the Wireless Setup Utility application on your computer to reconfigure the printer to connect to your wireless network. On your computer, launch the Lexmark Printer Home application > go to Settings tab > Wireless Setup Utility. Please follow the instructions on your computer screen.
If you still need assistance, please contact Lexmark Technical Support Center for additional assistance.
Aug 21, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
I have a gate way laptop with Intel® PRO/Wireless 802.11g integrated wireless 10/100/1000 Mbps integrated Ethernet LAN card, i cannot connect to my wi-fi network, is it possible that the wi-fi card is...
Wi-Fi card can be considered broken only if its not able to scan for any available networks. Also, do check in the device manager of the computer. Check for the device status of this wireless adapter there. If its properly installed, etc., it should say, "This device is working properly". There is also a fix for other error messages. Regarding hardware breakage, we cannot come to a conclusion so easily as we have all these things to check. The case may be little complicated as its an in-built wireless card. We cannot even remove it and try on a different computer.
Mar 17, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
My built in wireless network adapter is no longer detecting any networks. It is an hp pavilion dv 2500. Is there a way to fix this problem; do I need a new adapter? If so, where can I get one?
The new hp units have a touch switch on the top panel. It should be blue when on, otherwise it is orange/yellow. Just touch the icon to change the status from off to on, then check for networks.
The paragraph below is from the hp website on wireless unit problems:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is quite common to accidentally bump the button and turn off the wireless service. On most computers there is an LED light that glows blue when there is a wireless device is turned on and enabled.
This is the link to that site:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00812738&cc=us&lc=en&dlc=en&product=3379103
Good Luck
Feb 01, 2010 | Computers & Internet
The wireless light is orange in the past was in green light
Switch on the hard switch as shown in the picture
Is still not active, Goto Control Panel, look for network connections and enable your wireless card, example is the picture below, (example only shown is the Local area network cable) But on the devices you can see there Wireless Card, make sure the status is Enable. To do this right click on the device and select enable. Still problem exists? Check your device manager if your Wireless network card driver is installed correctly...
Oct 21, 2009 | HP Pavilion dv6000z Notebook
Wireless networking hardware not functioning properly.
Check on Device Manager if it is working properly
Right-click My Computer-Properties-Hardware-Device Manager
Click on the plus sign beside Network Adapter and double-click your wireless card.
Check on the device status if it says it's working properly.
Try to disable-enable the adapter by right-clicking on it under the device manager window.
If it has a question mark, it is most likely driver issues so contact your wireless card manufacturer or PC manufacturer if the wireless card is built in.
Jan 12, 2009 | Gateway MX8711 Notebook
I cannot get my laptop to go wireless. My router is a LinkSys - the techs there say there is no problem with it. I used to have wireless prior to my computer having to be sent in to Gateway...the...
0) Be sure that your wireless router is working properly
1) Check your wireless card on your computer
See the status of the card
>>My PC>> right click Properties >> Hardware >> Device Manager >> Network
2) Check if your card (if it is PCMCIA Card) was installed correctly, if not installed again.
if you dont have the driver, get the driver of your card from manufacturer website (D-link, etc)
3) If your card is built-in check be sure that the power button is ON
4) Check if you have some or your wireless network available
5) If not renew your ip address
6) If you see the network, select your network and connect.
Let me know how it is going
Pablo :-)
Oct 20, 2008 | Gateway Computers & Internet
Wireless Network Card
how old is the laptop and did you turn on the wireless switch located on the exteiror of the laptop ?
Jan 28, 2008 | Acer Aspire 3000 Notebook
Installation troubleshooting with belkin 802.11g
Windows Wireless Network Status window should detect the router; it should broadcast the SSID belkin54g or something similar; you do not need the CD to set it up.
Nov 09, 2007 | Belkin F5D7330 802.11g/b Wireless Adapter
Linksys wireless broadband router and wireless access point
Hi I would love to help you with all the resources and knowledge I have, however, this would require online chatting kind of. You either reach me using the live chat feature of Fixya or just add my msn id in your messenger : sandeepbakshi@hotmail.com. Whenever I am online, I would assist you. Again, if the above given suggestion is not possible, please give me the following details: 1. exact model no (on the bottom panel) 2. firmware version (if possible) 3. no. of hard wired PCs (directly connect) 4. No of wireless computers 5. ISP 6. any other device connected to the router 7. status of internet on the hard wired PCs 8. status of wireless computers 9. The status of lights on the router (dont forget to specify the labels on top of the lights to make things clearer) thank you
Mar 10, 2007 | Linksys Wireless-G WRT54G Router
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
