Question about Kenmore Freezers
I am trying to identify the model number of an old Kenmore freezer. It is an ultra-low (-20C) so it's probably considered a lab freezer. It's about 3' tall. The door handle says Kenmore 6. The only other identification inside or out is a wiring diagram on the back. The number on there is 728839-A. Any Idea?
fridgetech
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
  • 1779 Answers
SOURCE: door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Posted on Aug 08, 2008
  • 311 Answers
SOURCE: I am accumulating ice inside my freezer
It needs to be defrosted. If ice builds up quickly again then start shopping for another freezer as the repair is not worth it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
  • 449 Answers
SOURCE: Gassy smell in upright freezer
Is this a refrigerator in a household or an RV?
The reason I ask is that RV refrigerators use ammonia, which you can smell. If you read the article you probably read that Freon does not have an odor, in extreme cases you can smell burnt refrigeration oil when a system with a large leak has been left running, but by then the unit wouldn't be working.
If your refrigerator did in fact have a leak it wouldn’t be working, due to such a small amount of refrigerant present. ( typically about 5 ounces )
So, your gassy smell is likely from something else. I find this happens most often when potatoes or carrots are stored for long periods of time in the refrigerator, usually in the crispers. When starchy vegetables wilt ( get smaller with age ) they give off a gas. The smell eventually comes not from the starch, but from the bacteria that starts growing on it. All this happens on a microscopic level so you won't see anything. good luck
Posted on Dec 19, 2008
  • 323 Answers
SOURCE: low temp alarm goes off on Kenmore upright freezer
The alarm is there for a reason. I wouldn't disconnect it. Maybe the compressor is low on gas. If your thermostat is on extremely low, try moving it up to a less cold position. Look in your owner's manual for recommended settings.
Failing that, get ready to shell out some bucks to the service man!
Posted on May 12, 2009
Freezer age and kwh usage for kenmore 2722
go here,put the name,model and serial numbers in and it will tell you how old any appliance is.
http://www.appliance411.com/service/date-code.php
Jul 10, 2013 | Kenmore Freezers
Sear chest freezer stop working model#2539139180
The compressor probably shut off on thermal overload. This protects the compressor from burning up. What has happened is that a capacitor or evaporator has gone bad or it could be low on freon. Have someone take a look at it. However, if it is older than 8-10 years old, consider replacing it. This could be the beginning of the end.
Feb 02, 2013 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
In my freezer, there is a blinking red light next to the icemaker on-off switch. What is it and why is it blinking?
It might be blinking because it hasn't been able to reach the required temperature or the temperature you have set. Probably leaving it close for one or two days, the light will go off, if not, you might consider changing the plastic isolation of the door, you know, the plastic thing that you see goes around the freezer door, best luck.
Jul 26, 2012 | Freezers
How do I adjust the freezer temperature on a Kenmore upright freezer?? Brand new, model number 461.27432, didn't come with a manual.. can't tell whether 7 or 1 is considered the coldest temperature?
Sorry there is no manual on-line for the freezer. But I can tell you this 7 is the coldest and 1 is the warmest.
Good Luck and Please rate 4 thumbs up for the free answer.
Jul 04, 2010 | Kenmore Freezers
It only two years old, do not know where the book is at. I have 800 lbs of meat in. it was set at 5. do we go up on the number and do i have to much meat in and air not getting a round. please help!!!!
as long as you did not pack it in too tightly,to allow an air flow around the back and sides of the shelves/drawers,you should use a freezer thermometer,in the centre,to check,after 24 hours,
that you have -18C to -20C all should be fine.....i do not trust onboard temp guages that much.....
Apr 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
What is a reasonable temp setting for this freezer? Bought it without the manual. A quick version on how to set that temp would be helpful. Thx, m..
freezers should be -18/20C to keep beef for 12 months,use a freezer guage in centre of freezer,that way you wont get ice bricks instead of ice cream.....test after 24 hours of setting....
Apr 05, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Need -20 degrees Celsius...Will this brand get there?
If all is ideal maybe -10 an occationally -15 and this is F considerable coolder than -20C. ALSO fyi a chest freezer will stay at or below these temps better than an upright and especially a self defrosting model. Because a chest freezer you dont loose all the cold air when you open the door. TYhey are not made in auto matic defrost as far as I know (never have seen one but then I havent been looking for one either. An up right freezer can be manual defrost or automatic. but the cold air falls ouit every time the door is opened.
Please let em know if this helps you by giving me as high a mark as you can and thank you for using fixya.
May 29, 2009 | Kenmore 24.9 cu. ft. / 705 liter Chest...
Old Upright Kenmore Freezer Help , please
If it is a shelve it is made for storage. A sign of imminent death on these old freezers would be its ability NOT to reach a low enough temperature when running. The older systems had heavier metals in the construction including the cooling systems. Some tips on keeping it happy would be to operate it in a place where you would be comfortable to sit for an extended period of time.
Jul 06, 2008 | Freezers
Old kenmore freezer
you are missing the 1st 3 numbers of your model# which is the generally 106. or 363. find the 1st 3 and then you will get the answers you need
May 24, 2008 | Freezers
Freezers Logo
91 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
