Question about Conair HC100RCS Hair Trimmer
Conair hc318d reassembly
I can't reassemble my blade kit on my conair hc318d hair clippers.
  • 2 more comments
  • Anonymous Jan 26, 2008
    can not reasemble my conair hc318d
  • zmplant Feb 19, 2008
    When trying to reassemble the blade and interior parts (that my 6 yr. old took apart!), I accidentally broke a small plastic part. Can these interior parts be purchased? Does anyone know how to put it back together even?
  • Anonymous Jul 22, 2008
    The blade part of my Conair HC318D trimmer popped off and now i can't get it back on.
  • arbednaej Aug 25, 2008
    mine fell aprt when i tried to clean out hair, now i can figure out how to put it back together picture?
    there is a small black part and a wire spring, the blade, a black crecent shaped deal with screw holes,  and the top blade thing and two screws.?
I have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Posted on Aug 02, 2009
    New Friend:
  • 7 Answers
The blade rests in 2 spring points, you have got to make sure that the spring "pins" are inserted into the holes on the blade, then you need to line up the nub at the lower end of the blade with the vibrating arm that extrudes from the razor, the nub needs to be in between the 2 teeth in the vibrating arm,(white plastic).. after lining everything up, apply gentle pressure on the head until you have the 2 screw holes lined up..the blade should "seat" itself around the screw holes...While holding blade in place insert and tighten at least one screw, once one screw is in place, you will no longer need to hold the head in place in order to insert the second screw. If you turn the clippers on and the lower blade is not moving, try pushing the edge of the blade side to side in order to get it moving freely. If this does not work, you either have not got the spring or the "nub" aligned right.
Posted on Jul 27, 2016
My remington HC-70, I cannot place the blades back on? Please help
Posted on Jul 06, 2011
How can i disassemble my canair HC111Dcs i think its much the same with HC111RCS i cant see any screw upon it how can i dis assemble it? i want to rewind the coil bacause i pluged it to 220v and its only 110V. please help me..
Posted on Oct 04, 2008
You can buy another blade set for that model. Call 1-800-3-CONAIR
Posted on May 26, 2008
How do you clean the clippers and keep them sharp?
You can use a damp cloth after use to remove hair and other debris. There isn't really a way to sharpen the clipper though. The work on more of a shearing motion, but if you notice it has a lot of pull, you can order new blades online.
Jun 17, 2011 | Conair 16-Piece Chrome Haircut Kit...
I have conair haircut kit 10 piece and i used it on my brother and it keeps pulling his hair and i turned the power on switch it still pulls his hair whats wrong with the clippers
Sounds like you may need the blade sharpened, it may be dull, otherwise the motor may not be functioning properly. Does he have thick or coarse hair? If so, you may need to go through it lightly in sections otherwise it will for sure pull, I learned that way back in hair school long ago. :) Goodluck!
Apr 02, 2010 | Conair HC90CS Hair Trimmer
Putting back together hair clippers
are u talking about the clipper it self or the clipper blade i need to know which one
Nov 07, 2009 | Health & Beauty
Andis Ultra Edge Pet Clipper Assembly Help
I took my andis ceramic edge blade apart to clean. Now my clipper will no longer cut my dog's hair
Aug 13, 2009 | Andis Health & Beauty
Wahl Razor will not realign after removing blades for cleaning!
This is always a problem with clippers, it's just a matter of holding the blades tightly in place and getting the screws in as tightly as possible without letting the blades go. This has always worked for me in the past.
Mar 17, 2009 | Wahl Super Taper Hair Clipper 2000 Hair...
Conair Champion Hair clipper
i have an "hc318d" conair hair clipper. i took the two screws off to oil the inside and now i can't get it put back together properly. can u help?
Aug 04, 2008 | Conair 5200
Conair HC100RCS Hair Trimmer Logo
5,148 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
