Question about Toymax Magnavox 37MF231D 37 in. LCD TV
When turned on it turns back off.
At this time I can on my tv and only the light comes on then back off after about 15 seconds. then once its powered up again it comes on as normal. I have turned it on a few times, that I have noticed, without any signal from my cable and it turned on the first time.
  • veeredd Sep 25, 2009
    I need o know what I can do to fix this problem. the tv has been moved to a different location to watch a game 2 weeks ago and it done the same thing at that outlet. Magnavox 37MF321D 37 in.
  • veeredd Sep 26, 2009
    When turned it on today for the first time, I didn't turn on the cable box. it turn on as normal. it only has problems when the cable box is sending its signal to the TV
    President:
  • 1,462 Answers
This is problem with two capacitors, which stores power for certain time and releases it.
Open the cover and try to find two capacitor in the power board
1)C2074 is a 2200 uf @ 25v
2)C2081 is a 1200uf @35v
Check whether these capacitors are good and not swallon/leaky, it dead try replacing the capacitor..And if not try finding other worn capacitor, try replacing if found..
THis can be done by normal person, think you can do it
Please leave me comment, if you need furthur assistance, Else leave me feedback
RNJ VINODKUMAR
Posted on Sep 27, 2009
  • 4,472 Answers
Http://www.fixya.com/support/t2696949-magnavox_37mf321d_37_will_not_turn
http://www.fixya.com/support/t465280-magnavox_37mf321d_37
here are some links to reference.
It almost certainly is your "power supply". Most likely you will want to just replace the whole board as its easier though obviously the choice is yours. This is a common issue with these tv's. I believe the whole board is about a 100$. If you need any further assistance please let me know.
Thank you,
Lee
Posted on Sep 25, 2009
  • Toymax Master
  • 19,396 Answers
The TV turns itself off and goes in standby because the protection circuit is detecting a wrong voltage, and is turning the unit off.
Try to connect the TV to a different main socket , to test.
If the TV is still turning itself off , then there is an internal fault.
Common fault that can cause shut down after few seconds are:
Faulty capacitor on PSU. A capacitor does not old charge as it should, causing an odd power draw on part of the circuit , the fault is detected after few seconds and TV turns off.
Faulty inverter board. the inverter board can fail after few seconds, often because of a faulty capacitor or a faulty oscillator on the AC side of the inverter circuit.
Faulty digital controller board.
Try first using the extension to connect to different socket. Also leave the set unplugged from main for about thirty minutes before reconnecting.
If that does not work, then the TV must be tested to find and repair the fault.
Why does my Philips 40" flat screen tv shut off 15 seconds after I turn it on?
The symptom you describe suggests power supply failure. It is still working but fading fast
Mar 24, 2013 | Philips 40pfl3706/f7 Lcd Flat Panel Tv
TV TURNS OFF ITSELF AND 15 SECOND LATER IT COMES
This is a Heat issue with the front sensor of the TV. Dust and Dirt block the sensor causing it to heat up faster and faster. Cleaning the lamp is extremely easy and it will get the TV working again, at least for a short while and then it will happen again. I know cause its been happening to me and it will work for about two weeks and start happening again. Sony actually has a class action lawsuit against them for this issue. Long story short here are the steps to correct the issue:
1. power down TV and disconnect from the power outlet then let sit for 30 minutes until its colled down 2. On the bottom corners of the TV (Back side) you will find a round screw that you can loosen with your fingers 3. once both screws are lose the front bottom part of the TV will pull off, there are magnets there so it will hold it in place temporarily. 4. Once the cover is removed, in the center of the TV will be a little door with another Finger screw to loosen, once off move the bar holding the door closed and remove the plate. 5. You will need an Alan wrench, the screw will be in the upper left corner, when this is loosened the screw will not fall out and you can pull out the Light fixture 6. CAREFULLY with compressed air spray the light assembly and the inside of the TV very well and then replace the light bulb. 7. Put the Door back on the front of the Light area, and assemble the rest of the TV in reverse order before testing the TV. I have done this multiple times as this is not a permanent fix but does restore life for a short period of time.
Feb 04, 2010 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Tv wont come on and a red light is blinking. I have a Sony Wide screen projection TV model kp-46wt520
Can you unplug the TV for about 15 seconds, and then plug back in and watch the stand-by light. Tell me how many time the stand-by light blinks in regular intervals. If it doesn't blink at all, you need to change a fuse on the g-board. Once this is done run back through the stand-by blink light process, and more troubleshooting can be done if problem isn't already solved. If the stand-by light just keeps blinking with a count over ten just tell me, and I'll look for other possibilities.
Oct 25, 2009 | Sony KP-46WT520 46" Rear Projection...
Why does the power light flash on my tv after 15 seconds when i turn it on for sometimes 2 or 3 days.
Hi, this is heat related. you will need to replace the fans in this unit. this will fix this issue. also, inspect the ballast in the lamp area. if it clicks when you are powering up more than 3 times, the high heat may have damaged this circuit that provides the power to the lamp.
May 20, 2009 | Toshiba 55HX70 55" Rear Projection...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
50" philips won't power on. get the 4x red blink led light
i have fixed 3 of this tv, with that exact problem in the last 2 weeks, needs a power supply, you can try to unplug it again, plug it in, hit the power button, as soon as it turns green, unplug it again, after 15 seconds , plug it back in, if power doesnt turn on by itself, turn it on, if it turns red again, emediatily hit power again, may have to hit power a few times in a row, but most of the time you can get it to come on this way, once it is on, it should run ok, until you turn it back off, but not a fix, needs power board
Jan 10, 2009 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Philips 42PF9956/37 Plasma TV - Looking for y sustain board
it isnt the Y-SUS board, it is the Power supply, iv fixed this exact problem twice in the last month, try turning the tv on, and when it turns green, unplug it real fast, while light is still green, after 15 seconds plug it back in, then hit the power button, if it dont come on, hit the power button again, this time, as soon as it turns off, hit the power button again to turn back on, sometimes you can trick the tv and it will turn on, at least i was able to do it, and once it comes on, it should work fine, untill you turn it off again.
Jan 10, 2009 | Philips 42PF9431D/37 TV
SAMSUNG DLP HL-S5086W
check the horizontal transistor if, good.re solder your tv.
Sep 28, 2008 | Samsung DLP HL-P5663W 56" TV
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Toymax Magnavox 37MF231D 37 in. LCD TV Logo
185 people viewed this question
Top Toymax Televison & Video Experts
matt martin
matt martin
Paul
Are you a Toymax Televison and Video Expert? Answer questions, earn points and help others
