Question about Frigidaire FEB27S5A Electric Single Oven
Frigidaire GLEF378CSB oven and display not working
My husband was cooking in the oven at a low temp, and it popped the circuit breaker (this has never happened before). He flipped the circuit breaker back on, and now the oven and the display are not working. The stove-top is working fine tho. ??
Hello, I have the same problem after moving and reconecting in a new house. right now it looks like that the clock and controlboard (P/N GAP316207529) is damaged. I will let you know where and how you can get the part and how to install it. I hope that my first try will solve the problem. (I'm living in Germany)
Chris
Posted on Dec 02, 2009
Temp control knob loose on old Frigidaire oven
my best guess its A Frigidaire wall oven, circa 1966-1970,
unsafe to use at any time if the temp controller trips the circuit breaker
could be the oven thermostat causing the trip as well
if Frigidaire are still in business
You will need to ask an electrician to fit a /tested used controller or new superseded part temp controller and knob
Oct 11, 2016 | Frigidaire Ovens
How to test oven control board on a Frigidaire FEF366DBE?
Hello Shawn Lloyd, thank you for your post!
I see that your Frigidaire range blew the breaker to your home out and now the oven will not heat up properly. There is not information provided in order to test the control panel I would recommend having a professional technician for proper diagnosis and repair. The technician will be able to use appropriate tools in order to verify the control panel is working properly. -Matt
Nov 16, 2014 | Ovens
Wall oven stopped working
Good Morning Peggy, thank you for allowing me to assist you!
Typically error code F1 indicates that your range has detected an issue with the runaway temperature (overheating). Try reprogramming your appliance by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. Wait approximately ten minutes and if the error code does not clear, I would recommend contacting a professional to proceed further. Most likely the EOC (electronic oven control) will need replacing. Hopes this help!
Dec 29, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven is flashing f10 and burning the top of food being cooked and then shuts itself off
Hello - Typically error code F10 indicates a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Oct 13, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My frigidaire oven is displaying F1 on the display case. I had something cooking in the oven and then the breaker popped. I went out to check the breaker box and turned it back on. Now the oven is just...
The F1 code indicates a control failure. Try pressing a key to see if it displays on the screen. If not, the keypad may have shorted and requires replacement.
If the keypad is fine, there is perhaps a problem with the internal checksum; disconnect the power for 30 seconds and reconnect it. If the code remains, you must replace the electronic oven control (EOC).
- If the F1 code appears when the oven is running, it means that the oven senses an overheating condition. Use an external thermometer to check the temperature inside the oven.
- If it is accurate, it means that either the temperature sensor probe or the control relay has malfunctioned. Disconnect the power, and inspect the sensor probe, replacing it if necessary.
- If the oven is actually overheating, replace the EOC.
- If the oven is allowed to overheat, the resulting damage is possibly so extensive that the entire oven may require replacement.
Visit THIS LINK for additional details.
Hope helps.
Jul 18, 2011 | Frigidaire Ovens
I have a Kenmore 790.9232 electric oven range with digital display. There was a pop as I was cooking today and the circuit breaker in the basement went off. I reset the breaker, and while the stovetop...
some thing has definately blown. were you using the oven at the time? it could be the oven element other wise i think its the circuit board. if you cant trouble shoot those simple things then you will need a technition.
Jul 02, 2017 | Ovens
I have a frigidaire oven model number GLEF378CSB - won't heat up
Make sure your getting 240 volts to the unit if not it's the board...sorry. More then likely it's the board.
Jan 10, 2010 | Ovens
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire FEB27S5A Electric Single Oven Logo
236 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
