Question about Maytag EPIC MFW9700S Front Load Washer
CANNOT RUN MACHINE IT SAYS"CONTROLLED LOCK" - Maytag EPIC MFW9700S Front Load Washer
    President:
  • 1,015 Answers
Hold the "cycle end" button for 3 seconds...this should unlock the control panel buttons.
Posted on Sep 25, 2009
Where is the control module for the windows and locks etc.
The vehicle is equipped with power door locks. Each lock actuator is powered and controlled by the door module mounted in the individual door. The driver door module (DDM) is the master control for the door lock system but the rear integration module (RIM) contains the program that determines when the lock functions are permitted. ( RIM ) is rear integrated module , under the back seat . Also a fuse box is also located under the back seat.
The door lock operation modes are controlled by the rear integration module (RIM). The RIM examines the requested function from the DDM, or the remote function actuator (RFA), as well as the transmission shift selector position and the ignition switch position information available over the Class 2 serial data circuits. The RIM determines if a locking function is permitted, and commands the DDM to perform the function permitted. The DDM then sends commands to the rest of the door modules via the SBI to implement the selected locking function.
The vehicle is equipped with power windows controlled by the door modules. The DDM receives a window switch request, over the SBI serial data, from either the passenger door module wired to the window switch pressed or from the driver door switch assembly. The DDM checks the Class 2 serial data to see if the status information is correct (i.e. ignition switch position) to permit window operation.
Your best bet is take the vehicle to the dealer or a repair shop that knows how the system works . Are you familiar with GM class 2 serial data communication network ? You could inadvertently render your vehicle unable to start an run if the class 2 bus were to become shorted to ground .
You
Buick Class 2 Operation Diagnosis 1998
May 03, 2016 | 2000 Buick LeSabre
What makes machine shut off after 15-20 pounds of pressure how do I get it to run up to 100pounds of presure
Hi Tony:
There should be a pressure controlled switch.
It should have an adjustment, often with a lock nut.
If you back off the lock nut, the centre can be screwed inwards to increase the "trigger" pressure.
Your unit may not be exactly as I describe, but the principle will be the same.
Hope this helps.
Nov 14, 2015 | Air Tools & Compressors
Qadra fire mt Vernon non ae feed uger runs in revere
For an electric motor to run in reverse the start windings have to be reversed at the terminal. To lock up indicates that the start windings are not getting power. All these are controlled by the start/run capacitor which is the normal failure point on electric motors. Take the motor to an accredited electrical shop and have it tested
Nov 13, 2014 | Cars & Trucks
Hoover washing machine door lock
I hope yr going to replace it, not run the machine without the lock. The lock is for safety, if a kid tries to grab clothes when it is spinning it can twist an arm off. So there is a safety concern.
Sep 01, 2014 | Hoover Washing Machines
Door wouldn't lock, so replaced lock, now door locks, but machine won't run
Good Morning Friend,
I understand that the lock on your Frigidaire Affinity washer, model# ATF7000E, started off not locking so you replaced the lock. I also see that after replacing the lock, the lock works but your washer will not run. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why it will not run. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Affinity ATF7000E Front Load...
WHAT IS A CL CODE ON MODEL 796.41022900 FRONT LOAD KENMORE ELITE WASHER,IT SHOWS INTERMITTENLY DURING WASH CYCLE
Means someone put it in controlled lock position. Just hold the Control lock button down for 5 sec or so until the light comes off. Machine isn't malfunctioning.
Jul 31, 2010 | Kenmore Elite 45986 Front Load Washer
I can't start my washer machine, it is in the controlled lock and will not let me do anything else.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Apr 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
F11 and f dl errors
I hope that you have a serivce contract or something on this unit you need a main control board f11 means that there is communication error between the 2 computer boards the fdl means that there is is door lock problem. But that is incorrect that is how you know which board has the problem the door lock is controlled by the main computer board. it's just playing tricks on you I have tried changing the door lock with those codes and it did nothing. that board tends to be alittle pricey .good luck.
Dec 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore Door Jam
Door Lock Mechanism broken.
Check Door Lock/Switch Assembly for foreign objects
Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Door Lock/Switch Assembly Failure
Jul 06, 2008 | Kenmore 44832 Front Load Washer
Computer
On the controlled pc you must open administrative tools - services and make sure telnet service is started and set to automatic.
On the controlling machine, open a dos window and type "telnet computer-name" or "telnet ip-address" when prompted enter username and password that is valid on controlled pc, at that point you can run many dos command line commands and programs. Make sure that controlled pc has passwords for all accounts, otherwise you open a big security hole.
Apr 06, 2008 | Microsoft Windows XP Professional With...
Maytag EPIC MFW9700S Front Load Washer Logo
50 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
