Question about Vizio L37 Television
The AV cable pin broke off (red plus) and is stuck in the port of my HDTV. Any idea how to get it out? It is a Vizio 37'' HDTV.
  • Vizio Master
  • 8,457 Answers
U know how to solder right?Must take back cover out all in the hole with srews ,and desolder the part.replace the part,damage pins cause short or colors operation.
Posted on Sep 28, 2009
  • 834 Answers
Git a good strong pair of twizzers or small needle nose plyers
Posted on Sep 25, 2009
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Dec 25, 2015 | Vizio Televison & Video
Vizio M550SV no sound. Is there an audio card or does the main board have to be replaced?
See page 8 here:
http://cdn.vizio.com/documents/downloads/hdtv/M550SV/991UG_M420-470-550SV.pdf
From the top
- HDMI - both Audio and Video come from device via one cable.
- RF Coaxial (aka CATV) - both Audio and Video come from device via one cable.
- 15 Pin Dsub (they are calling it RGB), Video comes from this cable and Audio is from a dual 1/4" plug (looks like a headphone wire at both ends).
- Component (this is true RGB) uses RCA type cables - two sets of cables, cable one has 3 RCA at each end and they are color coded, as follows Red/Green/Blue, cable two has two RCA color coded as follows White/Red. Cable one is Video, and cable two is audio, total of 5 connections at source and 5 connections at tv.
- Composite AV - one cable set, coded as follows - Red/White/Yellow, Red/White are audio and Yellow is video.
Hope this helps.
Nov 25, 2014 | Vizio Televison & Video
Cable port broken off vizio L37
The Main Board will need replacement. Soldering in another cable connector will usually not work in most cases unless you change the entire tuner
Aug 02, 2012 | Vizio L37hdtv10a L37 37" 720p Lcd Flat...
I have a vizio 55 in. e550vl the hdmi ports quit working when lightning hit a tree by the house i think maybe a surge came through the satellite if i was to replace the main board would that fix it i...
I am having the same issue with our Vizio E550VL TV. Does your TV show No Signal on the screen? I was able to get regular AV to work with the Yellow, Red, and White cable to work but none of the HDMI ports would not work. If it does not power on at all it may be the power supply. I had to order the main board to get it to work correctly. Vizparts.com is where you can order it from.
Aug 10, 2011 | Vizio E550VL 55 in. LCD HDTV
Satellite/Cable Coax "DTV/TV" in-port broke
Replacing connectors on televisions can be a pricy endeavor. If you can't afford to bring it into a service shop, you may have luck by switching to a different type of connector. If your Satellite or Cable receiver has an HDMI output, your best bet would be to buy an HDMI cable and hook that up instead - the quality would actually be better than coax. Failing that, depending on what kinds of outputs your sat/cable receiver has, you could also go with (in order of preference) component video (a cable with five ends, red/green/blue, plus two for audio), s-video (a round metal connector with four pins in the middle), or composite video (similar to a component video cable, but only three ends - red, white, and yellow).
Any of the above cables (including the HDMI) can usually be found at your local big box electronics retailer for under $30.
May 02, 2011 | Televison & Video
42 inch vizio has picture (direct tv) but no sound. Tv is not on mute.
Did you check the RCA AV Cables? The ones with the red, white yellow?
What is the connection you have from Direct TV box to your TV. You might want to start on that.
It might probably as well related to any of the remote controls settings. Either of the Direct TV control or TV Control.
1. Check the cables
2. Check if there is any function on the Direct TV remote that will turn off the sound
3. CHeck the Vizio TV Menu Settings.
4. Try with other component such as DVD to discard the possibility of malfunctioning VIZIO Speakers.
Vizio offer a good customer service if still under warranty.
God Bless You!!
Feb 14, 2011 | Vizio VW37L 37 in. LCD HDTV
Cable input not working
Bad column driver board or connection. Or bad panel.
Apr 18, 2010 | Vizio VX32L Television
I just purchased a vizio 37 in tv. I wanted to know about the best hook up for the tv to the direct tv box.
If your Direct TV box is HDTV compatible then the best connection would be HDMI, and Componant Cables (Red, Green, Blue, w/Red, White) would be the second choice.
If your Direct TV box is not HDTV compatible only SD compatible, the best connection would be S-Video (S-Video cable with audio cables), Composite Video (Yellow, w/Red, White), or Coax cable.
All of the above cables can be purchased at your local Radio Shack, Best Buy, Walmart etc..
Feb 08, 2010 | Vizio Televison & Video
Where do the yellow,red, and white cords connect to on my Proscan 37'' DVD/HDTV
it depends on what signal your sending to the tv.
red and white are usually sound and yellow is picture or AV.
you may need to select the input on your TV to recive a picture. Does this help?
May 07, 2009 | Televison & Video
Pink Screen on Vizio 37 inch with HDMI Connection
I work as a contract technician for Vizio, and I can tell you from experience that replacing motherboard is one of the only solutions to this problem. The other solution if under warranty is to replace it. If you experience red, blue, or green pixels where dark shades (like nose, eyes, clothes, etc), call Vizio and accept nothing less than a full replacement! I have had situations where I replaced motherboard and within 2-3 hours the pixels return. Hope this helps.
Dec 13, 2008 | V, Inc. Vizio P50HD Plasma Television
Vizio L37 Television Logo
862 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
