Question about Miele Touchtronic G892 Built-in Dishwasher
Drain intake indicator flashing. We have cleaned all but the intake filter. How do you clean or check to see if cleaning is necessary of the intake filter?
After cleaning the drain, looking at the intake (no filter on ours) and the light wouldn't go off, I just decided to take the ctrl-alt-delete approach and hit all the lower four buttons all at once, bingo, it cleared the light and machine started.
Posted on Oct 01, 2009
  • jer-zgirl Mar 29, 2011
    omg that worked!!! it's been on for 4 days and there was water at the bottom but it's on and running.
ALL LIGHTS ON PANEL ARE FLASHING??
All the lights on my incognito started to flash. This was after the drain/intake light started to flash also. I called Miele and they helped me to reset the lights flashing. They said that when all lights are flashing that this indicates an overheat condition. They asked if my filters were clean and I thought they were. However, my wife had started to use liquid dish washing detergent and the liquid detergent had plugged up the filter screen at the bottom of the dishwasher. I cleaned it good with a scrub brushing and boiling water. This fixed the problem. Bottom line, don't use liquid dish washing detergent in a Miele, only powder.
Apr 08, 2014 | Miele 24 in. Incognito G843SCVi Built-In...
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
My Miele G2430 dishwasher stops right after draining in the first minute or so after starting, and the intake and drain light comes on. The solenoid at the end of the intake hose then clicks and the light...
Hi
Intake/Drain light flashing means an issue while draining. The dishwasher is not draining properly. Please check for air gap on the dishwasher is not clogged. It prevents dishwasher from draining properly and sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Keep handy large bowls and towels to soak the water out. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections and switch it on. If the error still appears then turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs to cancel the error message. Switch the appliance off and then back on again. Hope this helps...please post back for further assistance.
Daniel
Feb 23, 2011 | Miele Optima G2430SCi Stainless Steel...
Dishwasher keeps shutting down with intake/drain light flashing. Had to be restarted at least 10 times yesterday.
first thing to check.
The filter is probably blocked.
It is inside the base of the machine.
Take out the filter and clean it and also clean out the filter well as that can also hold quite a bit of debris.
Please dont forget to vote this answer was helpful.
Many thanks
Feb 17, 2011 | Miele Dishwashers
Dishwasher miele g646sc-the inlet/drain light flashes yet the drain system is clean and working the inlet filter is clean and the filter washed
Hi dear.If the checked lights comes on after the main wash & then flashes(when on main wash cycle,if the main pump works for a few minutes & then stops for a while & so on...)that indicates main wash pump faulty.You need to replace the motor it self.I hope that helps.Thanks.
Aug 25, 2010 | Dishwashers
Intake/Drain lit flashing
I have exact same symptons, please someone help. I have had issue before where the plumbing backed up so it overflowed into the catch tray. Then that has to be vacummed out and then just start a new cycle. This time there is no water in the overflow tray....
May 28, 2010 | Miele 18 in. G601SC Plus Slim-Line...
Miele G 843 Vi won't cycle. Fills, can be drained, but no wash.
Most units have a recirculating pump, and an output (drain) pump.
If I were you, I would disconnect it, drag it outside and turn upside-down (remove everything internal first)
Take off the drain pump and check over, then check the main pump motor for free rotation first.
Also clean both those, and check condition of hoses/ carbon brushes on main motor while you're there.
Doing this full service now should give you a long run without problems.
My guess is the main motor seal may have leaked a very little, allowing the spindle to sieze. Freeing it and applying light oil with regular use should be ok.
Replace carbon brushes if worn to save hassle later - they're cheap.
May 02, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Drain is clogged
I had a flashing red Intake/Drain light. After calling Miele tech support, he confirmed that the drain was plugged so I took all drain hoses apart and finally discovered that the problem was a plugged air gap. I replaced it and the problem was solved.
Nov 18, 2009 | Miele Dishwashers
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Miele Touchtronic G892 Built-in Dishwasher Logo
1,319 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
