Question about Sony Cyber-shot DSC-W130 Digital Camera
My cybershot's lense is stuck out... what do i do?
    President:
  • 1,197 Answers
if ur very sure that the battery is fully charged... first we would advice you to change the batteries and see ...... if that doesnt work... the battery contacts may be corroded or bent and hence not making correct contact with the battery
.... sometimes there cud be dust or sand particles in the lens retraction passage... blow out air in those places..... this cud help a great deal.... I was able to fix a similar problem by wiggling the outermost part of the lens.as its trying to go in....
also try Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
if that doest help
Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. turn it off, slip in the memory card and turn it on one last time.
if that doesnt help
Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying the above fixes and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
regards
iversh
Posted on Sep 27, 2009
Testimonial: "thank youu , no luck though ): the camera will turn on, but i cant take pictures & the lense wont close when i turn it off."
Jammed lense
Good news and bad. It can be fixed, but this is not a DIY project. Any attempts at fixing it yourself will likely worsen the problem. The camera needs professional repair, but make sure that you get an estimate before you commit to the repair -- you may have to decided if the camera is worth this extra expense.
Nov 27, 2009 | Cameras
Sony Cybershot bent lense
Sorry to say that although your camera is in warranty but it does not cover under warranty according to the terms and condition, you just have to visit nearest sony service center to get estimate for complete lens assembly, it must be replaced by new one. You didn't mention model number here that i can tell you the cost and part number of lens assy.
thanks for using fixya.
Oct 18, 2009 | Sony Cameras
Sony cybershot 7.2 When you turn it on the lense comes out and goes in and comes out and goes in on and on and on till you turn it off.
this is a lens array problem probably due to the fact you have dropped it down to floor. the only thing you can do is take it to nearest sony service center and get the lens array replaced. it costs aroung 60$.
May 31, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
My Sony Cybershot w120 camera and now the lense won't pop out
Hi, there is no need to buy a new camera. The lens is avaible as a spare part. If you get a help from an authorized service they will solve your problem
Apr 08, 2009 | Sony Cyber-shot DSC-W120 Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Camera lense
turn on
gently take hold of end of lense and twist and pull it may click but be gentle dont pull to hard or make it pop
switch off and on and this should solve the problem
Sep 10, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
My sony cybershot dsc-p200 lense is stuck.
Sony Cybershot DSC-P200 worked great then the lens stuck in the open position.
Read on this site some one suggested gently manipulating the lens and tapping it then turning it on. It worked!!
Apr 07, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Sony cybershot DSC-W50 lens problen
thats normal.
it just doesn't have enough power to bring the lense back in.
once you charge your battery and turn it on the lense will automatically come back in and then out for you to take a picture.
Apr 06, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Lens stuck open
I have to agree with one of the comments previously posted. I too had a Sony DCS-S700 and the lens was stuck open. Whenever I turned the camera on, the Sony Cybershot logo appeared and dissappeared, turning the camera off. I noticed the lens was crooked, so I moved it in the center direction and the camera worked again.
Mar 06, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Cybershot
Haha, I have the same problem.
The lense is stuck.
I kept turning it on and off repeatedly.
And now I can view pictures on it again.
Nov 03, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-shot DSC-W130 Digital Camera Logo
288 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
