Question about Denon AVR-4306 Receiver
Denon AVR-4306 Optical In problem
Whenever I connect a device such as a TV or Media Center PC to the Optical In ports they do not produce any sound. The other ports seem to work fine. I have tried connecting to 3-4 different optical in ports using a Toslink cable from multiple devices and have no luck. I am setting the Audio In - Digital In Assign to Optical 1 and am attaching the cable correctly. The video from my Media Centre PC comes through the HDMI cable fine and works with RCA jacks. Is there another setting besides Digital In assign I need to make or do you think it is a hardware problem?
SOURCE: Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Posted on Dec 24, 2008
  • 11896 Answers
SOURCE: Need help connecting PS3 to my Denon AVR-3801
You could try sticking a vcr/dvd player in between the connections and using those input/outputs instead.
Posted on Jan 17, 2009
  • 163 Answers
SOURCE: Have put an optical cable from optical digital out
You need to do digital input assignment. Go to SETUP, DIGITAL INPUT ASSIGNMENT, set OPTICAL 1 for your input (DVD).
Posted on Apr 09, 2009
SOURCE: My Denon AVR-5800's optical (toslink) inputs no
everything is HDMI connection now. i still have the avr-5800 denon reciever. how can i make this work with my new LCD, DVD with hdmi connectors now a days. i want to keep my AVR but this lucks of hdmi connection. so how can i make my connections on these? video and sound?
Posted on Dec 07, 2009
  • 8546 Answers
SOURCE: Unable to assign optical and digital inputs to other inputs
It won't let you assign the same input twice. Check to see that DVD is not already assigned to any other In(x) function.
From the manual:
• You cannot select a specific item more than once.
• You cannot assign the same input source to both “IN (2)” and
“IN (3)”. For example, you assign “CD” to “IN (2)”, “–––”
appears in “IN (3)”.
Posted on Mar 16, 2010
I would like to find out how to play audio from my panasonic viera tx-40cx400b tv/other devices e.g. xbox one etc through to my Teac A-H300 amplifier.
Having looked at the TV, you will have a lot of problems trying to connect to that amp. The TV has a digital optical out output only. The disc player you mentioned will also be out only. You need a optical "in" for them both. The TV has no analogue out sockets. The only chance you might get any sound out is via the scart socket. If that is fully wired, then the scart might produce L&R analogue out. A scart plug with RCA connections (make certain it has both audio in and out) might produce some sound for the amp.
Otherwise no chance!
The amp you have was not made to work with digital signals. The TV will produce high quality Dolby 5.1 sounds. Assuming you get the scart to produce the sound, then you will only get stereo sound, little better than the TV itself!
I therefore recommend you get a decent digital amp that you connect all your future devices too. One that has HDMI connectors as well as at least two optical inputs.
Onkyo make some excellent models. For example this model would do the job Onkyo TXSR444 Home Cinema Receiver.
Feb 25, 2016 | Teac A-H300 Amplifier
How to connect tv, direct tv box, and home theater together properly ?
Hi Vincent
That would be a heap of detail to go into. Time consuming...
Hopefully this quick pointer might help.
What is HDMI
High Definition MultiMedia Interface
Note the word MultiMedia
This Means....Both HD Video & Sound through the one cable.
HDMI is the latest state of the art connection.
Use this wherever possible. It's made for High Definition
More Convenient
Use a HDMI cable from one device to the other wherever both devices have that port type (connector).
You don't have to pay a premium ridiculous price for HDMI Cables as in the Monster type. Overpriced.
Well made regular brand & Gold pins are nice. Keep them Short.
Long Cables loose quality. 1 Meter is default.
Your LCD TV should have more than one HDMI port for inputting & outputting media (sound & video)
HDMI can be used for INPUT or OUTPUT
Eg OUT to an Amplifier or IN from a device like DVD Player.
On the OLDer equipment you will Have a YELLOW connector. That is used for the Video signal.
Fiber OPTIC cables are a better way to transfer AUDIO than the red & white cables. Cleaner.
But this only works if the 2 devices have an optical port available.
Some New Amplifiers are smart and may require you to select the optical port in the settings instead of the default HDMI.
This may also apply to HDMI Port Choice.
Simply plug the HDMI in first & check.
Use a known source e.g. play a DVD or CD or Radio Reveiver as a signal.
ONE HDMI Port on the TV might be an OUTPUT ONLY channel (PORT) to an External Amplifier (if you wish to use one)
HDMI on external devices will be Outputing video & sound on their HDMI Port
To the INPUT HDMI PORTS on the TV.
Some TV's will fall back to a particular HDMI port on power fail or startup therefore not requiring you to use the remote every time.
External SPEAKERS should have the polarity checked. Eg Red (or marked wire) to the same post on either speaker. This makes sure that the speakers travel forward together at the same time. Pumping sound forward then retracting together....
so they are not fighting against each other.
.......This is called out of phase & distorts sound.
Hope this Helps
Enjoy Your New Entertainment
Was this Helpful
.......Then give me a tick of approval for my trouble....
HDMI Wikipedia the free encyclopedia
Feb 13, 2016 | Orion LCD TV SLED2480 Sansui - 24"...
How do I connect a sound bar to my Panasonic TX-50A300B I want to use an optical cable as ear phone jack does not produce a decent level
If your TV has an optical port on the back, you simply get an optical cable long enough to connect the two. On your TV sound setup screen you'll have to select optical out so the sound from the TV will be switched from the RCA jacks to the optical out port.
Nov 21, 2015 | Panasonic Televison & Video
No "red light" on Digital In
The port on the jvc is probably an input, which does not produce light. Only optical outputs will have the red light in them.
Jan 04, 2013 | JVC TH-A75R System
I can't get a menu screen up on my Denon AVR 2803.
Did someone turn the OSD off on the menu? You might try a reset of the receiver. This would be in your manual.
Aug 23, 2012 | Denon Avr 2803 7.1 Channel 875 Watt...
Trying to connect HP M9060N and Sharp Aquos through Denon AVR 1508, only get 'no signal' response. Have HDMI 1 set to DVD, HDMI 2 to AUX, HDMI 3 to TV, which is order of HDMI outlets on receiver.
Depending on your TV inputs, you are better off to run video componenets through TV first then, connect TV to reciever via digital optical. Recievers have video pass through but, noyt the best route. You can use TV's menu to choose what you watch and, only have the one output from TV to reciever. Make sure you scan through TV and reciever menus to make sure you are selecting the right channel.
Jun 21, 2011 | Denon AVR-4306 Receiver
How can i upgrade denon avr 4306 up to 1080p?
You don't need to upgrade that model as it already supports 1080P. If you are using HDMI connections between the receiver your TV the receiver will upconvert the other analog video sources (composite and component video) to 1080 content. Most likely 1080i as this is the standard format when upconverting.
Feb 28, 2011 | Denon AVR-4306 Receiver
Acer AX1700-U3700A with variable Audio on HDMI
Your problem isnt in your PC, it's because you chose the onboard sound to listen to music etc, which is normal. Unfortunately, you need to choose the HDMI Audio output if you want sound on your TV FROM the HDMI cable. Right click the sound icon located to the lower right side of your screen and choose (adjust audio properties). Now go to the audio tab and click the output device window and choose your HDMI audio output, whatever it may be called. Just pick the one that wasn't selected when you opened it and click ok or apply. Now all audio output is controlled by your Video card lol. Crazy aint it?
Feb 14, 2010 | Acer Aspire AX1700-U3793A PC Desktop
Open Questions:
See all Denon AVR-4306 Receiver Questions
Denon AVR-4306 Receiver Logo
131 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
