Question about HP Pavilion zt1135 Notebook
How to repair the left click button on HP Pavilion ZT1135
It feels like the spring under the left touch pad button has either broken or is out of place. This has happened 3 times before and I was able to get it fixed under warranty. Now I have no warranty and want to fix it myself. Please help me!
Hey,
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Posted on Sep 25, 2009
Very slow 2003 HP Pavilion zt1135 laptop computer
Go to start type
run after that type mscofig after that go to advanced option after that go to boot put there to the last number of prosecor that how you do it
Feb 13, 2013 | HP Pavilion zt1135 Notebook
On touch pad, the left and right click below the pad, for the mouse, the left button doesn't click anymore?
Since the left button is a primary button it gets used quite a lot thus the button fails at some point in time.
Either the button has broken or the spring mechanism has broken.
Don't worry it can be repaired, claim warranty support if you can. The laptop needs to be partially disassembled and the buttons inspected. The button may need replacing.
Take care!
damnor01
Jun 09, 2011 | HP G70-460US Notebook
Hp touch pad will not allow me to click on anything
go to the settings under control panel for the touch pad and see if you need to adjust one of the settings.
Jul 27, 2010 | HP Pavilion dv9000z Notebook
My left click button on my touch pad of my hp laptop is loose, how do get access to under the click button? I have a hp pavilion dv5.
Ask HP for the part's list+diagram for the laptop. It should show you what to tae out and where the screws are.
Apr 11, 2010 | Compaq Presario M2000 Notebook
Hp pavilion dv4 left buttom not work
left click is membran switch it was fix in motherboard
need to replace it .
for tapping control you can set as per your comfort from
start menu ---> setting ---> control panel ---->mouse
in "Buttons" tab select double click speed and check it right side yellow folder open and close when you tapping
Feb 01, 2010 | HP Pavilion dv4000 Notebook
Hey My touch panel aint working
there is a button at the top of the touch pad with a light to the left, blue means its unlocked, orange means its unlocked. try the button to swap between states
Jan 12, 2010 | HP Pavilion dv6000t 15.4" Notebook Laptop...
Hp dv6000 touchpad - left button doesnt work - what do i do
Does the button actually click when you touch it? If it does not, if you cannot feel a "click" then the button underneath the plastic had collapsed and the actual button board underneath the touchpad area will have to be replaced. It is actually cheaper to just buy another palmrest with the touchpad assembly in place.
Jan 04, 2010 | HP Pavilion dv6000z Notebook
Hp touch pad keeps clicking like crazy....
Try the following steps...
1. First clean the touch pad with a dry cloth.
2. Disconnect the battery and the AC adapter and any other device that is connected to the NB and hold down the power button for 2 mins. This will drain the static.
3. Go to device manager and click on the + sign beside mice and other pointing devices, select synaptics / alps touch pad driver, right click on it and uninstall it. Now go to recovery manager > advance options > hardware driver installation > select the same driver and reinstall it.
This should fix it....
otherwise, go to hp.com/suppport and download the latest bios available.
you can also run a spyware scan if all the above steps do not work. go to www.filehippo.com and download antispyware program and run a scan.
Hope it helps..
Regards,
Anup
Apr 08, 2009 | HP Pavilion DV7-1023CL Notebook
How to left click on my Toshiba laptop
Under the touch pad there are two buttons the left one should bring up the context menu (Left Click).
The right one is a standard select button.
Jan 22, 2009 | Toshiba Satellite P205D-S7454 Notebook
Left mouse button on touch pad not working
have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Dec 30, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion zt1135 Notebook Logo
605 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
