Home | Whirlwind | -Air Cooler with Heater and Humidifier, FH-... | R22 upright or ups...
Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner
Problem for Whirlwind -Air Cooler with Heater and Humidifier, FH-778...
R22 upright or upsidedown?
By gary_bright on Sep 25, 2009
My compressor comes on for about 2 seconds, then shuts off. I have replaced the capacitor, but it didnt help. When the compressor kicks on for the short time, i see bubbles in the glass looking almost foamy. After about 2 minutes it comes on again for 2 seconds and has bubbles again. I understand this mean its low of freon. I have a can of r22, the recommended coolant. My question is, "do I hold the can upright or upside down to add it"?
Solution #1
posted on Sep 26, 2009
Not Rated)
terrencio
Rank: Master
Rating: 96%, 8 votes
If the sight glass is foamy, stop what your doing, the system is contaminated with moisture. Chances are the compressor is gonna be toast. First reclaim the refrigerant, second replace the filter drier. third triple evacuate the unit with a vacuum pump, until the pressure gets down to below 1000 microns.(400 is ideal, but I doubt this system will ever see that without replacing the compressor). Fourth, if these tasks are beyond your abilities, call a service company, or have the unit replaced. The reason the compressor shuts off after two minutes is because theinternal overload protector has tripped, this means the compressor is drawing too many amps, since you have replaced the capacitor I cansafely assume, either the internal components of the compressor have been damage by the acid created by the presence of moisture in the system, or the filter/drier, or strainer (internal) have been plugged with debris. Either way it will take several hours of work to save it, or a few hours to replace it. Sorry to have to give ya the bad news.......good luck!
Was this helpful?
Yes
No
Solution #2
Not Rated)
mac5932002
Rank: Guru  Air Conditioners  Expert
Rating: 88%, 52 votes
STOP what are the pressures. you dont want to add freon just yet
Was this helpful?
Yes
No
Solution #3
Not Rated)
jumptrout51
Rating: 89%, 998 votes
Attach the service gauge to the low side and position the refrigerant container upright.
Was this helpful?
Yes
No
Popular Solutions for Whirlwind -Air Cooler with
Questions and Unsolved Problems for Whirlwind -Air Cooler with
Do you recommend Whirlwind -Air Cooler with Heater and Humidifier, FH-778 Air Conditioner?
Answer
Answer
Just missing the piece that holds the vent in the window for an Everstar portable a/c. Is it... (More)
Answer
Installed a new Hunter thermostat a few weeks ago. All was cool (pun intended) until yesterday when... (More)
Answer
MPMI-10CR-BB6 DONT WORK THE AC DOES NOT TURN ON AND WHEN ITS PLUGGED ALL THE LIGHTS ARE ON, WHY ITS... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlwind -Air Cooler with...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
