Question about Gateway MT6451 Notebook
The monitor just goes out. It displays vertical
The monitor just goes out. It displays vertical lines. I've been told it's a bad motherboard please help
  • Gateway Master
  • 1,606 Answers
Vertical lines can mean either a connector problem on the lcd itself or on the motherboard connector or a problem with video ram or the chip. Unfortunately none of those are cheap or easy to fix. You can try an external monitor and if that displays normally then the problem is connector or lcd. You can sometimes find a replacement display at fair prices so if that is it then it might be worth fixing. If it is the motherboard then the repair can cost as much as a new replacement laptop.
Posted on Sep 26, 2009
Display vertical line
Turn off the monitor and disconnect it from the back of the pc. This way you will isolate the monitor from the PC. Now turn on the monitor, if you still see the vertical line then that means the screen is bad and you would need a new monitor.
If the monitor doesn't have the vertical line then that means your video card is the issue or if you have an integrated vga port on the back of the computer then the motherboard is bad and would need to be replaced.
Sep 23, 2013 | Acer V173 Monitor
I have a vertical line on my lcd sreen what is the cause of this problem
Could be your video card(GPU) or bad pixels in the monitor itself.The best way to tell for sure is to borrow a monitor and hook it up to your machine.If the line is on the other monitor the GPU is bad,if not your monitor is bad.
May 27, 2011 | Computers & Internet
Video displays vertical lines then goes blank
There could be 3 possible reasons for a vertical lines
1. Driver for graphics card needs to be updated
2. Grpahics card faulty
3. LCD problem
try connecting an external monitor and see if the display is also vertical on the monitor, if yes the problem is graphics card, if no, the problem is the LCD. Hope this helps
Dec 11, 2009 | Acer Aspire 5100 Notebook
Laptop screen displays vertical lines of various colours
Have you tried to connect your laptop to external monitor?
If you get normal picture on external monitor, then you need to replace LCD screen, but if you get same picture on external screen, then unfortunately you will need new motherboard, because graphics card is integrated to motherboard.
Aug 13, 2009 | IBM ThinkPad R52 Notebook
Asus 1000he red vertical line in monitor will not
Hi
If you have External Monitor check by connecting it
if you get display on external monitor without line it means Display screen is Bad, if Line appears on external display as well then there is either Display driver issue or motherboard problem.
Jul 19, 2009 | ASUS Eee PC 1000H Laptop
Vertical white lines appear on screen and music will play, beeping and a "chopper" noise have also occured. Replaced motherboard in Dec 08.
To isolate the issue.please connect the notebook to external monitor with the help of VGA port.(Blue PORT) on the notebook.if it good with out any lines.you need to fix the LCD screen of the Notebook.
May 10, 2009 | HP Pavillion ZV6000 Notebook
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Gateway MT6451 Notebook Logo
106 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
