Question about Amana MH09A3PA235 Comfort Zone Room Air Heat/Cool-Heat Pump, 9000BTUH, 230V Air Conditioner
When the ac unit is on the water comes in the house
  • Dennis Boxerman May 11, 2010
    Just exactly where is this water? Near the indoor unit? (Air handler)
  • 334 Answers
The condensate drain line is clogged, causing the condensation water to overflow. You can use a shop vac to clear the line. attatch it to the outlet side of the line. also clean out the condensate drain pan located at the bottom of the indoor coil.
Posted on Sep 26, 2009
My ac isnt draining water and creating mold in the house on my furniture & clothing
drill hole in cabinet to let water drain but be careful of wherer u drill. 3/8 bit is big enough
Jul 23, 2014 | Frigidaire FAC125P1A Window Air...
Haier portable AC water collection tank full in one hour.
My unit was working fine for a couple years but now it won't evaporate. It still cools fine but it also collects about 16 ounces of water every hour and then shuts itself off until I drain it. I'm wondering it the evaporative mechanism it broken some how.
Jul 24, 2013 | Haier CPN12XH9 Portable Air Conditioner
Carrier Infinity AC indoor unit in the garage is leaking water on the floor. There is no ice on the coils, The drain is not clogged. There is no water in the coil area. I turned off power to the...
It seems as though you have an unrelated water leak....
Often the water supplies are copper tubing....
Copper tubing and concrete do not get along well...
but hey it lasts till the warranty is up....
and they can't see it from their house...
heatman101
Jan 16, 2011 | Carrier 52CQ315 Air Conditioner
My heil 9000 leakes water when ac is on
mcdevito75 here, This is normal condensation, the water should be directed away from inside the house, if need be call an A/C repair shop to come to the house and increase the tilt of your A/C unit in the window so any water or condensation build up is directed outside.
Aug 27, 2010 | Heating & Cooling
I have a Weather King AC/Furnace in the attic that's dripping water into the drain pan. When we purchased our new house it came with this unit and it never dripped ater. Now, the water is dripping towards...
I assume it is dripping water when the AC is running. If you look at the attic unit, there should be a PVC pipe running from the unit - probably an insulated PVC pipe. This pipe probably goes across the attic to the edge of the house and drains outside. The drain pan may also have a drain pipe, but the one on the AC unit is the issue, and is probably plugged. Go outside and see if you can locate the AC drain pipe. See if the ground is wet below the pipe and if water is steadily dripping from the pipe (with AC running). If the pipe and ground are dry, the pipe is plugged. If you have a wet/dry vac, try connecting it to the drain pipe outside to see if you can **** the pluggage out. If you can get it clear, water should start dripping out of the pipe. This same thing happened at our house. I decided to cut the pipe in the attic, and add in a PVC isolation valve, tee, and water hose connection with plug, so I can valve out the AC unit from the pipe, remove hose connection plug, and hook up a water hose and flush the line to outside. Lowe's sells all of the PVC pipe fittings. The water pressure from the hose will always flush out the algae and crud to the outside of the house. I can also remove the plug and pour a cup of bleach down the drain pipe every couple of months to keep algae growth in check. I also cut out the trap (u-leg) from pipe in the attic and purchased a ready made trap a Lowes (the contractor who built our house had made a lousy homemade trap). I purchased a few PVC elbows and installed the trap on the drain pipe outside. By the way, our AC drain pipe comes out of our wall outside and drains near our outside unit. Our secondary drain pan drain pipe comes out outside from an eave on the side of the house. I don't know what you drain line looks like (it may have a port to add bleach, or some cleanout provisions, maybe not). If you choose to modify/improve it, then make a sketch of it, go to Lowe's and get the PVC parts you need + PVC pipe primer and cement. PVC cement dries fast. Remember, the pipe must flow downhill from you AC attic unit. You can use a regular wood saw to cut the pipe. I hope this helps you. You need to keep the drain line clear as algae will continue to grow in it. Pouring bleach in the line every month or two helps. You also need to check maybe once a month that the line is draining properly (check to see if dripping outside). You can get some serious water damage to your ceilings if the water backs up and overflows. I discovered that our drain line was plugged just in time as our drain pan drain line was also partially plugged and drain pan was about to overflow.
May 08, 2010 | Weather King 12AJA4201AH Air Conditioner
My a/c is trwonig cold water and air
The water is standing in the ac unit and not draining out.Is this a window unit?Ac on a car or truck?If it is a window unit for a house,remove ac unit from window,and take out side and if it is in a cover,remove the cover to expose the ac unit,and it`s components.Wash out the bottom of the unit to uncover all the drain holes.Get all debri out of unit.Replace the unit in the window at a good tilt(tilt it outward)so it can drain good,and not back up in your house with water.
Aug 29, 2009 | Heating & Cooling
Portable AC leaking
depending on where you live. do have high humidity. then you have excess amount of water that might make condensate. like very cold can of can of coke.
Jul 11, 2009 | Soleus PH310R03DB Portable Air Conditioner
Just purchased a 15000 btu 110 Frigidaire window unit and we love it. However, since the rear of the AC is actually on the back porch, the water from the AC runs down the wall and on to the floor. We could...
window units slide into an outside frame section
there is a hose attachment area at the back of the ac unit proper that a hose can be attached to
and there should be a section in the frame that allows the hose to be fitted to that ac unit proper
the unit should be mounted so that it actually slopes slightly down at the rear so water can collect at that drain point
there are adaptors that should have come in the packing box for hose attachment
if not, many people use white poly piping or electrical conduit with suitable elbows to collect the water at the hole and pipe it back to the wall into a bucket and the collected water used to water plants and gardens
May 02, 2017 | Frigidaire FAC126P1 wall/window Air...
UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS COOL NOT COLD COMING OUT OF VENTS CARRIER 58DLA / 58DLX CENTRAL AC FAN AND COMPRESSOR ARE OPERATING BLOWER IS WORKING UNIT IS TURNED ON TO AC TEMP SET AT 76...
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
May 03, 2009 | Carrier Heating & Cooling
Heating & Cooling Logo
177 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
