Drum light on hl2140 keeps flashing even when new drum unit has been installed
HOW TO REMOVE DRUM ERROR IN BROTHER HL2140 PRINTER
Need to replace drum and reset the counter
(Essentially the cartridge/drum unit should not be in the printer when you reset it)
1) Open front door
2) Remove the cartridge/drum unit
3) Hold down front button until all lights come on
4) Put cartridge/drum unit back in
5) Close the front door
The Drum life should be reset.
Jul 07, 2011 | Brother HL 2140 Laser Printer
Print want print
If you recently purchased it, just put it back in the box and take it back to the store for a replacement. I wouldn't bother tryng to fix it if you can get a brand new one that works the way it's supposed to.
Apr 02, 2010 | Brother HL 2140 Laser Printer
Brother HL5250DN PRINTER THE DRUM LIGHT KEEPS ON
it has a drum sensor ,it was disable to work but it look like new please change ot replace drum unite not only drum total unite then solve your problem
thanks Tareq
Nov 11, 2009 | Brother HL 5250DN Laser Printer
I have a brother printer 2140 and the drum light stays on :0
You have to open the door and hold the go button til all lights flash. That tells the printer it has a new drum. After that press the go button 3 times and it will print a report that shows the drum as new...
Jul 09, 2009 | Brother MFC 210C All-In-One InkJet Printer
HL2140 - DRUM REPLACED APPROX 3 WEEKS AGO, LIGHT KEEPS COMING ON
When you replace a drum in a brother machine you have to tell the machine it's a new drum. The instructions are on a sheet packed with the new drum. With the front door open you hold the panel button until all the lights flash on, then close the door and you're ready to print.
Jun 23, 2009 | Office Equipment & Supplies
Yeah, I have the HL-5250DN printer. The light
Hi there -
The reason the drum light keeps flashing is that you have to "reset" the machine after you've installed a new drum. To do this, I believe all you have to do is make sure the printer is on and then push and hold down the "GO" button a few seconds and then the flashing will stop. This will "reset" the printer to recognize you've installed a new drum. I'm going from memory on that, but I believe that's correct. It's a really simple solution. Good luck!
May 15, 2009 | Brother HL 5250DN Laser Printer
Drum light flashes
its the sensor, its not aligned to specs. make sure the drum is in its proper space then, unplug for 5 min to reset the control panel.
Feb 11, 2009 | Brother HL 5140 Laser Printer
Drum
Try this to rest the drum counter.
After installing a new drum unit the drum counter must be reset. Use
the following steps:
1. Printer must be powered on.
2. Press the cover release button and open the front cover.
3. Press and hold the Go button until all four lights are on solid.
Release the Go button.
4. Close the front cover.
5. The drum light will now be off.
Feb 06, 2008 | Brother HL 5040 Laser Printer
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
453 people viewed this question
jasbo
jasbo
